T.O.P Racing - Scythe
17 posts in this topic
Aluminium Front Solid Axle Set (Scythe Gold)
Aluminium Front Solid Axle Set (Red)
Aluminium Front Solid Axle Protector (Scythe Gold)
Aluminium Front Solid Axle Protector (Red)
Steel Front Solid Axle
33T/15T Modified Pulley Gear Set (without belts)
33T/17T (ratio : 1.94) Drive Train Set
33T/17T Modified Pulley Set
Diff. Hub Set
Aluminum Diff Hubs with Blades (Scythe Gold) New!!
Aluminum Differential Hop-Up Set (Scythe Gold) New!!
Aluminum Diff Hubs with Blades (Red) New!!
Aluminum Differential Hop-Up Set (Red) New!!
Differential Protect Seal (Scythe & Kyosho Stallion
TOP have updated their car for the next season. They called it the TOP Scythe '2008 Edition'. This car has ‘restorable flex’ chassis design for superb cornering speed & stability. It has a Full carbon fibre chassis, shock towers and steering plate, Alloy threaded shocks, motor mount, alloy pivot blocks and alloy hex hubs. And the new single bellcrank ball bearing steering set-up delivers now even a better steering. The TOP Scythe '2008 Edition' comes with a light weight rear differential and front one-way. This is the ultimate TOP Scythe Editon.
This version comes with the following red aluminium option parts:
2 x bulkhead cover
2 x bulkhead left/right sides
1 x motor pod base
1 x motor pod right side
1 x top deck support post
1dfd5bd5b08178d9ff73b62f5bdf5ad5.image.100x66.jpgbf12cbc7bca52147f650ec09cd72e5cd.image.100x66.jpg12f62d4d3fe5adc96331718cf75bac47.image.100x66.jpg905b66fe57611159aa21da4d8f2638db.image.100x66.jpg41c5bdc5429b17ed97d982df02abaec2.image.100x66.jpg
http://www.muchmoreracing.com/store/index.php?main_page=product_info&products_id=2553
The Carpet-Flex Pro Conversion Kit comes with the following parts to convert your existing Scythe Chassis:
2.75mm carbon fibre carpet bottom deck with milled motor mount
2.25mm carbon fibre carpet top deck
2 sets of red alloy lower bulkhead left/right parts
2 sets of new design red alloy single sided upper bulkhead parts
4 red alloy top deck support posts
4 suspension pins for use with bottom deck
To answer a few of the questions:
#1 - I did use Xray suspension arms, castor blocks and steering blocks. These were not used so much from a performance standpoint but a safety standpoint as their parts are extremely durable for foam/carpet racing. With this being the first race with TOP, I wanted to have a good result with the car without the worry of the HPI arms, blocks, hubs breaking easily. I watched Hara break a lot of HPI parts last year and this concerned me so Vincent and EJ gave me the go ahead to use them for the race. We are working to adress this though as soon as possible. I tested here before the race and was actually quicker with the HPI parts but durability was my concern as I know if I had a bad result, both TOP and myself would take a beating online...lol..
#2 - I did use Kyosho shocks and differentials. Again, the main reason being that I had experience with them and I knew how to set them up for good performance and life. I have no doubt that that TOP shocks and aluminum differentials will work well but it was just one of those things were there was limited time and I needed to make sure I only had to learn/set-up a few items rather than start from the ground up with only a few days testing. If I remember correctly, the aluminum differential comes with a 2.0mm screw which I am sure I would break in Mod/Foam. In every other class raced it would be fine but again, being the first race I wanted to be sure to have no "break downs" and just focus on the set-up and being comfortable with the car.
#3 - I cut the bulkheads so I had more room to adjust the upper camber links as I just didn't have the experience with the car at the major events. I tested a little here before the event and I liked the lower rear inner link but at the race it was terrible. I think the main difference being that our track was low traction with Paragon and the Birds was super high traction with Jack the Gripper (really different balance and feel). In the end, I actually put the stock upper bulkheads back in the rear and ran the lowered ones in the front. Overall, the pivot ball was only .5mm lower than stock which could have been done with a shorter ball stud. The height of the camber link mounts is the same from the stock car to the Carpet Flex bulkheads.
Josh Cyrul
Josh Cyrul just inked a deal with TOP (Tokyo Optional Parts) to run their Scythe touring sedan. Just released for the Scythe is the Carpet Pro Flex top plate and bulkheads. Cyrul's car seen here with th CPF kit installed.
The CPF kit includes a stiffer top plate that gives you the option to use aluminum stand offs to keep flex to a minimum. The new top plate also doesn't bolt over the upper halves of the bulkheads; this makes differential removal a breeze. The new lower bulkhead pieces are now two left and right pieces instead of being one piece connected together. Josh easily captured the overall Super Stock win with this new TOP ride.
Here are some pics of my TOP Scythe. For those that don’t know this is a 1/10th electric touring car, combining the best of HPI, Yokomo and TOP’s own parts to make a very competitive chassis.
I just took these pics quickly as it is a sunny day, the car was run at an outdoor meeting a couple of days ago hence the tyre dust all over it. Sorry if it offends your eyes.
Somewhat battered shell now, having had the car 9 months or so. It is a Protoform Mazdaspeed 6 if you were wondering.
Under the shell. The car is quite close to standard, there are a few bling parts on there like the red nuts, but I still run the plastic bulkheads because for me the car is a lot easier to drive like that. And yes, I know I am using stone age brushed/NiMH/40MHz technology - but it works!
Preparation and assembly of the TOP - Scy Model Chassis
The battery casings of the chassis need to be filed to a 45º angle so that the battery can sit perfectly. The battery must not lie below the level of the chassis or it it will rub against the asphalt. Then a little bit of loctite must be applied to the filed zone and then spread with a cotton swab.
In the same manner, a little loctite be also be applied to the edges of the chassis as with shock supports to avoid delamination.
If you use adhesive tape to secure the batteries you can smooth the edges where the tape has been applied with a file to prevent splitting.
TOP Racing have released 2 new versions of their electric touring car, the Scythe. Available as an ARP or CFP version, both come with 2.5mm thick ‘Equi-Flex’ chassis and 2.0mm thick carbon version 2 upper deck for easy spur gear maintenance as well as separate type bulkhead assembly for easy drive train maintenance. The ARP spec chassis is for use with rubber tires and comes with regular profile shock towers, ARP 2.0mm Ver. 2 upper deck and separate-type suspension mounts, while the CFP is designed for use with foam tires and has low profile shock towers, CFP 2.0mm Ver. 2 upper deck with wings for extra stiffness and also has regular one-piece suspension mounts.
New Common Features of ARP/CFP Series
- 2.5mm U.S. Spec. “Equi-Flex” Carbon Fiber Main Chassis
- 2.0mm Ver. 2 Upper Chassis for Easy Spur Gear Maintenance
- Separate Type Bulkhead Assembly for Easy Drive Train Maintenance
- New Drive Pulleys with “Anti-Skip” Pitch Profile
- New Internal Drive Ratios Optimized for Rubber and Foam Tire Racing
- New High Strength Steel D-Cut “Never Get Loose” Universal Pin
- Rear Alloy Dog Bone for a Lighter Drive Train
- Ver. 2 Universal Joint for Smoother and More Durable Drive Operation
- Rear Belt Tensioner
- “Clamp-Type” New Offset Wheel Hex Adaptor
- Front and Rear Carbon Fiber Composite Suspension Arms
- All Parts are compatible with Scythe from Sy Brand
ARP-Specific Features
- Regular Profile Shock Towers
- ARP 2.0mm Ver. 2 Upper Deck
- Separate-Type Suspension Mounts
- 37T/17T Internal Drive Ratio (1:2.18)
- Front Steel Spool and Rear Light Weight Differential
CFP-Specific Features
- Low Profile Shock Towers
- CFP 2.0mm Ver. 2 Upper Deck with Wings
- Regular One-Piece Suspension Mounts
- 33T/17T Internal Drive Ratio (1:1.94)
- Front and Rear Light Weight Differentials
Source: racingartcompany.de
ce chassis n'est pas importé en France. Par contre l'importateur allemand est très actif et ce week-end à l'ETS il y en avait une bonne vingtaine dans les stands. Mais à mon avis, pour la plupart, leurs setups devaient pas être au point car visuellement c'était pas super en piste.
