nocif13
Table de ressorts et huile / Spring and oil chart
154 posts in this topic
est ce que quelqu'un connaîtrait s'il vous plait les équivalences entre de l'huile Muchmore et Yokomo et les CST réels mesurés s'il vous plait?
Nico'
#308372 Progressive Spring Set
• New progressive springs 2.2–2.6
• 2.2 soft at the beginning, firmer in middle, 2.6 hard at end
• Black color
• Laser engraved for easy identification
• Sold as a pair
• Individually measured, controlled, inspected and matched to provide identical damping characteristics
• Perfect spring match-ups
• Gives your car predictability and consistency
show.php?img_id=69029&crt=1eed34047b6aa5c47dc0a2a7d7ccf498
Salut.
Les ressorts HPI qui vont bien, c'est les références pour Pro4 ou les nouvelles ?
Pour les blancs, les roses et les bleus, j'ai deux références différentes et des duretés différentes ... Merci.
Key Features
Low Frequency - Allow for a plush feel on the track with more grip and consistency
Full Set Included - All five of the Low Frequency Springs available for the 22 platform for the rear will be available in this single package for easy tuning
Paint Markings - Each spring is marked with a paint swatch at the end of the spring for easy identification
Black Oxide Finish - The black oxide finish works as protection from corrosion and also make the springs easily identifiable against the original 22 springs which have black paint
TLR233012
The Low Frequency Spring Sets allow for a more plush suspension feel with increased grip and more stability. The four included springs are only separated by .12 lbs/in increments allowing for very fine tuning to get your 22 vehicle dialed in. The lower frequency springs also land better allowing for a mellow rebound as the car settles quicker and more consistently.
Springs included in order from softest to stiffest:
Pink 2.86 lbs./in 9.25 coils
Red 2.96 lbs./in 9.00 coils
Orange 3.03 lbs./in 8.75 coils
Silver 3.18 lbs./in 8.50 coils
TLR233013
The Low Frequency Spring Sets allow for a more plush suspension feel with increased grip and more stability. The five included springs are only separated by .05 lbs/in increments allowing for very fine tuning to get your 22 vehicle dialed in. The lower frequency springs also land better allowing for a mellow rebound as the car settles quicker and more consistently.
Grey 1.96 lbs./in 12.50 coils
White 2.02 lbs./in 12.25 coils
Yellow 2.06 lbs./in 12.00 coils
Pink 2.11 lbs./in 11.75 coils
Red 2.16 lbs./in 11.50 coils
Merci arn0, elles sont bien utiles tes mises à jours.
Nico'
Si cela peut t'aider. Tu as Muchmore en haut du tableau
Je dois être bête, mais où se trouve le lien du tableau ? J'ai beau chercher en 1ere page je ne trouve pas. Merci d'avance
Je suis a la recherche de concordance entre ressorts big bore associated et kyosho.
Damien
Une vrai machine cet Arnaud!
Petite question du débutant : est ce que les huiles d'une même marque/gamme sont miscibles?
Je m'explique : si j'ai en ma possession une huile 30 et une de 50, est ce que j'obtiens une huile de 40 en mélangeant 1 dose de 30 et 1 dose de 50?
Merci.
Oui, Oui, c'est miscible dans la mesure ou tu prends la même marque, tu n'auras pas de disparité.
En respectant les proportions, tu obtiens le grade désiré.
50% de 30wt + 50% de 50wt = 40wt
Je le fais souvent.
Comment avec deux viscosités différente on peux obtenir un mélange parfait ?
C juste impossible.
C juste impossible.
si c'est toujours possible sous réserve que tes 2 huiles soient miscibles et que tu respectes les lois de mélanges...
Apres... si t'as de la 24Wt au lieu de la 23WT... est-ce que ca va changer qqchose???? est-ce que tu va réellement le sentir...???
20mm Big Bore Shock Spring Set for 1/10 Touring Car
Ma question, pour plus de motricité, l huile doit etre plus fluide ou plus visqueuse en TT
Salut Marc,
Parles-tu de l'huile pour les amortisseurs ou de l'huile/graisse du différentiel?
Huile amortisseurs. "Plus vite le transfert de masse se fait plus ca motrice" c est vrai ca? donc il faut mettre de l huile fluide.
Petite question, pourquoi en TT 4X2 les rssorts avant sont plus dure ques les AR.
