Robitronic - Scalpel
81 posts in this topic
Here are some important tips to help assembly and set up your new Scalpel, click on the oicture!!
Pre-printed bodies now available
Who wants to paint when you have these cool pre-painted bodies all ready to go. Just trim and apply decals and you are ready to hit the track. The bodies come in 3 different colors red, blue and green; includes a full decal sheet with wheel decals.
RA2075B Scalpel body, painted blue
RA2075R Scalpel body, painted red
RA2075G Scalpel body, painted green
Scalpel tires with different shore hardness now available pre-mounted on black or white wheels.
RA2071 Front wheel black complete, red soft (2pcs)
RA2064 Front wheel black complete, yellow medium (2pcs)
RA2072 Front wheel black complete, blue hard (2pcs) = Standard
RA2071W Front wheel white complete, red soft (2pcs)
RA2064W Front wheel white complete, yellow medium (2pcs)
RA2072W Front wheel white complete, blue hard (2pcs) = Standard
RA2065 Rear wheel black complete, white supersoft (2pcs) = Standard
RA2073 Rear wheel black complete, red soft (2pcs)
RA2074 Rear wheel black complete, yellow medium (2pcs)
RA2065W Rear wheel white complete, white supersoft (2pcs) = Standard
RA2073W Rear wheel white complete, red soft (2pcs)
RA2074W Rear wheel white complete, yellow medium (2pcs)
Je t'ai vu Hérétic , c'est beau hein ??!!??
capté...:apploo:
sinon la j'ai un peu besoin de sous, alors j'en profite pour passer une 'tite annonce:
VDS cause scalpel, ma mère, tbe , entretien irréprochable, toutes options.
Faire offre ou m'envoyer sur le champ une scalpel toutes options comme sur la photo, AVEC LES JANTES BLANCHES, hein mat ?
pour les fdp on s'arrange....
IB1400's
Novak Micro GT
GWS 4RII rx
Hitech SRX tx
HS-81MG
Stock Scalpel Motor
Robitronic introduce the first real 1/18 electric Pan Car ever.
This ultra-lightweight Pan Car-Style Chassis contains a High Performance POWER 300 Motor and is prepared for a 4 Cell-Battery-Pack. The high efficiency Drivetrain, the ultra low Point of Gravity with a GT-Style-Body with high Downforce, the ingenious Suspension and the Factory-glued Foam-Tires makes this Car into a Rocket on the Track.
http://www.robitronic-usa.com/images/content/scalpelinfo1_k.jpg
Features
• High efficiency Drivetrain
• 1.5mm Carbon-ultralight-Chassis
• 4 Cell Layout (2/3 A batteries)
• Ultra-low point of gravity
• Fibre-glass Anti-roll Antenna
• Servo post fits standard micro servo
• Fully adjustable Carbon-Suspension-Arms
• Fully adjustable Friction-Plate Dampening-System
• Adjustable Rear-Shock
• Adjustable Tweak of T-Bar with Set Screws
• CNC-Aluminium Gear-plates
• Adjustable Ride-Height
• Adjustable Heavy-Duty Ball-Differential
• 3 different Spur-Gears and 8 Pinion-Gears included
• Easy Quick-Release Battery-Mount-System
• Preglued and sanded Foam-Tires on Rims
• Robitronic POWER 300 High-Power Motor 4.8V
• Ultra-Low GT-Style Racing Body
Specification
• Length: 180mm
• Width: 110mm
• Wheelbase: 129mm
• Height: 55mm
• Weight: 320g
• Battery (not included): 2/3A 4cells
• Servo (not included): Micro-Servo (30x12x30mm)
More pictures
Source : Robitronic
Bonjours,
Tout et dans le titre "Que penser vous de la Robitronic scalpel 1/18 eme"
Comportement, fiabilité, ou trouver des pièces etc. etc.
Merci de vos commentaires
A+:D :D
Bonjours,
A+:D :D
Je vais te répondre le plus honnetement possible.
Comportement: ca doit tenir super bien le pavé vu que toutes la caisse est une 1/12° reduit au 1/18° (donc legerement plus petit!) et donc avec des epures de suspension vu et archi vu.
Fiabilité: Pas encore de retombés mais les piéces qui se vendent le plus sont l axe et les pieces composant le train arriére (Te, support de cellule).
Ou Trouver des piéces. Facile RMD (Importateur Team Associated)étant l importateur de la Marque Robitronic en France, il travaille avec de nombreux revendeurs en France dont nos Partenaires SMS (select model shop) et MilleniumRC. Donc très facile d avoir de la piéce.
Maintenant je te donne juste mon avis, la Scalpel ressemble a une 1/12°, se comporte comme une 1/12° coute aussi cher qu une 1/12° mais avec les inconvenients du 1/18°, pack specifique, moteur specifique etc...
Bref pour le meme prix qu une 1/12° tu auras un matos qui sera a usage unique (que pour le 1/18°) et des perfs legerement inferieur a une douze et le jour ou tu voudras t essayer au 1/10° piste ou TT, tu seras obliger de racheter du matos pour pouvoir rouler.
En Gros, achete toi plutot une 12!!:P;)
Just my 0.2$
à sa sortie, j'avais réalisé un article sur celle-çi ;)
les bilans sont en balance avec la réalité, assez difficile a mettre au point, surtout au niveau des pneus, ils ne sont pas regulier, c-a-d que lorsqu'on les traitent, ca marche pas les 3-4 premiers tours, puis elle est scotchée pendant +/-10 tours, puis elle tourne plus.
fragilité au niveau du Té arriere, beaucoup de jeu dans les fusees avant, et dereglage chronique du plateau de friction superieur, le diff est assez difficile a regler.
l'article en question ;)
http://www.demiweb.be/MRCH/dossiers7.htm
Salut DT10D Je te remercie pour ta réponse et ton avis mais la scalpel je l'ai déjà ainsi qu'une Trinity 1/12 et 2 TC3 pour faire cour.
Salut Nondidju toi aussi je te remercie de ta réponse et on a fait les mêmes constatations que toi sur le jeu des fusées et l'axe du plateau de friction supérieur 2 de casser sur 3 voitures par contre pas de problème avec le diff.
a+ ;) :applo: :D
No. RA2105 Lolita Body
The new Body for the Scalpel is very low to the chassis and the big spoiler at the rear makes a lot of downforce. The Body is for the 4 Cell Kit and for the 6 Cell Chassis.
No. RA2201 6-Cell Chassis
2mm Chassis with 6 Battery Slots for low center of gravity. The wheelbase moves from 130mm to 142mm. This is also for a better performance at long straights.
R/C Madness Micro On-Road Nats
http://www.robitronic.eu/
Robitronic Scalpel gets the 3rd place with the Driver Wesley Dennis at the US Micro On Road Nationals.
Wesley Dennis used a near Kit car with 4 Cells and a Brushed Motor.
Robitronic has released these hot new red-anodized, machined-aluminum upgrades for the Scalpel. Shown here are the 4-degree A-arm set, steering knuckle set, bumper plate, universal servo mount set, antenna mount, rear wheel adaptor (left), and right side diff plate. A titanium axle is also available to reduce rotating mass. Install these upgrades and you’ll have the sharpest (pun intended) Scalpel at the track.
Aluminum
A-Arm set 4-degree – Item no. RA2082; $41
Steering knuckle set – RA2085; $45
Antenna mount – RA2099; $25
Universal servo mount – RA2086; $32
Bumper plate – RA2083; $21
Diff right side – RA2102; $15
Rear wheel adapter set (left) – RA2084; $10
Titanium rear axle – RA2087; $25
http://www.rccaraction.com/ME2/dirmod.asp?sid=&nm=&type=news&mod=News&mid=9A02E3B96F2A415ABC72CB5F516B4C10&tier=3&nid=986DD8F29B1E4C99A582A0B21CAD6F1F
Est- ce que quelqu'un sait ou trouver ces deux références en France ? MP !merci !:youpi:
merci reporter !
au passage; les dimensions données dans l'article sont un peu fantaisistes : je mesure 128 mm d'empattement, et en gros 110 mm de voies AV et AR.:carre:
edit : houlà j'avais pô bien vu , sorry !
sinon merci nocif pour l'info, je pensais plutôt à un magasin de vpc, à moins que rmd ne vende aux particuliers?
