philippe27
GForce Mini Break-in system
1 post in this topic
GForce introduce the Mini Break-in system for mini and micro-size brushed motors. Designed for the use with Tamiya’s Mini 4WD series of “slot cars”, the system is also usable for the brushed motors found in Kyosho’s Mini-Z or HPI’s Micro RS4 line of vehicles. The motor run-in system is housed in a sturdy case with a jog dial to adjust the output voltage and also a timer that stops the run-in process after a certain time. A non-slip foam pad and a velcro strap prevent the chassis or motor from moving around and the break-in device is powered by four AA-size batteries or an optional power supply.
Specifications:
– Dimensions: 112x47x45mm
– Input: 4.8V-6.0V
– Output: 0.1V-6.0V
– Timer for run-in function
– LCD display
– Jog dial for menu operation
– Pre-wired with crocodile clamps
http://www.gforce-hobby.jp/products/G0121.html
