philippe27
Ripmax Coyote 1/18th Truggy EP
1 post in this topic
At 1/18th scale size, the Coyote is capable of being used both outdoors in the rough and indoors on carpets. Don't be fooled by the compact size, the Coyote packs quite punch, thanks to a powerful 370 class, brushed motor and 6 cell 1300mAh Nimh battery.
Getting that power down onto the surface comes courtesy of the rugged 4 wheel drive system and great suspension. You even have differentials in the front and rear gearboxes like the big 1/8th racing buggies. The four shock units are oil dampened just like the biggers cars too! The electronic unit incorparates the ESC (electronic speed controller) and 2.4gHz receiver into one compact unit with the steering servo strapped to the underside, making a very compact installation.The steering servo incorporates a real 'servo saver' to protect the internal servo gears from damage. On the other side of the chassis (for balance) is a 6 cell 130mAh Ni-mh battery that delivers hard and reliable power to the durable 370 size brushed motor.
Just to add that final quality touch, the chassis is made from durable plastic. This strong backbone is the platform that everything else bolts too and is designed to take some serious 'knocks' when in use. All the wheels and gearboxes are ballraced for a long life and the suspension arms and drive shafts are designed to absorb shocks from impacts before finally failing. These sacrificial parts are very cheap to replace, getting you back in action very quickly. In fact, you'd be amazed how cheap all the parts are to keep your Coyote in tip-top condition.
Finally, the easy to hold and operate, 2.4ghz transmitter has trims for both steering and throttle as well as 'Dual rate' function for the steering to help you learn how to drive precisely and with the feel you prefer.
The Coyote is certainly a great way to get into R/C cars and at a price that puts her within everybody's reach!!
• Factory-Built with Fully Proportional 2.4GHz Radio Control
• Powerful Motor for Amazing Performance
• 4 Oil-Filled Adjustable Shock Absorbers
• High Capacity Ni-MH Battery Pack and Charger
• Combined Receiver and Electronic Speed Control
• Independent and Adjustable Suspension
• Powerful 9g Steering Servo
• Tough Metal Chassis
• Heavy-Duty Suspension Links
Note: Prototype Shown, production may be slightly different.
PDF Logo Download the Manual
in PDF Format (.PDF)
PDF Logo Download the German
Manual in PDF Format (.PDF)
Specifications
Length: 295mm
Height: 103mm
Servos: 1x Mini 9g (Inc.)
Radio System: 2 Channel 2.4GHz (Inc.)
Electric Motor: 370 Class Brushed (Inc.)
Wheel Drive: 4WD
Ground Clearance: 22mm
NiCad/Ni-MH: 6 Cell 1300mAh Ni-MH (Inc.)
Speed Controller: Brushed (Inc.)
Wheel Base: 165mm
EUR&Category=040-033#
http://www2.ripmax.net/Item.aspx?ItemID=C-RMX0050/EUR&Category=040-033
http://www2.ripmax.net/Instructions/C-RMX0050-EUR.pdf
autres rc 1/18
http://www2.ripmax.net/Category_List.aspx?Category=040-033
