teovich
Les modèles de radios à manches
129 posts in this topic
Cover the Universe FASTER!
The long awaited Esprit III Universe is the next evolution in the Esprit series. New updates in performance bring it along side the EX-10 Helios plus more new functions. The new era of fast CPU speeds is here.
The recent World Championship and TQ titles by David Spashett (Team Corally) in 1/12th scale and Andy Moore (Hot Bodies) 1/10th Touring prove that the Universe is here for the taking.
Esprit III Universe Tx/Rx (KR-302FS) FM 27MHz # 80301
Customize to your driving style!
This computerized three channel radio has an impressive list of features that are found in the EX-10 Helios, plus more! Continuous developments in computer technology have led to radio control transmitters incorporating much of this sophistication.
The new Custom Menu feature allows for the use of the functions that you are going to use. No more searching for functions that you want to use! Add, delete, prioritize the functions. The navigation of the menu is relatively easy with the use of the jog dial. The exquisiteness of the arrangement of the jog dial and the command key utilize the highest ease of use. The navigation between functions, increase and decrease of specifications are easy to understand and the simplicity is clear, yet at the same time feasible.
The new development of the multi angle stick allows for moving of the steering and throttle control stick to your preference for true comfort. Up to 40 degrees in stick movement is possible. The new development adds luxurious structure to traditional mechanical restrictions allowing for a driving experience that is not impaired.
Audible warnings can be custom set and created to differentiate from other users and to be assigned to functions. The comprehensive instruction manual leads you through initial setting up if you want to change from the factory presets, right through to incorporating every feature available.
With four speed settings, (Normal, Super HSR, Advanced HSR, Ultra HSR) all current KO receivers can be used regardless of servos being digital or analog.
New features include third channel mixing, third channel travel, channel program mixing, steering travel preset, tilt mixing, idle up and brake mixing. Ideal for 1/5th scale racers, boats, rock crawling, or any application that will demand these features.
Feature are listed below.
Steering Functions: Travel / Balance / Speed (1~2Way) / Curve / Center Trim / Sub Trim / Trim Rate / Reverse / Tilt Mixing / Steering Travel Preset
Throttle Functions: High Point / Brake / Curve / Punch / Speed (1~3Way) / Acceleration / Active Brake System (ABS) / Preset / Automatic Start / Sub Trim / Trim Rate / Reverse / Idle Up / Brake Mixing
Timer Functions: Up Timer / Lap Timer / Down Timer / Alarm / Pre-alarm / Lap Navigation / Operation Timer
Others: Customized Menus / Mode Settings (Ultra/Advanced/Super HSR, Normal) / Auto Display / Backlight Screen / Customizable Ringtone Melodies / Position Display / Direct Set / Electrim / Digital Grip Dial / Battery Alarm / LCD Contrast / 9 Model Memory / Model Name / Model Select / Model Copy / Memory Recall / Memory Restore / Memory Reset / Channel Select (for use of channel 3) / Beeper Pitch Shift / Adjust Volume / Set Up / Channel 3 Travel / Channel 3 Position / Program Mixing / EEP ROM / Output Resolution (PPM 1024STEP)
More info
Source : KO PROPO
C'est surement mieu que de ne pas avoir de news du tout...
Encore une new que je ne lirai pas car je n y comprend rien.
En meme temps pour comprendre les fonctions dont elles disposent faut pas un dictionnaire non plus!!!
Mais si vous avez du temps pour nous aider a traduire les textes de toutes les news que nous recevons chaque jour vous etes le bienvenu a bord. :rolleyes:
En résumé :
Elle est plus mieux que celle à volant (EX-10 Helios) car plus rapide sur son interface et programme plus aboutis.
Quelqu'un a t il tenu dans ces mains la nouvelle KO ?
Vos impressions par rapport à l'Esprit 2 ?
Merci.
Voila, ma chère C4R de 1989 a grand besoin de repos, et j'aimerai m'offrir une radio de compet. Mais determiner les besoins est delicat quand on est novice... Mon 501x merite du bon!
Alors futaba 3vc, 3vcs, a synthétiseur, a spectrum, a module... Sanwa gemini2, super exzes... Ko esprit 2, 3, z'...
J'aimerai juste pouvoir orienter les sticks...
Si les possesseurs de ces radios pouvaient m'aider a me decider, je serai ravi!!
merci a tous.
A manches, la plus récente est la esprit 3 tout juste reçue par RB
et en plus elle fait mirroir, très pratique pour se remaquiller sur le podium!!
moi j'adore la 3VCS et vraiment complete...
Merci Maxoo, mais pour de la compet à un niveau somme toute assez pietre(!) est ce qu'une 3vc ou 3gr ne suffit pas? En fait qu'a t'elle de plus la VCS?
j'ai la Futaba 3GR à synthétiseur de fréquence et franchement, à mon humble niveau, il n'y a aucun réglage qui manque (exponentiel sur accél, frein et direction, ABS, trim digitaux, possibilité de garder en mémoire différents réglages etc...) ! Elle est vraiment pratique et pas trop chère. Et puis avec le synthétiseur de fréquence, plus besoin de quartz !! :youpi:
Merci Korben. C'est clair que l'absence de quartz est un plus...fiabilité? top radio? j me demandais aussi quelle etait l ataille du recepteur, s'il etait micro ou juste petit dans une moyenne...
Pour la fiabilité, pour le moment rien à redire : tout marche correctement (j'ai cette radio depuis environ 6 mois, utilisation en TT 1/10 électrique en salle et en extérieur). J'ai très rarement des tops radio, pas plus souvent qu'avec mon ancienne radio à quartz...
En ce qui concerne la taille du recepteur, elle est dans la moyenne (celui que j'ai est le R303FHS)
Korben une derniere chose, ets il possible d'adapter ensuite un module spectrum ou futaba?
Non, à ma connaissance, ce n'est pas possible : il n'y a pas d'emplacement pour ajouter un module...
Merci pour ces quelques infos sur les futaba.
Mon choix va se faire entre des modèles qui acceptent les modules, pour evoluer plus tard:
3vcs, Exzes plus, et Esprit 3.
Y a t il des points qui font que l'une est vraiment au dessus?
Ensuite, j'ai vu que ces radios existaient en 2 frequences: 27 et 40 mghz.
Pourquoi choisir l'une plutot que l'autre? encombrement? top?
Merci à tous...
La fréquence ne joue pas sur la taille; Seule l'esprit 3 est dispo en 26 et 41; Le 26 peut éventuellement éviter les top avec certaines électroniques novak
Merci à tous...
moi je commence en 1/10 piste electrique avec ma 3PKS (a synthèse avec module) que j'utilise depuis 2ans en bateau d'endurance et franchement il manque aucun reglage sur cette radio, vraiment super:applo:
Merci CB mais je parlais d'emcombrement des frequences lors des compets!!! :youpi::youpi:, enfin c'est sympa de m'avoir repondu!
Pour la prise en main, définitivement KO propo...
Teovich, tu veux parler d'ergonomie ou de facilité de reglages?
merci!-buveurs-
idem : ergonomie = KO
Pour avoir des manches orientable en KO, c'est forcément l'Esprit 3. Idem pour le spektrum. En Sanwa, ça existait aussi sur la Super Exzes (orientation mache et Spektrum). Par contre, défaut sur la Super Exzes, le dual rate est commun à toutes les mémoires (Je ne sais par sur la Plus).
euh??? c'est quoi le dual rate, et a quoi cela sert il??
