Sign in to follow this
Followers 0
Awesomatix A800 - first look
1 post in this topic
The new Awesomatix A800 is hitting the stores shortly and soon many new lucky owners will enjoy it.
It is a departure of the shaft driven layout following now the trend of 2 belt driven cars.
Although a proven choice, Awesomatix has chosen to explore even further the posibilities to improve weight distribution and maximize the performance potential of the car.
By placing the spur gear on the right side (battery side) of the car, it allows to put the motor by 2mm further to the centre of the car as well as give direct access to the spur gear without the requirement of removing belts or upper deck. More on this later.
The entire transmission has been designed with the goal to be the lightest and most efficient possible. Low friction belts and pulleys help to achieve these goals as well as better reliability is achieved through the use of specific materials and well thought design.
Three chassis options are available. Here you can see the two of them. The one on top is a very nice aluminium hard anodized scratch resistant chassis with a lot of milling and a 3D shape where a concave effect is visible at the bottom of the chassis. This has proven to perform very well in many different conditions on carpet racing.The carbon chassis is a standard design with symmetrical milling on both sides of the main axis to produce even flex characteristics
Source: JD & RACING
Followers 0
