Seb.Mure
X-Factory - X6 Square
560 posts in this topic
X Factory, responding to input from customers, releases a kit to allow faster removal of the batteries from the X – 6 Squared and X – 60 without damaging the chassis.
Chief Engineer Paul Sinclair said, “Many Family members live and race in places where LiPo batteries must be removed from the car for charging. Also, many who use cells instead of LiPo want to remove them to charge or store. The X – 6 Squared’s CF battery strap is held in with flathead screws which go into posts in the chassis. Constant installation and removal of these screws will damage the threads in the chassis, and this new kit eliminates the problem.
“Many owners of the X – 60 truck have converted from the Kit-supplied nuts to thumb screws, but that will not work for the X – 6 Squared because the body sits too low. The new Quick change kit contains four 1” long set-screws that can be installed in place of the standard bolts with an Allen driver and four low-profile locking nuts which are just low enough to clear the buggy’s body.
“We think truck owners will like this kit because the set-screws can be installed so they barely protrude above either the supplied low-profile nuts or a thumb screw, thus making a neater installation. And all X – 6 Squared owners will want one.”
Part # 1225, Battery Quick change kit
Voici les références des pièces pour monter les courrones Losi, particulièrement celle de 82 dents pour le X60 mais qui s'applique au deux versions du X6.
LOSA3123 Disque de friction
LOSA3132 Plateau de friction
LOSA3931 Courrone de 82dents en 48dp
LOSA3983 Courrone de 82dents en 48dp, chargé en Kevlar
Ce qui donne le tableau de rapport suivant:
J'en ai profité pour condenser le tableau des ressorts au AE et Losi, pour ceux qui cherchent les correspondances. Le document est disponible dans les pages de réglages du X6 et X60
[attach]4666[/attach] [attach]4667[/attach] [attach]4668[/attach]
Dans le principe c'est les même que celle livrer en plastique.
Mais elle sont plus belle donc oui ;) Normal je les ait commander!
sympa mais vraiment utile?
utile oui car elles sont filletées donc on ne force plus dans le plastique je l'ai prise juste pour ca je m en fout qu'elle soit jolie...
Et sinon, pour ceux qui on eu le X6 et ensuite le X6², qui à vu une différence?
Niveaux comportement?
jesais pas moi j'ai connu le Rb5 (une charette) et donc le x6 square.
ya pas photo entre les 2 chassis, l'un est super delicat a piloter, l'autre est facile avec une bien meileur feeling des les 1ers tours de roues :)
Moi j'ai eu le B4 il à quelques temps et j'avais beaucoup de mal.
Et là j'ai le x6 mais j'ai cassé le chassi pendant l'entrainement samedi, je l'ai recollé en esperant qu'il tienne jusqu'à la derniére finale de dimanche.
Promo sur les pièces d'anciens x6 (donc pas le squared) ;-)
Il faut compter 50€ env pour un chassis et pour le kit du squared est à un peu plus de 100€, et on repars avec une caisse neuve...
Je voulais dire qu'il falais rajouter env 100€ de plus pour avoir le kit.
Answer-RC Xfatcory X6 SQ ABEC-5 16pc Bearing Set
Using Answer-RC Bearings specially manufactured for 1/10th scale this set offers a excellent value bearing set for the Xfactory X6 Series.
One rubber seal and one metal shield offer the prime ratio of protection versus free running. Use the rubber seal on the side facing dirt to keep the filth out. Lubricated with a high quality bearing oil these bearings offer free running and excellent longevity.
Contains
14 x ANSBR3318
2 x ANSBR3553
Une petite question au possesseur de X6² ? quel moteur brushless vous conseillez pour bien exploiter la « bête » avec des lipos : 6,5 – 7,5 voir 8,5 T ?
Merci !
PS : Plutôt sur des pistes du style gargenville ou montigny (herbe - terre).
Meme avec 9.5, moi c'est ce que je mets
8.5 avec rapport 26/78 => nickel pour les pistes longues et accrocheuses. (Astro Turf par ex.)
9.5 avec rapport 28/78 => nickel pour les pistes courtes et glissantes. (terre par ex.)
7.5 avec rapport 24/78 => bien mais un peu trop sec, même pour les pistes Astro Turf.
Et oui, c'est dans l'air du temps, on est au Down Sizing!!!
Attention, ces données sont à comprendre avec l'utilisation d'accus LiPo à forte décharge. (type 35 ou 40c)
pièces pour le pincement arrière à l'état prototype par team aj pour x6 / x6² / x60
angle de pincement fournie: 3°/ 4°, angle de 3,5° / 3,75° en court de test
prévu en bleu et noir
Mais ou peut-on trouver ce radiateur moteur ???
X-Factory X6 Parts
5 different packs available
Pack 5 is the comprehensive kit with full instructions
Pack 5 which includes pack 1 + 2 + 3 + 4 + Ellis Stafford 'secret winning' instructions
X6 Brass Weight Distribution Kit
The long awaited complete weight distribution kit for the X-Factory X6
This kit is designed and used by British Champion Ellis Stafford.
The kit comprises of all the identical weights that Ellis uses and manoeuvres around the chassis for different track conditions.
All parts made from high quality brass....
The kit also comes with Full Instructions written by Ellis himself
First batch - Currently 20 in production and will be available on the 6th of July.
Pack 1 - X6 Under Speedo Weight 70g
Permanently fixed in the X6 this weight is essential to the cars performance
Pack 2 - X6 Behind Servo Weight Adjustments 120g
This is a 4 piece kit that has adjustments of 1=30g 2=60g 3=90g 4=120g
Again as used by Ellis Stafford
Pack 3 - X6 Rear Corner Weights x2 35g=70g
Used in low grip conditions
Pack 4 - X6 Under Lipo Weights x2 25g=50g
Again as used by Ellis for certain track conditions including bumpy tracks
www.rudebits.co.uk
les prototypes sont devenus réalité
cales de pincement arrières pour X6, X6² et X60
couleur disponible: noir et bleu
angles disponibles 3° et 4°
en bleu
en noir
X-Factory X6 Parts
(pack 5 which includes pack 1 + 2 + 3 + 4 + Ellis Stafford 'secret winning' instructions)
(pack 1) X6 Under Speedo Weight 70g
(pack 2) X6 Behind Servo Weight Adjustments 120g
(pack 3) X6 Rear Corner Weights x2 35g=70g
(pack 4) X6 Under Lipo Weights x2 25g=50g
www.rudebits.co.uk
Ca doit être interessant mais là franchement j'y comprend rien. Personne ne peut le traduire???
