Losi - Electric 8ight
93 posts in this topic
5251.attach
Losi est en train de travailler sur un 4x4 1/8e Electrique
We were at the track shooting some action shots and we notice the Losi Team was out testing a mysterious new car. You can try to figure out what's missing from that "factory white" Losi 8IGHT. It's not missing color, wheels, a body, or an antenna (okay it's missing that antenna). If you look close you see it's missing an engine, pipe, and if you have XRAY vision a fuel tank.
That silence is the sound of what should be the first production brushless 1/8-scale from a major manufacturer. This will eliminate the cost of buying an entire nitro kit and having to buy a separate conversions (more money). When, where, and how will all be answered when Losi is ready to show the details of the car...but for now if you are thinking about big electrics this will make for many good dreams about silent racing.
Des kits de conversions (Ex: Novak) existent actuellement mais qu'un fabricant travaille sur un projet d'une telle nature, cela est plus intéressant et souligne l'intérêt pour cette catégorie par rapport aux risques et nuisances engendrées par le combustible utilisé dans les catégories thermiques
Quelques images d'un Losi 8ight converti en éléctrique, pas le projet Losi
pour la photo ci dessus, je crois que c'est un kit d'adaptation Novak (proto) pour Kyosho MP777
Une autre réalisation personnelle sur base Losi
Electric-oriented modelers eager to drive Losi's renowned 8IGHT or 8IGHT-T are going to love this new 8IGHT Electric Conversion Hardware Kit . The kit converts the nitro-powered 8IGHT family of products into an electric-powered ride. The hardware kit includes a molded battery tray and straps for up to a 5 cell LiPo pack, radio tray, aluminum motor mount, 2 pinion gears (1 for buggy, 1 for truggy), spur gear and all screws and washers needed to mount the components to the chassis.
Xcelorin Brushless Systems from Losi represent the latest development in brushless power and performance. The 1/8-scale 1300Kv Xcelorin Sensorless Motor and Electronic Speed Control Combo will convert any 8IGHT-based race or RTR vehicle into an electric vehicle. Enjoy the brute torque and speed achieved through brushless technology with Losi’s 1/8-scale Xcelorin Sensorless Brushless Systems.
The Xcelorin Sensorless combo combines the performance features of the two components below to achieve the power and response needed for RC competitions.
1/8 Sensorless Motor - The powerful 720-sized Xcelorin Sensorless brushless motor offers performance designed features like a sintered neodymium rotor, precision motor ball bearings, and is virtually maintenance free.
1/8 Sensorless ESC - The feature packed Xcelorin Sensorless Electronic Speed Control features a high-speed cooling fan, pre-wired Losi EC5 power connector, accommodates a 3-5 cell LiPo battery pack, forward/brake with reverse or forward/brake settings, two preset drive profiles with unlimited potential with a PC and much more.
The ESC also includes a Quick Programming Card, which allows adjustments to the ESC without the need for a computer, and included three pre-programmed profiles for convenience.
Features
* Molded battery tray with three hook and loop straps capable of holding a 3-5 cell LiPo battery pack
* Radio tray designed specifically for the 8IGHT-E
* Comes with all hardware, including screws and washers needed to mount components to chassis
* Two pinion gears (15T and 16T) and one 45T spur gear
Features
- Powerful, 720-sized brushless motor
- No motor maintenance required
- Precision motor ball bearings for smoother operation
- Sintered Neodymium rotor
- Longer run times
- 150A continuous current with 720A peak
- Prewired Losi EC5 power connector
- Accommodates up to a 5-cell LiPo battery pack
- High-speed cooling fan for lower running temperatures and protection
- Optimized for Spektrum or legacy radio systems
- Adjustable low-voltage cutoff to protect your battery investment
- Forward/Brake with Reverse or Forward/Brake settings
- Forward and reverse throttle limiting available
- Four LEDs to indicate functions
- Two preset drive profiles with unlimited potential with a PC
- Quick Programming Card allows adjustments to the ESC without the need for a computer
- Includes three pre-programmed profiles for convenience
- PC setup software CD included for complete configuration of profiles
- Software interface allows for unlimited profile settings and tuning
- Adjust brake and throttle curve settings with the simple-to-use graphical interface software
Interessant - au fait, c'est kiki fabrique le BL/controleur Losi? Feigao/hobbywing? ou autres?
(il me semble aussi qu'asso propose deja un TT 1/8e tout equipe BL, non?)
bien vu le variateur posé sur un radiateur proche de ceux des moteurs thermiques
5363.attach
Losi 8IGHT and 8IGHT-T owners feeling a little voltage coming on? No problem - Losi has the answer with their new line-up of 1/8-scale products specifically to convert your nitro buggy or truggy into an electric-powered machine! Check out these new releases:
LOSA0912 8IGHT/8IGHT-T Electronic Conversion Kit
This kit converts the nitro-powered 8IGHT vehicles into an electric-powered ride. The hardware kit includes a molded battery tray and straps for up to a 5S Li-Po pack, radio tray, aluminum motor mount, 2 pinion gears (1 for buggy, 1 for truggy), spur gear and all screws and washers needed to mount the components to the chassis.
1/8 Xcelorin Brushless Systems
Losi introduces its 1/8-scale Xcelorin Sensorless Brushless Systems. The 1/8-scale Xcelorin Sensorless Motors and Electronic Speed Control will convert any 8IGHT-based race or RTR vehicle into an electric vehicle. Now, 8IGHT owners can enjoy the brute torque and speed achieved through brushless technology with Losi's 1/8-scale Xcelorin Sensorless Brushless Systems.
- ESC is prewired with a Losi EC5 power connector and will accommodate up to a 5-cell Li-Po battery pack
- Includes a Quick Programming Card for making adjustments to the ESC without the need of a computer
- Forward/Braking with Reverse or Forward/Braking configuration
- Powerful, 720-sized brushless motors feature a sintered neodymium rotor
LOSB9556 1/8 Xcelorin Sensorless Brushless Combo, 1300Kv
LOSB9557 1/8 Xcelorin Sensorless Brushless Combo, 1700Kv
LOSB9420 1/8 Xcelorin Sensorless Brushless Motor only, 1300Kv
LOSB9421 1/8 Xcelorin Sensorless Brushless Motor only, 1700Kv
LOSB9422 1/8 Xcelorin Sensorless Brushless Motor only, 2100Kv
coté perf cela donne quoi ?
meilleur qu'avec un moteur thermique ?
bonnes questions!!
y aurait-il des francophones qui roulent en 8e electric?
1/8 8IGHT-E 4WD Buggy Race Roller
At a Glance
Losi's Limited Edition 1/8-scale 8IGHT-E 4WD Buggy Race Roller combines the innovative design and technology of Losi's award-winning 8IGHT Competition Buggy Chassis with the fierce torque and speed of Losi’s 1/8-scale Xcelorin Brushless Systems.
The 8IGHT-E Race Roller is a competition buggy chassis that has been hand assembled and tuned to exact specifications. Each and every screw is installed to specific torque settings to maintain consistent construction. Additionally, every screw or bolt that secures metal-to-metal contact features thread lock to prevent backing out or loosening due to vibration. The differentials and shocks are pre-built and filled with 100% pure silicone fluid.
The 8IGHT-E Race Roller features Losi’s superior 1/8-scale Xcelorin Sensorless Brushless Power System. The fully programmable, high-output electronic speed control (ESC) can handle a 3-5-cell LiPo battery pack, and offers precise throttle and braking control. The 2100Kv brushless motor requires virtually no maintenance, while offering unmatched efficiency and speed designed for 1/8-scale racing. Additionally, the ESC offers tons of programming options, including adjustable throttle limits, selectable user profiles, and much more using the Quick Programming Card or personal pc programming software.
Once assembled, the 8IGHT-E Race Roller is given a complete inspection to ensure that it meets Team Losi Racing’s requirements for durability and performance. You can be sure that your 8IGHT-E Race Roller is ready for serious competition as soon as you open the box.
Features
* Pre-installed Xcelorin 1/8-scale Brushless System with 2100Kv Sensorless motor w/5mm shaft
* Secure, hard-mount Xcelorin ESC with rubber shock absorbers
* 4mm motor mounting screws
* Large ESC heat sink with fan to keep damaging heat away
* Molded LiPo battery tray with hook and loop straps that can accommodate a 3S to 5S LiPo
* Newly designed body specially built for the 8IGHT-E for improved air cooling of the electronics
* Adjustable aluminum motor mount with rear motor support
* 4mm thick machined and hard anodized aluminum chassis plate
* Unique narrow chassis configuration for quicker handling and ground clearance
* Oversized shocks with threaded hard anodized shock bodies
* Sealed front and rear differential housings keep dirt out of the gears
* Zero bump steer design with adjustable Ackerman
* Captured hinge pins require no retaining clips
* Machined premium aluminum 5mm thick alloy shock towers
Product Specifications
Type:Electric Competition Buggy Race Roller
Scale:1/8
Length:19.5 inches (495mm)
Width:12.13 inches (308mm)
Wheelbase:12.64-12.80 inches (321-325mm)
Chassis:4mm Hard-Anodized Aluminum
Suspension:H-Arm, Full Independent
Drive Train:Offset Drive with 3 Sealed Differentials
Motor or Engine:1/8 Xcelorin Sensorless Brushless Motor, 2100Kv
Speed Control:1/8 Xcelorin Sensorless ESC
Radio:2-Channel Radio System (sold separately)
Servos:High-Torque (sold separately)
Batteries:3-5-Cell LiPo Battery Pack (sold separately)
Charger:Sold separately
Wheel Size:17mm Hex
Kit/RTR:Race Roller
Shock Type:Oversized Hard-Anodized, Threaded Bodies / 4mm Shafts
Body:Clear, 0.040-inch thick, Electric Buggy Racer Body
Ball Bearings:Complete
Needed to Complete
Compatible Battery Charger
2 Channel Radio System with High Torque Servos
Paint for Polycarbonate Body
Losi Recommends:
14.8V 5000mAh 4S 25C LiPo Hardcase Battery Pack (LOSB9864)
Intelligent LiPo Balance Charger, 1-5 Cells (LOSB9605)
Losi's 8IGHT-E 4WD Buggy Race Roller is a competition buggy chassis that has been hand assembled and tuned to precise specifications, and is nearly ready to hit the track right out of the box. This 1/8-scale electric buggy combines the innovative design and technology of Losi's award-winning 8IGHT Competition Chassis with the fierce torque and speed of an Xcelorin Brushless system.
Featured Chassis Callout
01. PRE-INSTALLED XCELORIN 1/8-SCALE 2100KV SENSORLESS BRUSHLESS MOTOR
02. 4MM MOTOR MOUNTING SCREWS
03. SECURE, HARD-MOUNT XCELORIN ELECTRONIC SPEED CONTROL (ESC) WITH RUBBER SHOCK ABSORBERS
04. LARGE ESC HEAT SINK WITH FAN
05. 4MM THICK MACHINED AND HARD ANODIZED ALUMINUM CHASSIS PLATE
06. UNIQUE NARROW CHASSIS CONFIGURATION FOR QUICKER HANDLING
07. OVERSIZED SHOCKS WITH THREADED HARD ANODIZED SHOCK BODIES
08. SEALED FRONT AND REAR DIFFERENTIAL HOUSINGS KEEP DIRT OUT OF THE GEARS
09. ZERO BUMP STEER DESIGN WITH ADJUSTABLE ACKERMAN
10. CAPTURED HINGE PINS REQUIRE NO RETAINING CLIPS
11. MACHINED PREMIUM ALUMINUM 5MM THICK ALLOY SHOCK TOWERS
12. MOLDED LIPO BATTERY TRAY WITH HOOK AND LOOP STRAPS THAT CAN
ACCOMMODATE A 3S TO 5S LIPO BATTERY
13. ADJUSTABLE ALUMINUM MOTOR MOUNT
14. PRE-GLUED XBT PIN TIRES AND DISH RACING WHEELS
Features
Xcelorin Brushless Power System
The 1/8-scale Xcelorin Brushless Motor requires virtually no maintenance, while offering unmatched efficiency and speed. Additionally, the Electronic Speed Control (ESC) offers tons of programming options, including adjustable throttle limits, selectable user profiles, and much more using the Quick Programming Card (QPC).
Ultra Narrow Drivetrain Layout
The revolutionary ultra narrow drivetrain layout positions the brushless motor in the center of the chassis for quicker response, sharper handling, and a plush ride.
Oversized Shocks and Machined Premium Shock Towers
The oversized, precision machined aluminum shock bodies are hard anodized for smooth operation and wear resistance. Threaded shock collars offer easy yet precise adjustment of pre-load and ride height, and strength and durability are added with the extra large 4mm diameter Titanium Nitride shock shafts. The front and rear shock towers are machined from premium aircraft aluminum alloy, and each shock tower is strategically lightened for optimized performance without sacrificing durability.
Sealed Differentials & Housings
Both the front and rear differentials and housings are sealed against the elements, protecting each diff from foreign matter that can affect performance and durability. The tight tolerance diff gears take better advantage of the viscous effect for superior traction and acceleration.
Pre-glued XBT Tires and Dish Racing Wheels
The 8IGHT-E is outfitted with Losi's XBT 1/8 Buggy Tires, the same tires used on the 8IGHT. These tires feature the proven, traditional Losi "X" pattern design for superior traction, excellent rough-track handling and a comfortable feel.
Zero Bump-Steer Design with Adjustable Ackerman Steering Rack
The steering system on the 8IGHT-E Race Roller is designed to prevent uncontrolled direction changes due to bump-steer. The adjustable Ackerman steering rack provides improved turn-in and precise control as well as additional tuning options to help you easily drive at speed on a broad range of conditions.
il faut un moteur spécifique la dessus??? je peux utiliser un gtb + 4.5 + lipo???
Dans la crèmerie où je me rends, je leur ai demandé s'ils pensaient que l'électro 1/8 allait bientôt marcher.
Ces derniers m'ont répondu qu'ils n'y croyaient pas du tout, ou alors dans 10 ans, avec un rire entendu.
Et bien, je suis certain depuis le début que cette formule va faire un malheur, et qu'un championnat ne va pas tarder à voir le jour, même dans notre cher pays, toujours un peu à la traîne....
C'est super alléchant en tout cas, je n'y vois que des avantages.
Christophe.
100 % daccord avec toi :applo:
Des que la fédé s'interresse a cette catégorie je switch immediatement même si au debut il faut essuyer les platres et se retrouver à 20 en Cf et à 2 en regionales lol
Jo
