philippe27
Chargeur puissant SKYRC Ultimate 1000W/40amp
7 posts in this topic
SKYRC Ultimate 1000W features with high efficiency with synchronous rectification technology, it is accurate and stable and also has some new features and functions. Users could set the terminal voltage by themselves and connect it to PC for PC control and firmware upgrade. What's more, users could also use it as Lithium Battery Meter and Lithium Battery Internal Resistance Meter. There are Automatic Charging Current Limit, Capacity Limit, Temperature Threshold and Processing Time Limit which makes the charger safe to use
Weight 1240g
LiPo/LiFe/Lilon/LiHV Battery Cell Count 1-8S
DC Input Voltage 11-30V
Charge Circuit Power 1000W
Charge Current Max. 40.0A
Balance Port Charge Current 10-500mA
Discharge Circuit Power 80W
Discharge Current 0.1-8.0A
Regenerative Discharge Current 0.1-40.0A
Current Drain for Balancing Max. 800mA
NiMH/NiCd Battery Cell Count 1-20S
Trickle Charging Current 50mA-300mA & OFF
Pb Battery 2-24V
Revised 2015-01-21
http://www.skyrc.com/index.php?route=product/product&product_id=203
ca c'est du lourd en puissance par contre pas d'idée du prix face à un graupner
C'est plutôt l'alimentation de 1kw qui va piquer les yeux.
double alim serveur hp 575 w x2 , moins de 50 euros. 24 v 1150 w
Tres repandu en modif sur forum helico
Perso j ai une double dell 1400 w cout de reviens de moins de 80 euros et c est super stable 57 amp en 12 ou 24 v
http://www.cyber-astuces.fr/modif-alimentation-serveur-dps-600pb
Voilou pour moins de 60 euros en double.....
Merci supernova mais je connais l'astuce.
ma question est toujours la même.
si un expert des chargeurs passe dans le coin
