Revolution Design B5RM/MM Multi Option Front Bulkhead Aluminium Set
1 post in this topic
<IMG src="http://www.revolution-rc.com/files/cache/fancy/rdrp0252-1__950x713.jpg" width="600">
The new Revolution Design Racing Products B5RM/MM Multi Option Front
Bulkhead Aluminium Set is made to replace the standard plastic composite
bulkhead in B5, B5M and T5M kits with a heavier and more rigid part in
order to adjust the vehicle's weight distribution while adding
durability at the same time. The part is made from high-quality 7075-T6
aluminium material and it comes blue anodised and laser-etched for easy
identification. Included is also an aluminium front suspension pin brace
to round out the factory look and to help add rigidity and precision.
While the slightly heavier part shifts the weight distribution to the
front of the vehicle in order to reduce wheelies on high-bite surfaces
the metal bulkhead also helps to calm down the front end on bumpy
surfaces and it can help adding steering in low-bite conditions. On top
of that the included delrin bulkhead inserts allow to run 25 degree or
30 degree wishbone kick-up to further fine-tune the steering
characteristics without having to swap the whole bulkhead.
RDRP0251 RDRP B5RM/MM Multi Option Front Bulkhead Aluminium Set
More details -> http://www.petitrc.com/_forumphp/showthread.php?67798-Team-Associated-B5-nouvelle-plateforme-4x2
Guest
