Sign in to follow this
Followers 0
philippe27
A-t-on deja parlé de ce Rc 1/10 Gambado NAKED ???
1 post in this topic
ABC Hobby Gambado NAKED rcMart Limited CFRP Ver. 1/10 Mini FF EP Car Kit Now Available @rcMart~
http://blog.rcmart.com/rc-abc-hobby-gambado-naked-rcmart-limited-cfrp-ver-110-mini-ff-ep-car-kit-now-available-rcmart/
11228037_10153570010387008_1249022936282
Brought to you exclusively by rcMart, ABC Hobby Gambado 1/10 Mini FF EP Car Kit is now available to be ordered outside Japan!!! This NAKED rcMart Limited CFRP Ver. Car Kit will bring excitement to both hobbyist and racer who loves to see what M-chassis is really capable of.
Here are some details of the car kit:
Vehicle Specification:
  • Drive Train: Front Wheel Drive
  • Suspension: King-pin Strut
  • Differential: 4 Bevel Gears
  • Chassis: CFRP
  • Damper: Oil
  • Steering: Crank Type
  • Overall Length: 285mm
  • Width: 160mm
  • Weight: 1050g
  • Wheelbase: 208 – 210mm
  • Ride Height: 3 – 8mm
  • Caster: Adjustable
  • Toe: Adjustable
  • Camber: Adjustable
  • Gear Ratio: 3.8:1 – 8.5:1
Option Parts Included:
  • CFRP Main Cassis
  • CFRP Upper Deck
  • CFRP Front Upper Mount
  • CFRP Rear Upper Mount
  • 7075 Aluminum Motor Mount (rcMart Limited Ver.)
  • Aluminum Accuracy Oil Damper
  • Titanium Coated Kingpin
  • Steel Spur Gear Shaft
  • Steel Counter Gear Shaft
  • Steel Turnbuckle Set
Limited availability for customers who have not pre-ordered, so please be quick to grab one!!!
Check it out here now: http://goo.gl/DEQB4S
Grab your ABC Hobby M chassis body here : http://goo.gl/SFLhM0
Others M chassis body: http://goo.gl/ZJL5TA
11889466_10153570010752008_1396431697048
11880501_10153570010402008_8744303689265
11057246_10153570010422008_2157626573344
11935006_10153570010487008_8482942001345
11960128_10153570010462008_5788834850854
11940705_10153570010347008_4912203660709
11960168_10153570010452008_8083821456186
11095389_10153570010637008_3225442726618
11880367_10153570010707008_5486063283425
11951321_10153570010802008_4215489725534
11880501_10153570010737008_7559942812219
11960219_10153570010712008_5564816692365
11061229_10153570010777008_5822463057120
11947507_1017593164939328_48806661132785
11896252_1017593158272662_89939184534918
11891178_10153570010822008_7856608781111
11959964_10153570010427008_3059636295004
Followers 0
