Sign in to follow this
Followers 0
philippe27
ça va tout peter Wasteland 1/18 4WD RTR Vehicles by Dromida
1 post in this topic
Ajoutée le 7 oct. 2015
No terrain is off-limits when you drive a Wasteland! These factory-assembled, fully-equipped electrics have everything you’ve come to expect from a Dromida vehicle, including full-time 4WD for top-notch traction and power distribution.
The foam dart launcher, however, is what makes these RTRs stand out. You read that right – a foam dart launcher! Just ready, aim and fire at your opponent’s vehicle, and watch the dart fly up to 30 feet in the air. It’s extreme futuristic fun for everyone, made impressively affordable!
The Buggy and Truggy are 100% ready-to-run, with a powerful motor, ESC, 3-channel radio system, 100-240V AC charger and all required batteries included. They’re also waterproof, so you can take either Wasteland through the elements – and watch if come back for more apocalyptic action.
• Launch foam darts through a 3rd channel on the transmitter.
• Big Bore oil shocks.
• High-traction, pre-glued tires with foam inserts.
• Independent steering servo with servo saver.
• Four-wheel drive.
• Waterproof electronics.
• Gear differential.
• 100-240V AC charger included.
• Radio system.
• Factory-painted body with pre-applied decals.
Both require: Nothing!
Buggy Specs:
• Length: 10 in (254 mm)
• Width: 7 in (177 mm)
• Height: 5 in (127 mm)
• Weight w/battery: 1.49 lb (678 g)
Truck Specs:
• Length: 11.5 in (292 mm)
• Weight w/battery: 1.64 lb (744 g)
Look for Dromida RTRs at: http://www.dromida.com.
Followers 0
