philippe27
Ripmax Micro Stunt Car EP RTR 2.4GHz
2 posts in this topic
This Ripmax Micro Stunt Car is perfect for indoor use. With the built in moving chassis suspension system this car is more than up to use on home made jumps and racetracks. The battery is built in and can be charged from the transmitter with ease.
The 2.4GHz transmitter has 2 settings. Like a traditional RC car you can use the throttle and steering normally but when you enter scale mode it has optional digital gears. Gears 1-5 are indicated by LED lights on the transmitter and each limit the power as you use them. Set it in first gear and get used to the controls then 'let it rip' as your power increases when you go up the gears!
• Includes 20 course cones (10 red & 10 blue)
• Scale speed setting with digital gears
• 2.4GHz Radio
• Moving chassis suspension system
• Available in Blue, Red or Black
Requires: 4x 'AA' Batteries for the transmitter
Download the Manual
in PDF Format (.PDF)
Specifications
Modulation: 2.4GHz
Length: 120mm
Height: 49mm
Weight: 60g
Radio System: 2 Channel (Inc.)
Wheel Base: 75mm
Width: 83mm
http://www2.ripmax.net/Item.aspx?ItemID=C-RMX0040&Category=040-110
http://www2.ripmax.net/Instructions/C-RMX0040.pdf
