2008 1/12th & 1/10th ISTC World Championship
383 posts in this topic
Pour les championnats du monde, il y a quelques changements dans le réglement
4.2 BATTERIES APPROVAL
4.2.1 The deadline date for submitting batteries (cells) to be approved for that year's World Championship is eight (8) months prior to the date of the Opening Ceremony of the World Championship. Applications for approval must be submitted to IFMAR.
The submittal for approval must contain a written technical specification from the original cell manufacturer for verification;
which must include: - dimensions and weights with associated tolerances.
Samples submitted are required to closely represent the weight range stated.
A minimum of 50,000 individual cells must have been sold (by the original
manufacturer or their agents) to commercial outlets in the retail or distribution sector of the hobby industry. Approval may be requested by the original manufacturer or their agents.
The submittal for approval must conform to the procedure current at the time for IFMAR approval - copies available on request.
4.3 MOTORS
4.3.2 An approved products list of motors approved for use in the World Championships must be posted on the IFMAR website and the organizer’s website (if available) four (4) months prior to the event and the list shall be included in the race acknowledgement package sent to each competitor no later than two (2) months prior to the event.
BRUSHED MOTORS
Specifications: ‘05’ sized displacements.
Can diameter to be a maximum of 36.02mm
Can length to be Maximum of 53mm measured from the mounting face of the motor to the furthest point not including solder, tabs or lead wires. Shaft diameter is .125 inch. Production Tolerances allowed. Ceramic magnets only (cobalt and rare earth magnets specifically not allowed).
Current is supplied to the armature by 2 brushes.
Armature - The rotor is to have three poles with windings. Stack length without epoxy - minimum 21mm and maximum is 22.8mm. Only Copper wire is to be used for the winding.
No Split rotor is allowed. The laminations have to be one after the other without anything between. The thickness of the stack plates is 0.35mm + 0.05mm, a maximum of 63 laminations to be used. The minimum stack thickness is 3.5mm.
The armature has to be permanently marked by the manufacturer, detailing the number of ‘winds’ and the name of the manufacturer.
A minimum of 5,000 units must be available at the time of approval. A minimum of three hundred (300) motors must have been sold to at least three (3) distributors or hobby shops or OEM’s at the time of submittal. The manufacturer has to provide an address of a hobby shop or the like, that any driver who wishes to obtain these motors at the time of approval can do so.
Approved motors may be modified by re-winding, balancing, truing of commutators, epoxying, ball bearings, brushes and custom brush systems only.
No hybrid (mixing of parts from approved motors) allowed.
BRUSHLESS MOTORS:
General definition of a Brushless Motor:
a) Sensored or sensorless motors are allowed.
B)
The motor has to be rebuildable. Ball bearings are allowed.
c) If the motor is sensored:
- It must use a six position JST ZH connector model number ZHR-6 or equivalent connector with 6 JST part number SZH-002T-P0.5 26-28 awg contacts or equivalent.
Wire sequence must be as follows:
Pin #1 - Black wire ground potential
Pin #2 - orange wire phase C
Pin #3 - white wire phase B
Pin #4 - green wire phase A
Pin #5 - blue wire temp control, 10 k Thermistor referenced to ground potential
Pin #6 - red wire + 5.0 volts d.c. +/- 10%.
Compatible speed control must use the 6 position JST header part number
X-6B-ZR-SMX-TF (where the X denotes the style of the header), or equivalent.
- The power connector has to be clearly marked A, B, C.
A for phase A
B for phase B
C for phase C
d) `05` size specifications
Can:
Overall maximum diameter is 36.02mm measured at whatever point yields the
maximum dimension, excluding solder tabs or lead wires. Overall minimum
diameter is 34.00mm measured at whatever point yields the minimum dimension, excluding solder tabs or lead wires. Maximum length is 53.00mm measured from the mounting face of the motor to the furthest most point of the end bell, not including solder tabs, lead wires or original manufacturer’s logo or name.
Minimum length is 50.00mm measured from the mounting face of the motor to the furthest most point of the end bell, not including solder tabs, lead wires or original manufacturer’s logo or name. Motor mounting holes must be on 1.00- inch (25.40mm) centres.
Stack/Stator:
The Stack or Backiron must be continuous. The laminations have to be one after the other without anything in between. Stack/Backiron minimum length 19.30mm, maximum 21.00mm. The thickness of the Stack/Backiron IFMAR 1/12TH & 1/10TH ISTC ELECTRIC ON-ROAD WC RULES
14 laminations is 0.35+/-0.05 mm. All laminations must be of the same material. Inside diameter of Stack or Windings equals the central space between the laminations or assembly of windings and must accept ‘plug’ gauges of 12.5 mm minimum, 16.0 mm maximum. These dimensions to be measured with the centre of the ‘plug’ gauge in-line with the centre of the motor Can. (i.e. Concentric to can).
Winding:
Delta and Y wound stators are permitted..
Only circular (round) pure copper wire permitted. No turn limit.
Rotor:
Shaft diameter must be 0.125 inches (3.175mm). Only one piece, two pole Neodymium or Ferrite magnetic rotors are permitted. Magnet minimum length 23.00mm, maximum 27.00mm. Magnet minimum diameter 12.00mm, maximum 15.50mm.
e) All motors must have the original manufacturer’s logo or name moulded into the end bell.
f) A minimum of two thousand (2000) brushless motors must be available at the time of approval. A minimum of three hundred (300) brushless motors must have been sold to at least three (3) distributors or hobby shops or OEM’s at the time of submittal. The manufacturer has to provide an address of a hobby shop or the like, that any driver who wishes to obtain these motors at the time of the approval can do so. No hybrid (mixing of parts from approved brushless motors) allowed.
5.1.14 DIMENSIONS
5.1.22.b When racing on a track surface which can be damaged (e.g. carpet) a minimum ground clearance of 3mm must be maintained at all times (
excluding Spur gears for 1/12th cars
SECTION SIX - TECHNICAL RULES 1/10th ISTC
6.0 PURPOSE
The essence of the 1/10th ISTC class is competition between realistic models of saloon/sedan cars raced in Touring Car Series for Class Two FIA Touring Cars.
All Cars must comply with the ISTC Technical Rules to be eligible to race in Timed Practice, Qualifying and Finals.
Bodies must be a 1:10 scale in character reproduction of touring car (sedan) 2 and 4-door vehicles that exist ore have exist, and raced in international Touring Car series
For homologation purposes, the bodies dimensions will be checked according the Global Body Specifications.
Bodies may be homologated by ROAR, EFRA, FEMCA or FAMAR up to four (4) months before the event.
This combined list will be made available by IFMAR to the organizer for inclusion in the Stage II Report. For technical inspection it is necessary that all body shells on the list can be identified by means of a manufacturer’s and/or homologation number issued by a Bloc. This number must be molded in at the right upper edge of the windscreen
http://www.ifmar.org/
Number Name Last Name Country Car Team
1 Krits Premprasert thailand HB cyclone RCS
2 Ryan Lee Korea Xray Muchmore
3 Jarb Ratanarat Thailand TRF416 Thailand
4 Surikarn Chaidajsuriya THailand HB HB
5 Chatpong Kunakornkasem thailand HB CYCLONE Hotbodies
6 Simon Nicholson Australia corally
7 Justin Vergunst Australia Corally
8 Charlee Phutiyotin THA XRAY PRC
9 Chavit Saligupta THA XRAY PRC
10 Meen Vejrak THA XRAY XRAY PRC
11 Rungtawan Sriyuak THA XRAY PRC
12 Watchararit Tanasansittikon THA XRAY PRC
13 Tanit Kachchapananda Thailand Associated TC5 Asso Novak
14 Tanon Wigromlert Thailand HB Cyclone RC Intel
15 Paphon Chanyasak Thailand Tamiya TRF-416 Futaba,Speed Pasion
16 Suchart Boonpipat Thailand XRAY T2 008 40.825 40.695 4381401
17 Shin Adachi Japan KYOSHO KYOSHO
18 Andy Moore UK Cyclone HB
19 Atsushi Hara Japan CycloneTC Hot Bodies
20 Tanit Kachchapananda Thailand Associated TC5 Team Associated
21 Rapeepat Thai TRF AJ Tamiya
22 Jilles Groskamp The Netherlands Tamiya 416 Tamiya
23 Takashi Kato Japan YOKOMO YOKOMO
24 Hupo Hönigl Austria TRF 416 TAMIYA
25 Hayato Matsuzaki Japan HB CYCLONE TC Hot bodies
26 Yoshifumi Takao Japan HB CYCLONE TC Hot bodies
27 Daisuke Yoshioka Japan HB CYCLONE TC Hot bodies
28 Eung-Chan Kim Korea Yokomo Yokomo/Muchmore
29 max Park s.korea xray xray
30 Bart Wubben Holland S400 Serpent
31 Kay Yang Korea AVID Robitronic
32 Kay Yang Korea AVID Robitronic
33 Teepita boonsut THA TRF 416
34 Santirat P. Thailand Tamiya Hobby Extreme-RCS
35 pinsant jirapinyo Thailand t2008 xray
36 Suwich Vataniyapramote Thailand XRAY T2008 XRAY
37 Yuichiro Takaya Philippines TRF416
C'est cette fin de semaine que ce déroule la course préparatoire.
Liste des inscrits ce jour! Noter la présence d'un français.
1 Eung-Chan Kim Korea Yokomo Yokomo/Muchmore
2 max Park s.korea xray
3 Bart Wubben Holland S400 Serpent
4 Kay Yang Korea AVID Robitronic
5 Teepita boonsut THA TRF 416
6 Santirat P. Thailand Tamiya Hobby Extreme-RCS
7 pinsant jirapinyo Thailand t2008 xray
8 Suwich Vataniyapramote Thailand XRAY T2008
9 Yuichiro Takaya Philippines TRF416
10 marc rheinard germany tamiya 416 tamiya
11 leungwai hongkong HB speed passion
12 jihun yoo korea yokomo muchmore
13 Viktor Wilck Sweden Tamiya TRF 416 TRF, SpeedPassion
14 Masami Hirosaka Japan YOKOMO YOKOMO
15 NAOTO MATSUKURA JAPAN YOKOMO YOKOMO
16 TAKESHI YOKOYAMA JAPAN YOKOMO YOKOMO
17 Luc Botton Australia Schumacher MI3 Pattaya
18 Ludovic Leflon France Avid
19 Hideo Kitazawa Japan TRF416 Futaba SpeedPassion
20 Katar khumtathep Thailand Xray CDR
21 VITOON MINGKAMONKUN THAILAND CYCLONE BE HOBBY
22 Padungkiat Kongsomporn Thailand HB Cyclone RCS & BeHobby
23 Karn Ngeanphisutsilp Thailand HB RCS Be hobby
24 SATOSHI MAEZUMI JAPAN TRF416 TRF
25 Mongkhonphan Lomrose Thailand HB RCS DSM
26 Chattham Pomnork Thailand Tamiya TRF 416
27 Ongsanit S. Thailand XRAY T2 008 BE HOBBY
28 Thavit S. Thailand XRAY T2 008 PRC
29 Krits Premprasert thailand HB cyclone RCS
30 Ryan Lee Korea Xray Muchmore
31 Jarb Ratanarat Thailand TRF416 Thailand
32 Surikarn Chaidajsuriya THailand HB HB
33 Chatpong Kunakornkasem thailand HB CYCLONE Hotbodies
34 Simon Nicholson Australia corally
35 Justin Vergunst Australia Corally
36 Charlee Phutiyotin THA XRAY PRC
37 Chavit Saligupta THA XRAY PRC
38 Meen Vejrak THA XRAY XRAY PRC
39 Rungtawan Sriyuak THA XRAY PRC 2.4GHz
40 Watchararit Tanasansittikon THA XRAY PRC
41 Tanon Wigromlert Thailand HB Cyclone
42 Paphon Chanyasak Thailand Tamiya TRF-416 Futaba,Speed Pasion
43 Suchart Boonpipat Thailand XRAY T2 008
44 Shin Adachi Japan KYOSHO KYOSHO
45 Andy Moore UK Cyclone HB
46 Atsushi Hara Japan CycloneTC Hot Bodies
47 Tanit Kachchapananda Thailand Associated TC5 Associated Novak Spintec
48 Rapeepat Thai TRF AJ Tamiya
49 Jilles Groskamp The Netherlands Tamiya 416 Tamiya
50 Takashi Kato Japan YOKOMO YOKOMO
51 Hupo Hönigl Austria TRF 416 TAMIYA
52 Hayato Matsuzaki Japan HB CYCLONE TC Hot bodies
53 Yoshifumi Takao Japan HB CYCLONE TC Hot bodies
54 Daisuke Yoshioka Japan HB CYCLONE TC Hot bodies
55 siri nawasakulthananon Thailand t2008 9vut, Son's Hobby
56 Ongsanit Simaraka thailand Xray T2 2008 Maxima Behobby Orion
il est meme sur ce forum dans la section robitronic le francais en question
http://www.thailandwc08.com/pre-world08/result/Control-1.html
Pos No. Name Max. Laps Total Tm Nationality ID. No.
1 1 ATSUSHI HARA 19 5:00.813 JAPAN
2 3 VIKTOR WILCK 19 5:04.595 SWEDEN
3 3 HAYATO MATSUZAKI 19 5:06.457 JAPAN
4 9 MEEN VEJRAK 19 5:07.053 THAI
5 4 KIM EUNG-CHAN 19 5:07.095 KOREA
6 2 BILLY EASTON 19 5:07.345 USA
7 8 JILLES GROSKAMP 19 5:07.394 THE NETHERLANDS
8 10 HUPO HONIGL 19 5:07.599 AUSTRIA
9 5 MASAMI HIROSAKA 19 5:07.664 JAPAN
10 4 MARC RHEINARD 19 5:08.225 GERMAN
11 6 NAOTO MATUKURA 19 5:09.334 JAPAN
12 7 SURIKARN C. 19 5:09.610 THAI
13 5 DAISUKE YOSHIOKA 19 5:10.684 JAPAN
14 8 PAPHON C. 19 5:13.090 THAI
15 3 SIMON NICHOLSON 19 5:15.198 AUSTRALIA
16 1 BART WUBBEN 19 5:15.410 THE NETHERLANDS
17 4 HIDEO KITAZAWA 19 5:15.966 JAPAN
18 2 JIHUN YOO 19 5:16.165 KOREA
19 8 TANIT K. 19 5:16.949 THAI
20 3 YOSHIFUMI TAKAO 18 5:02.628 JAPAN
21 6 CHARLEE P. 18 5:03.897 THAI
22 6 CHATPONG K. 18 5:03.969 THAI
23 7 PORAPONG R. 18 5:05.239 THAI
24 5 SATOSHI MAEZUMI 18 5:09.302 JAPAN
25 8 LEUNG WAI 18 5:13.682 HONGKONG
26 10 RYAN LEE 18 5:14.463 KOREA
27 1 CHATTHAM P. 18 5:16.963 THAI
28 5 PINSANT J. 17 4:53.761 THAI
29 9 SIRI N. 17 5:00.793 THAI
30 6 MONGKOLPHAN R. 17 5:00.814 THAI
31 4 KRIST P. 17 5:03.147 THAI
32 10 JUSTIN VERGUNST 17 5:03.808 AUSTRALIA
33 2 SUCHART B. 17 5:04.730 THAI
34 8 RUNGTAWAN S. 17 5:05.294 THAI
35 2 SANTIRAT P. 17 5:06.474 THAI
36 2 TANON W. 17 5:16.707 THAI
37 7 LUDOVIC LEFLON 16 5:04.869 FRANCE
38 2 ANDY MOORE 14 3:45.757 UK
39 7 TAKASHI KATO 12 3:19.773 JAPAN
40 3 CHAVIT S. 8 2:32.594 THAI
41 9 LUC BOTTON 6 1:43.086 AUSTRALIA
42 1 SHINNOSUKE ADACHI 5 1:19.486 JAPAN
43 10 PADUNGKIAT K. 0 0.000 THAI
44 7 ONGSANIT S. 0 0.000 THAI
45 4 KATAR K. 0 -.--- THAI
46 3 TEEPITA B. 0 -.--- THAI
47 1 RAPEEPAT P. 0 -.--- THAI
48 5 MAX PARK 0 -.--- KOREA
49 4 KAY YANG 0 -.--- KOREA
50 1 VITOON M. 0 -.--- THAI
51 10 KARN N. 0 -.--- THAI
52 9 YUICHIRO TAKAYA 0 -.--- JAPAN
53 6 SUWICH V. 0 -.--- THAI
54 9 TAKESHI YOKOYAMA 0 -.--- JAPAN
WARM UP WORLD CHAMPIONSHIP 2008
Merged Runs: Control #2
2 1 SHINNOSUKE ADACHI 19 5:04.476 JAPAN
3 3 VIKTOR WILCK 19 5:04.595 SWEDEN
4 4 MARC RHEINARD 19 5:05.146 GERMAN
5 5 MASAMI HIROSAKA 19 5:06.269 JAPAN
6 3 HAYATO MATSUZAKI 19 5:06.457 JAPAN
7 9 MEEN VEJRAK 19 5:07.053 THAI
8 4 KIM EUNG-CHAN 19 5:07.095 KOREA
9 2 BILLY EASTON 19 5:07.345 USA
10 8 JILLES GROSKAMP 19 5:07.394 THE NETHERLANDS
11 7 SURIKARN C. 19 5:07.475 THAI
12 10 HUPO HONIGL 19 5:07.599 AUSTRIA
13 6 NAOTO MATUKURA 19 5:09.334 JAPAN
14 5 DAISUKE YOSHIOKA 19 5:10.684 JAPAN
15 4 HIDEO KITAZAWA 19 5:11.441 JAPAN
16 8 PAPHON C. 19 5:13.090 THAI
17 1 BART WUBBEN 19 5:13.934 THE NETHERLANDS
18 7 PORAPONG R. 19 5:14.749 THAI
19 3 SIMON NICHOLSON 19 5:15.198 AUSTRALIA
20 2 JIHUN YOO 19 5:16.165 KOREA
21 8 TANIT K. 19 5:16.949 THAI
22 6 CHARLEE P. 18 5:00.708 THAI
23 7 TAKASHI KATO 18 5:01.948 JAPAN
24 3 YOSHIFUMI TAKAO 18 5:02.628 JAPAN
25 6 CHATPONG K. 18 5:03.969 THAI
26 10 RYAN LEE 18 5:04.419 KOREA
27 8 LEUNG WAI 18 5:05.381 HONGKONG
28 5 SATOSHI MAEZUMI 18 5:05.437 JAPAN
29 10 PADUNGKIAT K. 18 5:11.228 THAI
30 6 MONGKOLPHAN R. 18 5:11.301 THAI
31 1 CHATTHAM P. 18 5:13.271 THAI
32 5 PINSANT J. 18 5:15.361 THAI
33 4 KRIST P. 17 5:00.170 THAI
34 9 SIRI N. 17 5:00.793 THAI
35 2 SANTIRAT P. 17 5:03.587 THAI
36 10 JUSTIN VERGUNST 17 5:03.808 AUSTRALIA
37 7 ONGSANIT S. 17 5:04.245 THAI
38 2 SUCHART B. 17 5:04.730 THAI
39 8 RUNGTAWAN S. 17 5:05.294 THAI
40 3 CHAVIT S. 17 5:12.879 THAI
41 2 TANON W. 17 5:16.707 THAI
42 7 LUDOVIC LEFLON 16 5:04.869 FRANCE
43 2 ANDY MOORE 14 3:45.757 UK
44 9 LUC BOTTON 6 1:43.086 AUSTRALIA
Round 1 of qualifying is complete. Very close up front. Top heat was within .10ths during the entire run. Viktor Wilck continued his great performance of 2008 with a great first round. Here are the top 10
VIKTOR WILCK 19 5:03.6
MARC RHEINARD 19 5:03.8
ATSUSHI HARA 19 5:04.0
MASAMI HIROSAKA 19 5:04.7
BILLY EASTON 19 5:07.2
HUPO HONIGL 19 5:07.4
KIM EUNG CHAN 19 5:07.7
JILLES GROSKAMP 19 5:08.1
MEEN VEJRAK 19 5:08.8
THEN IT IS
SURIKARN
DAISUKE YOSHIOKA
SHIN ADACHI
BART WUBBEN
ANDY MOORE
Weather is changing a bit. Gone is the sunshine that shined on us this morning, now it is cloudy and overcast so everyone is focused on getting in the best runs they can while the weather is cooperating.
More at the end of the 2nd round.
Thanks,
Scotty
RC Tech
de nombreuses equipes sont assez degoutees (surtout xray qui etait venu en nombre au titc et avait joue les prolongations) car la piste a ete non seulement refaite avec un nouveau trace, mais aussi entierement resurfacee.. donc bcp de reglages a revoir car ces derniers mois, elle avait tendance a devenir tres savonette.
shopufo a fait pas moins de 45 carros pour cette course :)
http://www.thailandwc08.com/pre-world08/result/q1-5%20result%20by%20point.html
Pos Name Nationality Car Model Q1 Q2 Q3 Q4 Q5 BEST 3 Laps Total Tm BestTm Laps Total Tm BestTm Laps Total Tm BestTm Laps Total Tm BestTm Laps Total Tm BestTm
1 VIKTOR WILCK SWEDEN TAMIYA TRF 416 155 149 153 113 155 463 Q1 19 05:03.699 15.697 Q2 19 05:10.017 16.082 Q3 19 05:05.202 15.817 Q4 5 01:27.242 15.564 Q5 19 05:00.687 15.558
2 MARC RHEINARD GERMAN TAMIYA TRF 416 153 113 155 155 111 463 Q1 19 05:03.836 15.764 Q2 10 02:44.042 16.255 Q3 19 05:05.160 15.763 Q4 19 05:00.910 15.443 Q5 13 03:42.869 15.890
3 ATSUSHI HARA JAPAN HB CYCLONE 152 155 139 153 153 461 Q1 19 05:04.092 15.773 Q2 19 05:05.877 15.928 Q3 18 04:48.695 15.824 Q4 19 05:02.872 15.758 Q5 19 05:01.319 15.464
4 HAYATO MATSUZAKI JAPAN HB CYCLONE 150 144 152 151 132 453 Q1 19 05:06.768 15.809 Q2 19 05:13.519 15.891 Q3 19 05:08.547 16.073 Q4 19 05:05.239 15.761 Q5 18 05:02.700 15.872
5 MASAMI HIROSAKA JAPAN YOKOMO BD 151 151 149 150 151 453 Q1 19 05:04.770 15.787 Q2 19 05:08.805 16.072 Q3 19 05:10.900 16.149 Q4 19 05:05.262 15.749 Q5 19 05:06.390 15.698
6 JILLES GROSKAMP THE NETHERLANDS TAMIYA TRF 416 146 153 138 152 138 451 Q1 19 05:08.171 15.847 Q2 19 05:08.530 15.993 Q3 18 04:51.663 15.982 Q4 19 05:03.819 15.777 Q5 19 05:14.157 15.921
7 BILLY EASTON USA SERPENT S400 149 152 143 146 150 451 Q1 19 05:07.205 15.955 Q2 19 05:08.784 16.016 Q3 19 05:14.216 15.947 Q4 19 05:05.940 15.895 Q5 19 05:06.480 15.634
8 HUPO HONIGL AUSTRIA TAMIYA TRF 416 148 146 147 149 152 449 Q1 19 05:07.428 15.800 Q2 19 05:12.950 16.054 Q3 19 05:11.394 16.071 Q4 19 05:05.583 15.901 Q5 19 05:05.204 15.944
9 SURIKARN C. THAI HB CYCLONE 144 150 148 145 147 445 Q1 19 05:09.481 15.991 Q2 19 05:09.495 15.942 Q3 19 05:10.949 16.097 Q4 19 05:08.471 15.995 Q5 19 05:08.644 15.980
10 MEEN VEJRAK THAI X-RAY T2' 008 145 148 144 148 149 445 Q1 19 05:08.873 16.067 Q2 19 05:11.408 16.237 Q3 19 05:11.849 16.104 Q4 19 05:05.725 15.764 Q5 19 05:07.400 15.885
11 DAISUKE YOSHIOKA JAPAN HB CYCLONE 143 145 151 144 146 442 Q1 19 05:12.232 16.126 Q2 19 05:13.067 16.113 Q3 19 05:10.615 15.965 Q4 19 05:10.154 15.856 Q5 19 05:09.804 15.845
12 ANDY MOORE UK HB CYCLONE 140 141 150 136 148 439 Q1 19 05:13.437 16.208 Q2 19 05:22.178 16.024 Q3 19 05:10.664 16.183 Q4 19 05:16.556 16.447 Q5 19 05:08.180 16.050
13 KIM EUNG-CHAN KOREA YOKOMO BD 147 147 145 143 144 439 Q1 19 05:07.783 15.968 Q2 19 05:12.117 16.164 Q3 19 05:11.806 16.195 Q4 19 05:10.194 15.584 Q5 19 05:10.753 15.797
14 SHINNOSUKE ADACHI JAPAN KYOSHO TF 5 STALLION 142 143 146 147 140 436 Q1 19 05:12.591 15.918 Q2 19 05:15.711 16.253 Q3 19 05:11.474 16.064 Q4 19 05:05.726 15.676 Q5 19 05:13.817 15.866
15 TAKASHI KATO JAPAN YOKOMO BD 127 142 141 141 141 424 Q1 18 05:11.770 16.302 Q2 19 05:16.321 16.430 Q3 19 05:16.197 16.372 Q4 19 05:12.080 16.203 Q5 19 05:13.204 16.180
16 BART WUBBEN THE NETHERLANDS SERPENT S400 141 139 135 139 143 423 Q1 19 05:13.251 16.125 Q2 18 05:01.946 16.301 Q3 18 05:02.595 16.189 Q4 19 05:13.820 15.726 Q5 19 05:11.858 15.984
17 JIHUN YOO KOREA YOKOMO BD 133 135 142 142 136 420 Q1 18 05:05.617 16.280 Q2 18 05:10.401 16.710 Q3 19 05:14.968 16.451 Q4 19 05:11.246 16.064 Q5 19 05:14.492 16.159
18 SIMON NICHOLSON AUSTRALIA CORALLY 134 136 120 138 145 419 Q1 18 05:02.143 16.429 Q2 18 05:07.809 16.782 Q3 17 05:03.902 16.548 Q4 19 05:14.242 16.048 Q5 19 05:10.208 15.841
19 TANIT K. THAI ASSOCIATED TC 5 126 140 133 137 142 419 Q1 18 05:13.756 16.572 Q2 18 05:01.081 16.595 Q3 18 05:05.809 16.384 Q4 19 05:16.514 16.235 Q5 19 05:12.984 16.198
20 HIDEO KITAZAWA JAPAN TAMIYA TRF 416 139 127 137 140 137 416 Q1 19 05:14.546 16.305 Q2 17 04:44.728 16.618 Q3 18 04:57.670 16.277 Q4 19 05:12.842 16.169 Q5 19 05:14.336 16.196
21 YOSHIFUMI TAKAO JAPAN HB CYCLONE 138 138 140 133 133 416 Q1 18 05:00.037 16.286 Q2 18 05:04.225 16.517 Q3 19 05:18.931 16.369 Q4 18 05:07.781 16.616 Q5 18 05:00.415 16.422
22 SATOSHI MAEZUMI JAPAN TAMIYA TRF 416 136 132 136 131 139 411 Q1 18 05:00.598 16.409 Q2 18 05:12.182 16.628 Q3 18 05:01.105 16.262 Q4 18 05:08.391 16.197 Q5 19 05:13.821 16.271
23 CHARLEE P. THAI X-RAY T2' 008 135 137 122 124 134 406 Q1 18 05:01.464 16.531 Q2 18 05:05.017 16.459 Q3 18 05:18.637 16.517 Q4 17 05:03.828 16.354 Q5 19 05:16.510 16.341
24 RYAN LEE KOREA X-RAY T2' 008 128 131 134 135 130 400 Q1 18 05:11.540 16.676 Q2 18 05:13.347 16.897 Q3 18 05:03.948 16.614 Q4 18 05:02.376 16.337 Q5 18 05:04.355 16.294
25 LEUNG WAI HONGKONG HB CYCLONE 125 133 131 134 131 398 Q1 18 05:14.588 16.472 Q2 18 05:11.634 16.813 Q3 18 05:08.608 16.635 Q4 18 05:04.843 16.488 Q5 18 05:03.050 16.448
26 PINSANT J. THAI X-RAY T2' 008 110 110 128 132 129 389 Q1 13 03:49.243 16.696 Q2 7 02:16.004 16.835 Q3 18 05:12.826 16.904 Q4 18 05:08.266 16.595 Q5 18 05:05.059 16.480
27 PAPHON C. THAI TAMIYA TRF 416 137 121 130 111 121 388 Q1 18 05:00.445 16.299 Q2 17 05:06.936 16.454 Q3 18 05:09.456 16.497 Q4 2 34:33.600 16.472 Q5 17 04:56.854 16.100
28 CHATPONG K. THAI HB CYCLONE 132 112 125 127 128 387 Q1 18 05:06.575 16.694 Q2 7 02:00.978 16.755 Q3 18 05:17.204 16.632 Q4 18 05:16.080 16.695 Q5 18 05:05.898 16.558
29 PADUNGKIAT K. THAI HB CYCLONE 131 126 129 125 126 386 Q1 18 05:08.762 16.536 Q2 17 05:00.978 16.914 Q3 18 05:10.596 16.703 Q4 17 05:00.837 16.578 Q5 18 05:09.483 16.302
30 LUC BOTTON AUSTRALIA X-RAY T2' 008 130 128 112 128 127 386 Q1 18 05:09.958 16.828 Q2 18 05:20.071 17.016 Q3 13 03:51.111 17.026 Q4 18 05:15.600 16.904 Q5 18 05:08.594 16.765
31 SIRI N. THAI X-RAY T2' 008 129 134 116 119 110 382 Q1 18 05:10.386 16.821 Q2 18 05:11.425 16.871 Q3 16 04:39.462 16.807 Q4 16 04:39.610 16.571 Q5 13 04:04.679 16.967
32 SUCHART B. THAI X-RAY T2' 008 124 125 127 129 116 381 Q1 18 05:15.952 16.833 Q2 17 05:02.272 17.183 Q3 18 05:16.085 17.047 Q4 18 05:15.450 16.918 Q5 17 05:05.432 16.795
33 CHATTHAM P. THAI HB CYCLONE 119 111 126 130 124 380 Q1 17 05:04.353 16.784 Q2 7 02:02.198 16.956 Q3 18 05:16.175 16.903 Q4 18 05:11.412 16.906 Q5 18 05:12.598 16.583
34 JUSTIN VERGUNST AUSTRALIA CORALLY 123 130 111 115 125 378 Q1 18 05:20.588 17.250 Q2 18 05:15.214 17.057 Q3 9 02:36.369 17.036 Q4 9 02:36.188 16.925 Q5 18 05:11.514 16.760
35 ONGSANIT S. THAI X-RAY T2' 008 121 124 124 126 123 374 Q1 17 05:01.824 17.305 Q2 17 05:03.357 17.017 Q3 18 05:17.540 17.096 Q4 18 05:17.366 17.033 Q5 18 05:16.536 16.798
36 MONGKOLPHAN R. THAI HB CYCLONE 114 129 118 123 120 372 Q1 16 04:57.512 16.714 Q2 18 05:17.304 16.924 Q3 17 05:07.291 16.764 Q4 17 05:03.993 16.831 Q5 17 05:00.512 16.647
37 NAOTO MATUKURA JAPAN YOKOMO BD 118 118 115 114 135 371 Q1 17 05:07.414 15.956 Q2 16 05:02.710 16.425 Q3 16 05:06.272 16.171 Q4 8 02:21.793 16.249 Q5 19 05:15.383 16.025
38 PORAPONG R. THAI TAMIYA TRF 416 115 114 132 116 122 370 Q1 17 05:13.725 16.355 Q2 14 03:56.961 16.598 Q3 18 05:06.425 16.645 Q4 12 03:54.057 16.545 Q5 17 04:38.738 16.006
39 SANTIRAT P. THAI TAMIYA TRF 416 122 122 123 112 117 367 Q1 17 05:01.207 17.224 Q2 17 05:06.493 17.281 Q3 18 05:17.615 17.119 Q4 4 01:15.998 17.302 Q5 17 05:02.911 16.690
40 TANON W. THAI HB CYCLONE 116 123 119 121 118 363 Q1 17 05:09.201 17.267 Q2 17 05:06.129 17.309 Q3 17 05:04.648 17.068 Q4 17 05:10.442 17.325 Q5 17 05:00.949 16.945
41 KRIST P. THAI HB CYCLONE 111 119 110 122 119 360 Q1 16 05:23.744 17.223 Q2 17 05:33.926 16.996 Q3 7 02:12.934 17.968 Q4 17 05:06.582 17.397 Q5 17 05:00.589 17.041
42 CHAVIT S. THAI X-RAY T2' 008 117 117 121 120 112 358 Q1 17 05:08.807 17.279 Q2 16 05:08.918 17.382 Q3 17 05:03.108 17.416 Q4 17 05:11.720 17.339 Q5 15 05:04.965 17.261
43 RUNGTAWAN S. THAI X-RAY T2' 008 120 120 117 117 115 357 Q1 17 05:02.962 17.322 Q2 17 05:09.851 17.516 Q3 17 05:15.466 17.267 Q4 15 05:11.979 18.099 Q5 17 05:11.595 17.421
44 VITOON M. THAI HB CYCLONE 112 115 113 118 114 347 Q1 16 05:16.636 17.887 Q2 15 05:00.228 18.630 Q3 16 05:10.585 18.228 Q4 16 05:10.757 17.954 Q5 16 05:02.243 17.360
45 LUDOVIC LEFLON FRANCE AVID ROBITRONIC 113 116 114 113 343 Q1 16 05:05.627 18.021 Q2 16 05:17.648 18.573 Q3 16 05:06.859 18.120 Q4 0 -.--- -.--- Q5 16 05:07.549 18.335
Merged Runs: Main A Result
Pos No. Name Total Points Final 1 Final 2 Final 3
1 1 VIKTOR WILCK 20 8 10 10
2 2 MARC RHEINARD 18 9 9 9
3 5 MASAMI HIROSAKA 15 10 4 5
4 4 HAYATO MATSUZAKI 15 4 7 8
5 7 BILLY EASTON 15 7 8 2
6 6 JILLES GROSKAMP 13 5 6 7
7 9 SURIKARN C. 11 1 5 6
8 3 ATSUSHI HARA 8 6 2 1
9 10 MEEN VEJRAK 7 3 3 4
10 8 HUPO HONIGL 5 2 1 3
