Team Associated RC8 / RC8T
20 posts in this topic
Illuzion body for the RC8 now available!
Now Available! The Illuzion – RC8 - Scoopless body by JConcepts
(Direct fit for the Associated RC8 buggy)
The Illuzion – Scoopless body has turned radical. The Illuzion “Scoopless” styling presents a smooth yet detailed design while incorporating many of the features from the original Scoopless body for the RC10B4. Race inspired aggressive styling, Illuzionized cab and durable design are just some of the features that make the new Illuzion – RC8 body stand out from the rest.
Add this exciting new body to your Associated RC8 today!
Illuzion – RC8 – Scoopless body Features:
* Original Illuzion - Scoopless Styling
* Race inspired body, cab and window design
* Unique side pod recess for increased durability and detail
* Clear polycarbonate with protective film
* Window masks and detailed Illuzion decal sheet
All bodies come clear (not painted) the images shown here on this page are custom painted. Custom paint is not included.
The RC8 Service Pack is available free of charge to our customers who purchased an RC8 Factory Team vehicle, part number 80900.
1 - Arm Mount A
1 - Arm Mount B
1 - Arm Mount C
1 - Arm Mount D
1 - Top Plate
4 - Button Head Capture Screws
4 - Flat Head Counter Sunk Screws
1 - Front Lower L/R Arms (pair)
1 - Front Upper L/R Arms (pair)
4 - Washers For The Capture Screws
2 - 45mm Socket Head Capture Screws (For D Plate To Gearbox)
If you have any questions about ordering your free RC8 Service Pack, contact our Customer Service Department at (949) 544-7500 X2124. You will be required to supply a proof of purchase for each RC8 Service Pack you order. Limit one Service Pack per vehicle.
Click here for instructions on how to obtain your copy of the RC8 Service Pack.
Shiny CV Bones
Diff Outdrives
RC8 Stub Axles and Input Cups
Strong and lightweight, these parts are made in the USA out of high-quality 7075-T6 aluminum. Reduce rotating weight by 1.93 oz. (55g) when using the complete set of all three products! Reducing rotating weight equals more punch, stronger brakes, and more run time!
Team Associated is proud to bring to you the Factory Team RC8T, a 1:8th scale full-blown racing truggy based on the successful RC8 platform! Like the Factory Team RC8 buggy before it, the highlyanticipated RC8T will raise the performance bar for 1:8th nitro truggies.
Strength, durability, maximum corner speeds and rough track handling were the key design elements Area 51 worked into the RC8T. Drivers will experience unparalleled and effortless “pop” as they launch from the jumps. Landings will be plush beyond belief due to the enhanced suspension that other truggies can only dream of.
From the correctly balanced and optimized weight distribution, silky smooth and reliable ‘Big Bore’ shocks featuring 4mm gold shafts, innovative clutch design, to the machined chassis, every inch of the RC8T screams high performance and durability. There will be no question to why the Factory Team RC8T will be the truggy of choice at the highest levels of competition.
The Factory Team RC8T Truggy Kit features:
• Factory assembled shocks, diffs and turnbuckles. Factory Team shock and diff fluids included.
• Factory Team ‘Big Bore’ threaded, hard-coated shocks feature 16mm six hole pistons and 4mm gold shock shafts for maximum smoothness
• Factory Team Aluminum Top Plate and Steering Rack for the ultimate truggy durability
• Factory Team chassis braces with integrated center stiffener that maintains chassis integrity
• 4mm woven carbon fiber shock towers for maximum rigidity, strength, and light weight to keep the center of gravity low
• Blue aluminum wheel hexes featuring captured drive pins and nyloc wheel nuts providing the ultimate in security
• The 4.30:1 ratio gear boxes produce maximum punch allowing the RC8T to accelerate harder out of the corners and up the biggest jumps
• FFC Free Float Caliper brake-system eliminates the possibility of unwanted brake drag while on throttle
• Two-piece split-center diff mount allows quick and easy access to the center diff
• Wing angle and position is fully adjustable and secure
• High-torque capacity three-shoe aluminum clutch
• Full CVAs with captured CVA pins
• Full ball bearing drivetrain and steering
• Metric alloy hardware throughout
• Milled 3mm black hard-coated 7075 aluminum chassis
• Factory Team blue titanium turnbuckles
Availability: July 2008
1:8 Scale Nitro 4WD Off-road Buggy Kit
The Factory Team RC8B picks up where the RC8 left off by adding many performance and durability enhancing features that were pioneered by our Area 51 engineers and world class pro team drivers, making a great buggy even better! The new RC8B features include Factory Team 16mm Big Bore threaded, hard-anodized shocks, updated 5mm 7075 blue aluminum shock towers, 7075 blue aluminum suspension mounts, Factory Team 7075 blue aluminum one-piece top plate, forward placement battery box, and optimized steering geometry. The RC8B gets you on the track fast, coming with pre-assembled shocks, diffs and turnbuckles, and also includes Factory Team shock and diff fluids. All of these refinements are what make the Factory Team RC8B, a potent buggy ready to take your racing to the next level, that is pure Associated!
The Factory Team RC8B Kit Features:
* Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
* Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
* New 5mm 7075 blue aluminum shock towers allow the driver to stand the shock angle up for a more aggressive suspension
* Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
* 7075 blue aluminum suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
* Optimized steering geometry for more consistency and reduced bump-steer
* Updated wing mount with additional clearance for 16mm shocks
* Molded composite radio tray includes optional forward placement battery box for increased steering
* Molded composite front and rear chassis braces
* Tough steel-alloy shock stand-offs
* Factory Team 83mm big wheels included
* Machined aluminum racing clutch shoes
* Lightweight engine mounts
* Factory Team 7075 blue aluminum one-piece top plate
* Light-weight 3mm hard-anodized chassis
* 4.30:1 ratio gearboxes for maximum punch
* Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
* Two-piece split-center diff mount allows quick and easy access to the center diff
* Caster blocks adjust 14, 16, or 18 degrees with molded inserts
* 3.5mm light CVA drivetrain with full ball bearings
* Rear molded CVA boots to keep dirt and mud out of rear joints
* Blue aluminum hexes and nylon locking wheel nuts
RC8B Specifications
Scale: 1:8
Power: Nitro
Length: 470mm
Width: 305mm
Track: 259mm
Weight: 3570g*
Wheelbase: 323mm
Internal Gear Ratio: 4.30:1
Drive: 4WD
*Actual weight will vary depending on the engine, exhaust, electronics and tires used in the finished kit.
RC8T Factory Team Championship Edition Kit
After TQ'ing all four rounds of qualifying, Team Associated's RC8T Factory Team kit took first place at the 2009 ROAR Nationals! Driven by Ryan Maifield and powered by the Reedy 121VR .21 competition engine, the RC8T performed as it was designed to and brought home the big win!
Inspired by this achievement, Associated is proud to introduce the RC8T Factory Team Championship Edition Kit. The RC8T CE kit has added many new features to the original RC8T that make it an even more potent race machine. Improved strength, durability, rough track handling and overall performance are all qualities built into the RC8T CE making it the most competitive Team Associated truggy to date.
RC8T Factory Team Championship Edition Kit Features:
• Pre-assembled shocks, diffs and turnbuckles with Factory Team shock and diff fluids included.
• Factory Team 16mm "Big Bore" threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for durability and reduced stiction.
• Updated 5mm 7075 blue aluminum shock towers with additional rear camber link options.
• Revised front upper camber link assembly allows for easier adjustments and maintenance.
• 7075 blue aluminum suspension mounts key into chassis for maximum durability.
• Molded bushings allow for easy adjustment of caster, rear toe-in, rear anti-squat, and front kick-up.
• Updated steering geometry for more consistency and reduced bump-steer.
• Molded composite radio tray includes optional forward placement battery box for increased corner speed.
• Molded composite front and rear chassis braces for increased chassis response.
• Blue aluminum Narrow hex adapters with pin retainer clips and nylon locking wheel nuts.
• JConcepts Punisher body features a low profile design for a lower C.G., improved air flow and quicker fueling.
• JConcepts Illuzion wing pre-drilled for RC8T.
• JConcepts tires and foam inserts.
• Three aluminum clutch shoes with full sets of 1.0mm and 1.1mm clutch springs.
• Factory Team 7075 blue aluminum one-piece top plate.
• Lightweight 3mm 7075 hard-anodized chassis.
• 4.30:1 ratio gearboxes with a 14T clutchbell and 54T spur gear.
• Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates unwanted brake drag.
• Two-piece split-center diff mount allows easy access to the center diff.
• 3.5mm light CVA drivetrain with full ball bearings.
• Rear molded CVA boots to keep dirt and mud out of rear joints.
• Lightweight engine mounts.
RC8T Factory Team Championship Edition Kit Specifications
Scale: 1:8
Power: Nitro
Length: 555mm
Width: 410mm
Wheelbase: 375mm
Track: 346mm
Weight: 4230g*
Drive: 4WD
Features
Weight Relocation • One of the things that made the biggest changes in the RC8B's dynamic is weight distribution. A simple rule is the more weight you put up front the more aggressively it handles. The newly redesigned radio tray moved the battery up toward the front and the result is a more aggressive and controllable steering feel.
BIG Shocks • One of the options missing from the previous kit, but available as an upgrade, was the new big bore 16 mm shocks. As many companies found the larger shock bodies offered better consistency and handling in the grueling conditions of racing.
CF out AL in • Many RC8 racers probably had most of these upgrades already. The Team has been testing these parts for a while, but it was never in one kit. So the new suspension geometry and the aluminum pivot blocks all come standard. That goes for the aluminum shock mounts, which are a stout 5 mm thick and have new shock hold locations.
1. Transponder Mount — Both a personal transponder and the regular ones have a place to sit.
2. Pre Assembled — Lots of parts like the diffs and shocks come pre-assembled to speed up the built time.
3. Camber Link Redo — Easier to adjust and more durable front-camber link mounts.
4. RC8B talk Ti — No skimping on turnbuckles; they are titanium.
5. Big Box — Sometimes companies make electronics compartments too small, but it's not the case with the RC8B. You get plenty of room for your RX of choice.
6. New Rack — A revised steering rack gives you less bump steer.
7. Free Floating Brake Calipers — No unwanted drag.
Testing
I headed up to my favorite track in the area, Thunder Alley, in Beaumont, Calif., for a day of testing. I had been running the previous car for a season and I'm pretty familiar with how the car handled so it would make for a good comparison. Thunder Alley has some of the best layouts for testing in the country and it really tests the cars handling ability. This layout was a very technical layout riddled with jumps and the traction varied from high when wet to low when dusty.
Acceleration and Speed • The new Reedy engine puts out a decent amount of power, more than most will be able to put down to perfection. The combination with the AE-2035 pipe and clutch setup felt great. The RC8B hits hard off the line, and it doesn't do anything strange when accelerating. Speed was pretty darn good for the straights.
Rating: 9/9
Braking • This part is always more complicated and harder to get right than people think. Getting the right bias and feel isn't something that you just set up in the pits. So once you get everything set right the RC8Bs, brakes work to perfection with little drama. They are pretty easy to adjust and hold their setting pretty well.
Rating: 9
Low-Speed • The RC8B never had any issues with low speed handling. The revision to the geometry and weight distribution added a little bit better response and a lot better "feel" to the car. It now feels aggressive, but not too aggressive where it bites your hand off. The rear end behaves much better now, but seemed to side step over some strange ruts.
Rating: 9.5
High-Speed Handling • Hammer down on the throttle and the Reedy engine gets happy. The RC8B was also happy, and its new shocks's ability to handle the chop made it pretty easy to stay in control. This was the box setup and even without any changes the RC8B felt right.
Rating: 9.5
Rough-Track Handling • It's getting harder and harder to say if a buggy does this well because most of the top-level buggies are starting to be too good. Luckily us mortals never have to worry about that, but it's good to know that the geometrical revisions made the car handle the rough stuff better. Since most 1/8-scale racing is done on some blown-out tracks, this becomes one of the must important handling areas. The RC8B now does it better than before. I did notice that in some corners that a rut would catch the car off guard and kick the rear out, but tires might have been more of the issue than the car with that.
Rating: 9.5
Jumping • The RC8B heads for the clouds with complete confidence and control. The snappy acceleration means you can clear the tougher sections easier. Once in the air the buggy behaves well and you can correct the attitude with the standard brake/throttle inputs. Landing is something that seems to have improved as well. There's less of a stiff smack when you flat land jumps.
Rating: 9.5
Wrenching
Maintenance • Working on any AE product seems to be easy. A lot of thought went into the design and layout of the car and that holds true for maintenance as well. Most of the "major" service areas are accessible by about four screws and thankfully the car only uses a few hex sizes so you'll only need a 2 mm or 2.5 mm wrench. We also love that AE switched to metric screws. Makes everything much easier.
Rating: 10
Wear and Tear • Every vehicle has points that wear or break, and the RC8B will be no different. That's not to say AE didn't take customer feedback and address the previous version's weaker points. You'll see that most of the stress points now have aluminum and things have been redesigned or strengthened to provide better durability. I'm slightly out of my "race practice," so it does take me longer to get my timing and rhythm going so I'll case, lawn dart, and honestly blow out much more than I normally would. It's not good for my pride, but it does show that the car can take an ass-kicking and keep going. The one thing that broke? I stripped a collar trying to adjust my rear brakes! I'll take that as damage anyday.
Rating: 10
Tuning • This version of the car includes many tuning options that you may not want to use. I stuck with the stock setup and compared it to what the current setup was and made any changes the team guys had different. AE has a Web site with all those current setup sheets, but my advice is drive the car first and get used to it. Don't change everything every run.
Rating: 10
Conclusion
AE continues to impress me with their vehicles. Not only are they tops in the class, they offer an incredible value. This fully loaded factory team edition is about $500 and you get a lot of kit for that. Material quality, handling, good parts and team support all equal an incredible car. It's not hard to see why AE is one of the best brands in the business.
Bonjour as tous,
Je suis à la recherche de big bore pour mon rc8rs. Quel sont les modèles les mieux adaptés pour un usage à caractère loisir plus quelque petites courses entre pots. plusieurs modèle proposés par asso mais est ce vraiment un bon rapport qualité/prix. Une dernière question sur les ressorts : sont ils vendus avec sinon quoi choisir?
Merci d'avance et bonne journée.
Ok merci. Les ressorts sont avec ou pas ?
