Cyclone D4 (TT1/10 Hot Bodies)
125 posts in this topic
Oh le beau yok, heu pardon Bj ah mince non Hot-bodies, voilà j y suis arrivé!lol!
Option List
61493 Stabilizer 1.2mm (kappa) 300
Cyclone D4 option
1.4mm of cyclone D4 kit standard (silver) softer 1.2mm. The road surface where the gap is many and low it is grip road surface direction.
61525 High down fourth wing set (175mm) 720
Cyclone D4 option
From to the method which seeks down fourth. Intense down fourth is generated the normal wing compared to 15mm plus due to the wing area which is done to the side. 2 entering.
61530 Front one-way diff. 39T ¥3,800
Cyclone D4 option
By the fact that you exchange with the front ball diff. of kit standard, from quick steering wheel quality is actualized.
61526 Chassis protect seat 880
Cyclone D4 option
The base of the main chassis the chassis protect seat of the film type which is protected from the soiling and the scratch. Adjusting to the form of the chassis, because it can cut freely, it is enabled in the various models regardless of genre.
61452 Cup joint 6mm (2pcs) 800
Cyclone D4 spare (new part)
61420 Front gear box set 850
61421 Rear gear box set 900
61422 Front suspension arm set 600
61423 Rear suspension arm set 600
61424 Front upright set 500
61425 Rear hub carrier set 400
61426 Front hub carrier (/10 degree 7 degrees) 600
61427 Bumper/wing mount set 400
61428 Battery mount set 550
61429 Shock piston set 400
61431 Steering wheel part set 500
61432 Ball-end/shock part set 500
61433 [be] bell gear set (39T/16T) 400
61435 Spur gear (80T/48pitch) 550
61440 Main chassis 2.5mm
(Graphite) ¥8,500
61441 Front shock tower
(Graphite) ¥1,600
61442 Rear shock tower
(Graphite) ¥2,000
61443 Front upper deck
(Graphite) ¥2,000
61444 Rear upper deck
(Graphite) ¥1,700
61450 Diff. cup joint set ¥1,600
61453 Motor mount
(Aluminum/black) ¥3,600
61454 Center bulkhead
(Aluminum/black) ¥2,000
61455 Center bulkhead upper
(Aluminum/black) ¥1,500
61456 Input shaft (5x23mm) 500
61457 Center drive shaft
(5x108mm) 700
61458 Center drive shaft
(5x71mm) 600
61459 Front suspension mount
(Aluminum/black) ¥3,200
61460 Front suspension brace (aluminum/black) 800
61461 Rear suspension block
(Front/aluminum/black) 850
61464 Rear suspension block
(Rear /3 degrees/aluminum/black) 850
61465 Steering post 4x34mm 200
61466 Servo saber set 600
61467 Suspension shaft 3x37mm 300
61468 Suspension shaft 3x47mm (2pcs) 300
61469 Suspension shaft 2.5x30mm (2pcs) 300
61470 Front axle shaft (2pcs) 980
61471 Rear axle shaft (2pcs) 980
61472 Hard steel drive shaft 76mm 700
61473 Hard steel drive shaft 62mm 700
61474 Front hexagonal wheel hub
(Steel/black /2pcs) 800
61475 Aluminum rear hexagonal wheel hub
(Crank type/black /2pcs) ¥1,500
61476 [arumisuredetsudoshiyotsukubodei] (78-58mm/2pcs) 900
61477 [arumisuredetsudoshiyotsukubodei] (95-67mm/2pcs) ¥1,200
61478 O-[ringu] adapter set (2pcs) ¥1,000
61480 Shock cap 15x7.5mm (black /2pcs) 700
61481 Shock shaft 3x45mm (2pcs) 400
61482 Shock shaft 3x54mm (2pcs) 450
61483 [shiyotsukuritenasetsuto] (2pcs) 600
61484 Shock spring adjustment nut (black /2pcs) 500
61485 Shock cap ball 4.8x8mm (purple /4pcs) 580
61486 [suritsupapureto] (2pcs) ¥1,000
61487 [suritsupapatsudo] (2pcs) ¥1,200
61488 Center cup joint ¥1,600
61490 Bearing collar (5x7x1.0/7.0mm) 300
61494 Stabilizer 1.4mm (silver) 300
61497 O ring SS090 (1.0x9.0mm/black /8pcs) 250
61498 O ring AS568-014 (1.8x12.4mm/black /8pcs) 350
61503 Shock spring 14x40x1.1mm8.75 volume
(Front/black /63gf/2pcs) 500
61508 Shock spring 14x70x1.1mm 14.5 volume
(Rear/black /34gf/2pcs) 500
61515 Front wheel (white /2pcs) 550
61518 Rear wheel (white /2pcs) 550
B121 Ball bearing 5x10x4mm
(Rubber seal /2pcs) 600
B130 Ball bearing 10x15x4mm
Z081 Plate screw M3x6mm
(Hexagonal socket /10pcs) 200
Z298 Plate screw M3x5x11mm
(Hexagonal socket /8pcs) 300
61521 Cyclone D4 body set ¥2,800
61524 Wing set (160mm) 620
61529 Cyclone D4 decare 700
61535 [suritsupasukuriyusetsuto] 400
6163 Powerful both sides tape 800
Cyclone D4 spare (existing part)
6816 Silicon O ring S10 150
6820 Silicon O ring P-3 clearing 150
6916 Pinion gear 16T 48P 500
6917 Pinion gear 17T 48P 500
6918 Pinion gear 18T 48P 500
6919 Pinion gear 19T 48P 500
6920 Pinion gear 20T 48P 500
6921 Pinion gear 21T 48P 500
6922 Pinion gear 22T 48P 500
6923 Pinion gear 23T 48P 500
66581 Pin 1.7x11mm (10pcs) 200
72302 Stubby ball set 550
73486 Bush set (R40) 400
73522 Diff. screw and tight lock diff. nut (2mm) set 400
75106 Body pin (6mm/black) 200
75115 Ball stud 4.3x10.3mm (2mm socket /4pcs) 360
75116 Ball stud 4.3x13mm (2mm socket /4pcs) 360
75122 Steering wheel block bush (4pcs) 480
75188 Universal rebuilding kit (2pcs) 300
93464 Titanium turn buckle M3x29mm (2pcs) ¥1,200
93467 Titanium turn buckle M3×34mm (×2) ¥1,200
93473 Titanium turn buckle M3×46mm (×2) ¥1,200
A133 Ball 5.8×6 400
A150 Kit standard thrust ball φ2mm 200
A157 Diff. ball carbide φ2.4mm ¥1,100
A162 Diff. screw M2×25mm 150
A164 Diff. ring 150
A165 Spring φ6×7×1.5mm 150
A166 Diff. thrust washer 400
B015 Ball bearing 4x7x2.5mm (2pcs) 600
B020 Bearing φ5×φ8×2.5 ZZ 600
Z082 Plate screw M3x8mm (hexagonal socket /10pcs) 200
Z083 Plate screw M3x10mm (hexagonal socket /10pcs) 200
Z150 Antenna pipe set 100
Z203 Washer M3×6mm 100
Z224 Washer M3×8mm 100
Z234 Cap screw M2x5mm (10pcs) 200
Z242 E ring E2 100
Z264 Pin 2×10mm 100
Z273 Straight pin 1.6x8mm (12pcs) 300
Z305 Screw post M3x15mm (4pcs) 500
Z350 Pan screw M3x5mm (hexagonal socket /10pcs) 200
Z352 Pan screw M3x8mm (hexagonal socket /10pcs) 200
Z354 Pan screw M3x12mm (hexagonal socket /10pcs) 200
Z355 Pan screw M3x15mm (hexagonal socket /10pcs) 260
Z356 Pan screw M3x18mm (hexagonal socket /10pcs) 260
Z541 Cap screw M3x6mm (6pcs) 200
Z661 Nylon nut M2.6 (4pcs) [sabeji] 21 150
Z676 Lock nut M3 thin shape 100
Z684 Flange nylon nut M4 100
Z700 [imoneji] M3×3mm 100
Z705 [imoneji] M3×10mm 200
Z813 Aluminum color 3x6x0.5mm (10pcs) 300
Z814 Aluminum color 3x6x0.75mm (10pcs) 300
Z815 Aluminum color 3x6x1.0mm (10pcs) 300
Z818 Aluminum color 3x6x2.5mm (10pcs) 300
Z852 Shim M5X7X0.2mm/10PCS 200
Z891 Shim M10X12X0.1mm (copper color /10pcs) 300
Z892 Shim M10X12X0.2mm/10PC
c'est pas grave, ce qui est valable en DTM l'est aussi en TT -buveurs-
Oui c est tout a fait vrai. D un autre coté, je ne comprend pas pourquoi HB a choisi de faire un chassis TT sur une base que l on vas dire de Pro4 donc a cardan au lieu de partir sur la base de la cyclone qui aurais etais justement encore plus tendance.
Par contre la ou je suis déçu et ce n est pas que pour HB, c est qu on a l impression de voir tous le temps le meme Buggy en terme de carrosserie. Tous reprennent celle du BJ en y apportant 1 ou 2 modifs a part Losi ,Tamiya et Yokomo.
oui je crois de plus en plus que pour rouler différent ça va être difficile, ou alors...moi je sais...
Hot Bodies is the release of a diff upgrade set for the Cyclone D4, with the main change being the use of a 2.6mm screw in place of the 2.0mm version that was originally available. This extra thickness on the diameter of the screw increases the durability of the differential.
Et un nouveau chassis de plus pour le Tout Terrain électrique ! Voici le Hot Bodies Cyclone D4...
The Hot Bodies Cyclone D4 is going to revolutionize the off-road racing scene! Combining intelligent & efficient design, a proven 4WD shaft drivetrain, and streamlined manufacturing processes, the Cyclone D4 is the result of months of non-stop testing and years of ambition!
Already a winner at its first major race, the IFMAR Worlds Warm-Up, the Cyclone D4 is destined to be the top choice for racers around the world in the increasingly popular 4WD off-road class!
These instructions show you some tips on how to better build your Cyclone D4. These tips are what top Hotbodies drivers do to their cars to ensure the best performance and reliability from their cars
Chassis Preparation (pdf, 1.09 Mb)
The first step when building your Cyclone D4 is to super glue the edges of your chassis, top decks and shock towers.
Transmission (pdf, 1.07 Mb)
There are several key areas in the build of the transmission where extra work and attention can pay off with superior performance on the track.
Steering (pdf, 1.01 Mb)
The first step is to clean up the mouldings for the steering parts. It is important to do this to ensure that the steering mechanism is free, without slop, once assembled.
Centre Transmission Assembly (pdf, 1.05 Mb)
When assembling the centre mount that clamps the slipper assembly into the centre bulkheads you may find it beneficial to stick the bearing holders to the centre bulkhead upper.
Driveshafts (pdf, 0.96 Mb)
The driveshafts are an important part of the transmission. Here we show how to improve the reliability and durability of your driveshafts.
Front Suspension (pdf, 1.14 Mb)
There are 2 different angle castor blocks included in the kit. On the castor block there is a letter and a number. The letter tells you what side of the car the castor block is for, and the number tells you how much castor the block adds to the car.
Rear Suspension (pdf, 1.15 Mb)
First, don't forget to install the bearing spacer between the two rear wheel bearings. This spacer stops the bearings being clamped when the wheel is screwed on.
Shocks (pdf, 1.22 Mb)
Check the shock retainer collar for burrs. If there are any burrs remove them with a modelling knife.
Electronics (pdf, 0.91 Mb)
The best way to route the wires from the speed control to the motors is under the front centre driveshaft.
Body and wing (pdf, 0.95 Mb)
The body has scoops moulded into it. When racing in warm conditions these scoops can be cut out to allow cooling air to pass over the motor and speed control.
Prototypes shown on pictures
Thickness: 4mm
Rear wing position: 2
New from HB for the Cyclone D4 is this Diff Maintenance kit. This kit has a thicker 2.6mm differential screw along with a new longer heavy duty nut. You also get new bigger thrust plates and balls. This kit will improve the life of your diff and eliminate any potential breakages.
HB61544 Diff Maintenance Kit (2.6mm)
You can also buy the screw and nut on its own if you wish to replace the new thicker nut or just need a fresh nut for safety.
HB61538 Differential Screw & H, Duty Nut Set 2.6mm
Une question toute simple aux possesseurs du Cyclone D4 Hot Bodies (et à ceux qui ont vu évoluer ce TT1/10) :
Comment trouvez-vous le comportement de la voiture ? Est elle saine / facile à piloter quelques soient les conditions de piste ? Quels sont ses défauts / qualités* (* à part d'être un BJ4 anodisé purple...)
Bref, un post pour en savoir un peu plus sur la bête...
salut j ai fait 3 packs avec le mien ,avec
rouelibre devant la voiture marche fort juste le train arriere a tendance a partir un peut je n'avait pas la bar stab d'origine je dois faire un essai bientot des qui ll ne pleut pas avec
ressorts blanc partout et la barstab + pneu neuf .
Merci pour réponse, c'est un premier avis intéressant.
Tu as roulé sur quelles type de surface ? Tu as utilisé les ressorts Blacks devant / derrière ? Penses-tu le tester en 4x4 permanent ?
je roule sur un terrain en argile avec ressort black devant et derriere de boite !
je ne changerai pas de caisse sauf si transmition trop fragile peut etre le B44 ? A etudier !!:)
salut, je possede un D4, j'ai fait a peu prés 12 packs,je roule sur un circuit terre ( a antibes ),la voiture est performante, un peu delicat du train AR dans les parties rapides, j' ai mis les fusé AR 0.5 degrées, le train AR se comporte mieu, et en mettant les ressorts blanc derriere, la voiture et stabilisé, mais la voiture est moin bien amortie et braque moin bien dans les virages lent, j'essaye d'autre chose vendredi, je vous tiendrai au courant. a++++
et si cela peut vous aider dans vos réglages, n'hésitez pas à consulter notre base de données (voir page accueil, menu LES INDISPENSABLES)
Pour le D4 -> http://www.petitrc.com/view_news.php?id=7888
Et si vous avez des fiches de réglages pertinentes, n'hésitez pas à nous contacter pour une mise en ligne.
Merci pour vos infos et le lien (bien pratique en effet - Merci Nico !)
Mon D4 va faire sa première sortie à Dhuizon (Coupe de France ce week-end) ... ça va être l'aventure !!!!!!!!!!!!!!!!!...........
C'est le liens de la dtm nico :)
Merci Fouad ! je me suis trompé de lien en effet - Celui-ci est rectifié.
Pour la terre, il y a quelques fiches de réglages.....Emmenez les, ça peut vous servir.
Salut Pascal ;)
Pour avoir vu rouler Teddy Truman au GP de Belgique avec ce D4... je suis resté sur ma faim car il n'a pratiquement pas terminé une seule manche, à chaque fois, c'est comme si les couples conniques dégageaient :confused:
Et à priori, pour faire tourner l'auto, faut mettre une BAR à l'arrière
Olivier
Salut Olivier !:)
Merci pour cette nouvelle info ... Les couples coniques ... Avec mon dernier TT ;-) je n'avais pas de problème... J'espère qu'avec le nouveau il n'y en aura pas non plus !!!! Wait and seeeeeeeeee ...
