Posted June 16, 2007 il parai que asso va sortir un 4X4 je voudrai savoir a quel prix et quand merci:buggyred: Share this post Link to post Share on other sites
Posted June 16, 2007 pas entendu parler d un 4X4 elec en tous cas. Cependant le RC8 est d ores et deja sorti en championnat TT1/8°. Share this post Link to post Share on other sites
Posted June 16, 2007 http://www.4wdrc.com/news_05_28_07.htm Share this post Link to post Share on other sites
Posted July 11, 2007 Voici le Factory Team B44, projet pensé en 2003 entre le Team Associated et JConcepts, 2 grandes marques partenaires officiels de la PETIT RC RACE 2007 The Factory Team B44 project came to life in 2003 as a cooperative effort between Team Associated and J Concepts’ Jason Ruona and Brad Reelfs. Team Associated & Jconcepts are Official partner of the PETIT RC RACE 2007. After Team Associated’s Ryan Cavalieri won the 2005 IFMAR World Championships in Collegno, Italy with the BJ4 Worlds Edition, Area 51 shifted into overdrive to produce a true ‘Associated’ inspired 4WD buggy that would continue to dominate the 4WD off road racing class. The B44 is the result of this two-year development effort. During the design and development stages Associated used their extensive and well-proven skills to make a 4WD competition buggy that is better suited to production. The results of this optimization are realized by you, the customer, in a more cost-effective vehicle with more readily available spare parts. The B44 is built on a 2.5mm woven carbon fiber main chassis and top plate. What’s new is the composite front bulkhead and rear chassis plate. These new features greatly improve overall durability and increase the ground clearance, further enhancing the B44's performance. Area 51 designers also improved the BJ4’s slipper clutch. The result is the B44’s new externally adjustable, dual pad slipper clutch, which transfers power to the ground more efficiently and effectively. The B44 employs a hardened steel CVA drivetrain with lightened ball differentials for unparalleled acceleration. The B44 soaks up the bumps using Factory Team hard anodized aluminum threaded shocks with gold shock shafts. The shocks mount to durable 3mm woven carbon fiber shock towers, making the B44 more responsive and giving quicker handling. The B44 gets the full Factory Team treatment with blue titanium turnbuckles, blue aluminum shock bushings and blue aluminum servo mounts for a car that looks as good as it is fast! Many Team Associated fans from all over the world have asked us when we are going to build a 4WD buggy. Team Associated is proud to say that day has come with the B44, the only 4WD electric race buggy that comes from a racing heritage with 20 IFMAR World Championships behind it. Factory Team B44 Suggested Retail: $549.99 Available: September 2007 Features of the Factory Team B44: • Composite front bulkhead and rear chassis plate for improved durability and more ground clearance • Externally adjustable, dual pad slipper clutch • 3mm woven carbon fiber shock towers • 2.5mm woven carbon fiber main chassis and top plate • Rear hubs use large .187 x .500 bearing for more durability • Lightened ball differentials front and rear • Shaft drive for unparalleled acceleration • Slotted motor mount for quick and easy installation • Blue aluminum center bulkhead cap with molded bearing inserts • Ball bearing steering with adjustable servo save • Hardened steel CVAs with cross pin retaining clips for ultimate reliability • Front wheels and hexes are optimized to prevent hex stripping • Hard anodized aluminum threaded shock bodies with Factory Team gold shock shafts • Blue Factory Team titanium turnbuckles • Blue Factory Team aluminum shock bushings • Blue Factory Team aluminum servo mounts • Blue Factory Team thumb screws and molded battery straps Share this post Link to post Share on other sites
Posted July 11, 2007 C'est marqué dans le texte.......cardan.... Share this post Link to post Share on other sites
Posted July 11, 2007 "Shaft drive for unparalleled acceleration" -> cardan Share this post Link to post Share on other sites
Posted July 11, 2007 le cardan c'est tout de meme le top en tt, surtout qd revetement poussiéreux ou caillouteux. d'apres foto, caisse semblable au bj, avec fusée noire ( non losi bien sur !) aileron new, par contre ds description ( lue rapidos) ils parlent du slipper réglable de l"extérieur, donc du nouveau peut etre à ce niveau ? style yok ? on verra..... on peut comprendre qu'asso a donné comme mission à j concept de plancher sur un projet 4wd ds l'optique de la sortir ds sa marque un jour, coincidence ou non le we est maintenant dispo sans pré liste ..... en tous les cas intéressant pour la disponibilité des pièces, mais en direct avec bj par leur site c'était nickel, mais tout n'était pas en ligne, c'est bien tout cela ! en tout cas année riche pour asso, avec la tc5, le rc8 qui arrive à la rentrée et le B44 maintenant ! ils mettent le paquet !!!:winner: Share this post Link to post Share on other sites
Posted July 11, 2007 Bonne nouvelle )) depuis le temps que la rumeur trainait sur le net !!! Le prix $550 (~400 roros) ... dans la lignee des models concurents: LOSI XXX-4 G+ ($499.99) JConcepts BJ4 WE ($475.00) Xfactory X-5² (499.00) Yokomo MR-4BXF ($550.00) Kyosho Lazer ZX5 ($499.99) TAMIYA TRF501X ($519.99) (info ces tarifs sont extraits des revendeurs rc amercains) Que va t'il se passer avec jconcept ? Les pilotes pro-asso vont-ils changer leur chassis? Nous verrons cela durand la prochaine saison :applo: Share this post Link to post Share on other sites
Posted July 11, 2007 le lazer est à 299$ et pas à 499:) mais un asso 4x4 j'en connais deja qui economise:applo: Share this post Link to post Share on other sites
Posted July 11, 2007 celui la va arrive grossir les rangs chez moi c'est sur!!!!! Share this post Link to post Share on other sites
Posted July 11, 2007 le démontage moteur amélioré aussi ( c'est pas dur) si quelqu'un peut donner une traduction précise .... il me paraitrait logique que le bj4 laisse la place au B44, apres ce sont des choix commerciaux on verra. en tous les cas ca confirme la "lignée asso" à savoir qu'ils ne sortent pas un chassi tant qu'il n'est pas aboutit, là en locurence j concepts a pensé la voiture surement en étroite collaboration avec asso ( en fournissant une bonne partie des pièces). Le rc8 par ex n'est prévu qu'en septembre.... de plus les chassis restent idem de nombreuses années, pas comme chez schum pour ne pas les citer qui sortent des caisses presque tous les ans ! ( je ne dénigre pas, mais c'est l'ex qui m'est venu à l'esprit).le B4 commence à avoir de la bouteille par ex ... vivement qu'on en sache plus, rien sur le site asso. Share this post Link to post Share on other sites
Posted July 11, 2007 le lazer est à 299$ et pas à 499:) yep desole c'etait le prix catalogue a sa sortit ! c'est vrai que maitnenant il est dispo partout a moins de $300 Merci pour le correctif mais un asso 4x4 j'en connais deja qui economise:applo: C'est sure a mon avis debut septembre ... dans les petites annonces ... il va y avoir du bj4 d'occase disponible ... et cela va arranger beaucoup de pilotes car les pieces asso sont disponibles dans kasi tous les magasins americains ... a la difference des bieces du bj4 Share this post Link to post Share on other sites
Posted July 11, 2007 IL ME TARDE D AVOIR LES PHOTOS DU CHASSIS NU SANS CARRO ,ANNONCé EN SEPTEMBRE CA VA NOUS FAIRE dU FIN 2007 DEBUT 2006 TOUS CA Share this post Link to post Share on other sites
Posted July 11, 2007 c'est un nouveau modèle de jante arrière non ? Share this post Link to post Share on other sites
Posted July 11, 2007 IL ME TARDE D AVOIR LES PHOTOS DU CHASSIS NU SANS CARRO ,ANNONCé EN SEPTEMBRE CA VA NOUS FAIRE dU FIN 2007 DEBUT 2006 TOUS CA si tu veux une photo du b44 va sur le site de jconcept, lisez le texte depuis le début la réponse se trouve dedans... Share this post Link to post Share on other sites
Posted July 11, 2007 hohohoho Encore un cousin du BJ4 ! Qui va courir avec au world? Sera t il WORLD CHAMPION ? Share this post Link to post Share on other sites
Posted July 12, 2007 On July 10, TTR/Associated announced the upcoming release of the new B44. This new vehicle is based on the BJ4 Worlds Edition and was a collaborative effort between TTR/Associated and JConcepts. The B44 was a collaborative project only. JConcepts remains an independent company, and our business will not change as a result of this collaboration. Both Jason and Brad have ties with Associated going back 15+ years. This has led to a close working relationship between Associated and JConcepts on the B44. JConcepts will continue to sell the BJ4 kits, parts and accessories to support new and existing customers. Look for more new and exciting products from JConcepts to fit the B44 and all Team Associated vehicles. Share this post Link to post Share on other sites
Posted July 12, 2007 en pre-release "a la tour des loisirs" -> $453.99 (ref ASC9060) Share this post Link to post Share on other sites
Posted July 12, 2007 Warsboy va se mettre au 4x4 ! Tout d'abords, j'apprends a conduire mon b4 .... Share this post Link to post Share on other sites
Posted July 12, 2007 FIN 2007 DEBUT 2006 TOUS CA Debut 2006 t'es sur ? Share this post Link to post Share on other sites
Posted July 12, 2007 fallait pas aller chercher bien loin pour avoir un asso B44, à quand le x5 produit par losi? Share this post Link to post Share on other sites
Posted July 12, 2007 Bah de toute manière, depuis que Gil est parti, chez Losi, ça sent le roussi... Share this post Link to post Share on other sites
Posted July 13, 2007 Sans carro, le B44 donne ça: Olivier Share this post Link to post Share on other sites
