Pneus JConcept TT 10e
42 posts in this topic
"Double Dees" unleashed - First Big race, first Big win.
JConcepts Racing Tires made their debut at the 2007 Nitro Challenge in Surprise, AZ. In the hotly contested 45 minute A-main event, Ryan Maifield made it a debut to remember by winning the Pro Gas Truck class A-main with his Associated GT2 running on JConcepts "Double Dees" tires in Sticky Green Compound.
In 1/8th scale buggy, Maifield also blitzed the track in Round 2 of qualifying with his Associated RC8 by laying down a TQ run using the 1/8th scale version of the "Double Dees". That qualifying run set panic throughout the pits forcing everyone to adjust their selections for round 3.
JConcepts driver Ryan Maifield stated:
"You can tell if a tire is going to work on the first lap and especially in 1/10th scale and gas truck in particular. While in the lead with 2 minutes to go when I heard the race announcer say I had my fastest lap in the entire 45 minute A-main, I was impressed!
JConcepts President Jason Ruona stated:
"I have been fascinated with R/C tires since I started racing in 1991. I've driven in 3-IFMAR Worlds A-main finals and been a Pro driver since 1994. Great drivers can make a lot of products look good; tires are not one of those products."
Although, the first major event for these tires, they have been under development for nearly a year. Rigorous testing by qualified drivers and designers make for ideal racing products. JConcepts - Will, Vision, Desire, Strength and Creativity.
JConcepts Racing Tires - Available Summer 2007
Photos Courtesy - Ultragraphics (Aaron Mathiason)
2.2” 2wd front buggy tire
Fits – Any 2.2” 2wd front buggy wheel
The JConcepts Groovy 2wd front tire is perfect for a variety of track surfaces.
The Groovy incorporates a compact tire body with sharp 4-rib separation for precise steering input and response.
Features:
Available in sticky Green compound
Compact tire body
Sharp 4-rib separation
Includes firm foam inserts
source: JConcept
New tires from JCONCEPTS, partner of the PETIT RC RACE 2007 at Paris
The JConcepts Rounder 2wd front tire is a great tuning compliment to any abrasive surface. The Rounder incorporates a compact tire body with rounded 4-rib separation for smooth steering input and response.
Features:
Compact tire body
Rounded 4-rib separation
PS : Après contact avec la firme, les jantes à batons devraient être dispo dans les deux semaines au plus tard sur leur site.
Tu parles de ça:
Rulux - 1/10th RC10B4 rear wheel
Spoke Wheel with JC imprint
4 pc per package
Available in White or Yellow
Fits B4, B44, and Losi XXX rear
Rulux - 1/10th RC10B4 front wheel
Spoked Wheel with JC logo imprint
4 pc per package
Available in white or yellow
Rulux - 1/10th B44 front wheel
Spoked Wheel with JC imprint
4 pc per package
Il y a aussi d'autres pneus:
Double Dee's - 4wd front, green - fits 2.2" 4wd front
Double Dee's - Green Compound - 2.2" buggy rear wheel
Double Dee's - 1/10th truck tire
Fits – Any 2.2” truck wheel
The JConcepts Double Dee’s rear tire is perfect for a variety of track surfaces. The especially unique Double Dee lug technology combined with the sticky green compound allow the flexibility necessary to compete on even the most demanding surfaces for an extended period of time. Double Dee’s are good to the last drop as the design allows even wear all the way down to the tire body.
The Double Dee’s incorporate a compact tire body with crisp tread and separation for intense racing.
Double Dee’s excel on outdoor hard packed clay surfaces with either dry or wet conditions. Double Dee’s are at their best when used on a surface with a blue grooved surface.
1/10th tire Features:
Compact tire body with crisp tread and separation
Aggressive square Double Dee lug technology
Includes firm And-1 foam inserts for 1/10th tires
The JConcepts Goose Bumps tire is just what the doctor ordered. The totally unique step pin and bar lug design combined with sticky compounds like yellow, blue and green allow even greater control on slightly loamy and wet conditions. The Goose Bumps are a special breed, designed for maximum performance when new or used as the design allows even wear all the way down to the tire body. Once the driver wears through the initial pin, a bar follows to maximize potential on aggressive surfaces.
The Goose Bumps incorporate a compact tire body with a crisp tread pattern with precise separation for intense racing competition.
Goose Bumps in new condition excel on soft surfaces with either dry or wet conditions. Worn Goose Bumps excel on indoor or outdoor clay tracks where a slight groove has formed.
· Available in sticky Green compound
· Compact tire body with crisp tread and precise separation
· Aggressive step pin and bar lug combination design
· Includes firm And-1 foam inserts for 1/10th tires
3023_450px.jpg?zenid=7df2c73bcb1cfd8add50603d44f370d0
Goose Bumps – Green Compound (fits 2.2” truck wheel)
JConcepts Goose Bumps for 1/10th Truck - packaged
JConcepts Racing Tires – Bar Codes
Bar Codes - Blue compound (fits 1/10th 2.2" buggy rear wheel) Part # - 3016-01
The Code of Silence has been broken at JConcepts, and the Bar Codes are out. The Bar Code design is the freshest tire design seen in the last 10 years of racing development regardless of class and scale. Like the name suggests the alternating bar design combined with the addition of the Y side bars provide uncompromised support for blue and black groove conditions. Available in Blue and Orange compound the Bar Codes are a specialty tire that when matched to the appropriate track can provide amazing results.
The Bar Codes are a part of the JConcepts special breed of tire, designed for maximum performance when new or used as the design allows even wear all the way down to the tire body.
Bar Codes in new condition excel on hard surfaces that have taken rubber with either dry or wet grooved conditions. Worn Bar Codes excel on indoor or outdoor clay tracks where a minimal dust groove has formed.
Bar Codes Feature:
* Available in sticky Blue compound * Alternating “Bar Code” design with Y side bars * X - design interior carcass design for enhanced support * Includes JConcepts And-1 inserts
JConcepts Tire Compound Key:
Yellow = Medium - all conditions
White = Medium – groove conditions
Blue = Soft - all conditions
Orange = Soft – groove conditions
Green = Super Soft - all conditions
www.jconcepts.net
Bar Codes - now available in 3 compounds!
Les Bar Codes sont maintenant disponibles en Blue, White et Gold aussi bien pour les Buggys que les Trucks
The Bar Code Y-Bar design is the freshest tire design seen in the last 10 years of racing development regardless of class and scale. Like the name suggests the alternating bar design combined with the addition of the Y side bars provide uncompromised support for blue and black groove conditions. Available in a multitude of compounds the Bar Codes are a specialty tire that when matched to the appropriate track can provide amazing results.
Bar Codes Feature:
*Available in a variety of compounds to suit a multitude of surfaces and abrasion rates *Alternating “Bar Code” design with Y side bars *X - design interior carcass design for enhanced support *Includes JConcepts And-1 inserts *The Golden combination - JConcepts Tires
JConcepts Tires are golden, golden in performance and golden in compound. JConcepts color coded compounds are the standard for tire compound identification and JConcepts wants to keep you covered regardless of conditions. Did you know that there are also white, green, blue and yellow compounds?
Consider this – JConcepts Tires have been winning around the world. Since their release JConcepts Tires have won locally, nationally and taken the Pole Position at the IFMAR World Championships. Big time results = big time proof.
For best results follow the brief description of each compound and appropriate application.
Gold
is the newest compound arrival to JConcepts. Developed specifically for indoor clay surfaces the Gold compound has gotten rave reviews from drivers racing indoors around the world.
White
compound is specifically for outdoor racing where track and ambient temperatures are high. White is also a great tire compound when conditions are extremely abrasive and wear is critical.
Blue
compound is an all purpose compound that performs in all applications. Blue compound is soft and exceptional in dusty and low bite conditions where tire adhesion is most vital. Blue compound has excellent wear characteristics and is well suited to 1/8th off-road and 1/10th off-road.
3028 - Carvers - blue compound (fits 2.2" truck wheel)
Part # - 3028-01
(Fits 1/10th truck wheel)
The JConcepts Carvers 1/10th truck front tire is perfect for a variety of track surfaces. The sharp angular and directional ribs provide the ultimate in control and direction on the most common dry and wet condition surfaces. The compact tire body combined with the JConcepts firm foam inserts allow for precise steering input and response for the most consistent laps times available.
Carvers in new condition excel on low traction surfaces as well as high “loamy” traction wet surfaces where no rubber has been taken into the racing surface Worn Carvers excel on indoor or outdoor clay tracks where a light blue groove has formed.
Carvers Feature:
* Available in sticky soft Blue compound
* Compact tire body
* Sharp angular and directional ribs with precise separation
* Includes firm foam inserts
JConcepts
Do you find yourself Wondering when to run the various JConcepts tire compounds?
Here is a quick article written by Frank Root, JConcepts Team Driver
JConcepts has been making tires for a few years now, but we are growing all the time. In the past year, there have been 3 new compounds introduced, so I though I’d take a minute to share a little about each, and highlight the conditions for which each would be ideal.
Green - It is the softest of the JC compounds. It is the best for wet dirt. If is similar to M3, but will wear considerably longer. The Double Dees work great on packed surfaces with a little loam and Goosebumps really shine on the loamier tracks, even if they go a little dryer. Groovy and Rounder fronts in green work well in both conditions.
Blue - The medium-soft compound is the softest compound we have for 1/8 scales, and 2nd softest for 1/10. It works best for wet, loamy 1/8 conditions. The blue 1/10 tires are currently the Bar Codes, which work great on “Blue Groove” condition that don’t reach super high traction(little to no dust on hard packed dry dirt).
Gold - The indoor compound works great on any type of indoor dirt, but are awesome on clay. The tread does not barely wear, and has great grip. The tires also make for awesome slicks, if the track calls for it. The compound was tested and developed on tracks in the Northeast and even OCRC in CA.
Yellow - The harder of the 1/8 compounds, work great in many conditions. On any hard packed track, with loam on top or not, the yellows really hook up. You will also get great wear out of these tires because they are not sliding around with all the traction they create. The Yellow Crow Bow Combo (Crow Bar Fronts, Cross Bow Rears) in yellow is my 1/8 tires setup of choice at most tracks.
Orange - The newest compound to the JC line-up. Only for 1/10 as of now, Orange comes only the Bar Code tread. It was designed and tested for the highest traction “blue groove” conditions, like those seen at the Hot Rod Hobbies Off-Road Shootout and the Cactus Classis. They actually debuted at the Cactus Classic with Ryan Maifield winning 2wd and Truck Modified. Lee Martin, Kody Numendalh, Steven Hartson, and I all made at least one A-Main using the tires as well. They work very well, creating a bit more traction than some of the others without wearing faster.
White - The hardest of the 1/10 Compounds works great on the super high bite “blue groove” surfaces. I really prefer them on Truck and 2wd fronts, to complement Orange rears. The wear is exceptional, and it is the perfect balance of speed and ease of driving.
J'ai achetter des pneu Truck Jconcept carver et j'ai un doute sur le sens du collage sur la jante aurriez vous une photo ou pourriez vous me l'expliquer pour ceux qui on deja utiliser ces pneus svp ?
Flip Outs (fits 2.2″ buggy rear wheel)
It’s not just a name; it’s a driver’s reaction. Flip Outs are here, giving drivers that tire in-between the Goose Bumps and Double Dees they have asked for. A very small pin construction makes up the foundation for the Flip Outs design and gives the grip when racers need it most. When the conditions are wet and green in the morning, traction is sometimes hard to come-by; Flip Outs are the new choice.
Alternating center bar support provides the base for the forward traction while the small accommodating tapered pins provide the dig and flex under hard acceleration and cornering. Tire profile and interior ribbing design were all areas of focus while creating the combination of durability, functionality and performance.
Features:
Available in Super Soft Green compound
Aggressive alternating center bar support
Includes And-1 inserts
Profiled - 1/10th 4wd front insert - Firm - 2pc
Part # - 3202-1 (Fits all rear 2.2” 4wd front buggy tires)
Profiled - 1/10th 2wd front insert - Firm - 2pc
Part # - 3204-1 (Fits all rear 2.2” 2wd front buggy tires)
Profiled - 1/10th buggy rear insert - Firm - 2pc
Part # - 3206-1 (Fits all rear 2.2” rear buggy tires)
Tire inserts are one of the most critical aspects of 1/10th off-road racing. Racers have asked JConcepts for a firmer and more durable insert and after much deliberation the new JConcepts Profiled insert is ready. Having the insert with proper density for track conditions pays dividends to the racer and especially toward the end of races. Starting on too firm an insert, the driver feels “on edge” during the first run or subsequent runs on a set of inserts. Starting on too soft an insert, the driver’s vehicle is not responsive enough or runs the risk of too much insert breakdown during the tail end of a tires life which creates a squirmy or inconsistent feel. Having the feel that is just right requires a bit of balance of durability and hardness. To add to the construction and performance, JConcepts has added cut / grooves into the profile of the inserts to add an even greater driver to track feel. JConcepts is just right and always on target with the new Profiled insert.
JConcepts team driver Steven Hartson states “Jason introduced these new inserts to me for testing and I have been running them ever since. Straight out of the package they were the best accessory item for 1/10th off-road I have seen in years. I have re-used them several times in my gold compound Bar Codes that I use continually at indoor races and I have been the envy of fellow racers and competitors ever since.”
Features:
* Available for 1/10th buggy front, rear and 4wd front
* Superior firm density material and construction
* Ultra durable, no breakdown during racing
* Precise contoured manufacturing
* Insert longevity, can be reused
* Water resistant
* Dark blue color for easy identification
3054 Rips
Steering control and consistency is one of the most important aspects of 1/10th 2wd buggy racing. With the Rips front tire, JConcepts has optimized a 3 rib front tire design by altering the rib depth, attack angle and multiple radius corners to give 2wd racers a smooth new option. Tiny ribbing has been added on the upper sidewall to provide a fresh edge during hard and high impact corners. Already a high-performance tire the Rips in prototype form have been used to TQ at the Arizona State Championships and JConcepts Clash.
Features:
* Available in Soft (Blue), Super Soft (Green), and Indoor Soft (Gold) compounds.
* Compact tire body with optimized 3-rib design
* Sharp attack angle ribs with multiple radius corners
* Includes firm And-1 inserts
3033 - Bar Codes V2
The Code of Silence has been broken at JConcepts, and the Bar Codes V2 tires are out. The Bar Code design is the freshest new tire design from JConcepts racing development and regardless of class and scale the Bar Codes = top notch performance. Like the name suggests the alternating bar design combined with the addition of the Y side bars provide uncompromised support for blue and black groove conditions as well as wet track indoor conditions. Available in Soft, Super Soft and Indoor Soft compounds the Bar Codes are a specialty tire that when matched to the appropriate track can provide amazing results.
The Bar Codes are a part of the JConcepts special breed of tire, designed for maximum performance when new or used as the design allows even wear all the way down to the tire body. Bar Codes in new condition excel on hard surfaces that have taken rubber with either dry or wet grooved conditions. Worn Bar Codes excel on indoor or outdoor clay tracks where a minimal dust groove has formed.
JConcepts now has the ultimate 1, 2 punch by offering the V1 and V2 Bar Codes in a variety of compounds for tuning precision.
Features:
* Compact tire body with crisp tread and separation
* Aggressive Bar Code design
Je souhaiterais savoir si quelqu'un a essayé les pneus av JConcept:ref 3054 et3004 Voir si les trois levres sont un peut plus directive qu'avec deux.J'ai essayé les 3 levres en losi cela tire tout droit.
Y at il une réponse?
