philippe27
ABC Hobby Gambado 1/10 FF HONDA CR-Z Grid M Chassis Touring Car Kit #25600
1 post in this topic
http://www.abchobby.com/productimg/gamb/pre.html
photo01.html
http://www.abchobby.com/productimg/gamb/photo01.html
http://www.abchobby.com/productimg/gamb/photo02.html
http://www.abchobby.com/productimg/gamb/photo03.html
http://www.abchobby.com/productimg/gamb/photo04.html
http://www.abchobby.com/productimg/gamb/photo05.html
http://www.abchobby.com/productimg/gamb/photo06.html
http://www.abchobby.com/productimg/gamb/photo07.html
http://www.abchobby.com/productimg/gamb/photo08.html
ABC Hobby released information on their new Gambado called 1/10 scale electric 2WD on-road chassis. The FWD (front wheel drive) chassis features a plastic composite chassis plate to which the front and rear McPherson strut suspension attaches. The springs sit directly on top of the pivot ball wheel carriers with friction dampers attached to the lower wishbones. The front-mid mounted motor sits in-line with the chassis roll axis and drives the front tyres. The stick battery pack, steering servo and receiver/speed controller are located in the middle to rear part of the M-size chassis. The Gambado comes as kit without electronics and an unpainted Honda CR-Z bodyshell.
Technical data:
- Front wheel drive
- Gear differential
- Length: 285mm
- Wheelbase: 208mm - 210mm
- Width: 160mm
- Ground clearance: 3mm - 8mm
- Weight: 1050g without body
Link: ABC Hobby Gambado with CR-Z body shell
Vehicle Specification:
Drive Train: Front Wheel Drive
Suspension: King-pin Strut
Differential: 4 Bevel Gears
Chassis: Plastic Tub
Damper: Friction
Steering: Crank Type
Overall Length: 285mm
Width: 160mm
Weight: 1050g
Wheelbase: 208 - 210mm
Ride Height: 3 - 8mm
Caster: Adjustable
Toe: Adjustable
Camber: Adjustable
Gear Ratio: 3.8:1 - 8.5:1
Include:
ABC Hobby Gambado 1/10 FF M Chassis Touring Car Kit (1 Set)
Clear Body (1 Set)
Wheels & Tires
Decals
Instruction
Require:
540 Motor
ESC
Radio
Servo
Battery & Charger
