Sign in to follow this
Followers 0
AME T-Shox V2
1 post in this topic
AME T-Shox V2
First item which hits the market in the new found cooperation between
AME and RUDDOG Distribution has arrived. The T-Shox V2.
The T-Shox V2 has been completely redesigned with 100% new parts but
with the same principle using a through going shock rod with 2 guidance
shims.
A better guided shock rod giving you a more consistent and smoother ride.
The piston moves perfectly through the shock body keeping the oil flow
perfect during the complete dampening movement.
Perfect zero rebound every time you build the shocks to be sure that all
four shocks will be built the same.
The smoothest ride you have ever had with any std design touring car on
the market.
New features:
- Big bore shock body
- High grade silicon pressure compensation bladder
- New silicon sealing o-ring
- New guidance shims
- Pre-mounted piston and shock rod for a play free piston
- Easier to build
- T-Shox assembly tool included
1 person likes this
Followers 0
