Sign in to follow this
Followers 0
ciol77
RC10F6 Factory Team
6 posts in this topic
RC10F6 Factory Team
RC10F6 Factory Team
1:10 Scale Electric 2WD On-Road Competition Race Car
Team Associated is proud to release its entry to the 1:10 scale 2WD electric formula car racing class, the RC10F6 Factory Team Kit, geared for precision and the ultimate in performance.
Full-scale Formula racing is considered one of the most elite forms of racing in existence, with technology and looks off the chart. The engineers behind the doors of Area 51 put maximum effort into the design of the RC10F6 FT kit to make sure the same could be said about their scaled-down version. With a full cast of setting options, an ultra-low center of mass, and sleek styling, the RC10F6 FT is designed to put you at the front of the Formula grid.
With an increase in entries greater than any class at the highly contested ETS series, Formula is growing at a rapid rate. All aspects of the RC10F6 FT were considered and optimized to make sure it would stand above its competition. Performance, adjustability, durability, and style were weighed heavily, and the RC10F6 FT kit shows its hand with a complete package of adjustments and options right out of the box. From front to back, with graphite control arms, the fully adjustable front end, the ultra-smooth rear pivot, and wings styled after current full-scale Formula rulings, no corner was left untouched. At an affordable price point, the RC10F6 FT comes with everything to assure you will be at the front of the pack. With such a well-balanced platform, it's easy to see that the RC10F6 FT kit is another Champion by Design from Team Associated!
This vehicle needs extra parts to make it operational. Click on the SPECS tab above to see what extra equipment you'll need to make the vehicle operational, such as motor and battery pack.
Prototype shown. Due to ongoing R&D, photos may not match final kit. RC10F6 Factory Team Kit shown on these pages equipped with items NOT included in kit: Reedy motor, battery, ESC, servo, receiver, wheels, tires, body, and pinion gear. Assembly and painting required.
Features
  • 2.5mm graphite chassis for optimized flex characteristics
  • Front and rear wings modeled after 2017 Formula rules included
  • FOX(R) Genuine Kashima Coat center shock for minimal friction and extended wear
  • Chassis design allows for multiple battery configurations
  • New center pivot design for optimized rear pod assembly
  • Lightweight graphite axle for increased durability and rigidity
  • Differential thrust bearing assembly for smooth action and extended life between rebuilds
  • Rear axle accepts all standard spur gears without adapter
  • Two steering bellcrank options for fine tuning Ackermann and steering rate
  • Servo mounts can be switched from "fixed" to "floating" to allow more flex in the front of the chassis
  • Integrated droop posts for adjusting droop without disassembly
RC10F6 Factory Team
Part # Description Price Buy
8023 RC10F6 Factory Team Car Kit
MSRP: $499.99
Web: $339.99
Out of Stock
NOTIFY ME WHEN IN STOCK:
Video
Product Brochure
PR-Docs_013017_RC10F6-Kit.jpgsource site team associated
1 person likes this
Il y a 20 heures, steenarigno a dit :
C'est beau... très inspiré X-Ray...
  Stéphane.
yop steph,tu trouve ?? j'ai beau chercher je trouve que ce sont quand même deux chassis bien different,bon en même temps comment ne pas avoir deux f1 qui se ressemble surtout que la xray marche fort ,donc a voir ,mais je compte bien le savoir tres vite
lolo
2 people like this
LOL, oui en regardant de près et en affinant : la triangulation av fait stt penser à la Roche, qui marche fort d'ailleurs... L'originalité, je trouve, vient des "renvois" latéraux en carbone au-dessus des links... La platine servo est la clone en look de la X-Ray...
Tu vas t'en prendre une ?
Moi, je reste fidèle à X-Ray : qualité et compatibilité des pces... et puis en TT, pro Losi dc Asso pas good LOL !!
  Stéphane.
yop
yes steph je m'en prendre une ,moi c'est asso aujourd'hui j'ai mais periode ou full asso ou full schum la je suis en mode asso ,
loic
1 person likes this
Followers 0
