philippe27
off-road Dromida DB4.18 Desert Buggy e Desert Truck 1/18
2 posts in this topic
http://www.dromida.com/surface/videos.html
http://www.dromida.com/surface/photos/index.html
Ready for the beach or backyard, day or night!
Where you want to go doesn’t matter – the DB4.18 can get you there fast! Everything you need for your first run is already in the box — and virtually everything that needs to be installed is already on the chassis. Insert the “AA” batteries in the 2.4GHz radio, charge and install the NiMH battery pack — and your work is done!
Waterproof electronics means that you can run on dirt, sand, wet grass and even snow without worry. And with LED lights to show the way, you can run all day and into the night.
The DB4.18 RTR includes:
Fully assembled vehicle
Finished body
Factory-installed motor, steering servo & receiver/speed control
D100 2.4GHz radio system with trims and dual rates
6-cell, 1300mAh NiMH (Nickel-Metal Hydride) battery
AC charger & charge monitor
(4) "AA" radio batteries
Features Radio Systems & Electronics Photos
DB4.18 RTR Desert Buggy (DIDC0045)
Length: 11.5 in (294 mm)
Width: 7.0 in (180 mm)
Height: 3.8 in (98 mm)
Weight w/battery: 1.45 lb (658 g)
Requires: nothing!
Hit the trail with LED brilliance and true truck looks!
Tough, fast, and fully assembled, the DT4.18 comes out of the box ready to conquer the roughest country around. It’s more than complete; it’s also loaded with performance extras most start-up trucks can’t match. There’s an M370 motor for 20+ mph straightaway speeds, plus a fully adjustable suspension, Big Bore oil shocks and multiple mounting options to tame the worst turf. Dual rates on the 2.4GHz radio make it a great truck to learn on and more fun to drive when you’re ready.
The DT4.18 RTR includes:
Finished body
[ Check out the review by Everything CPO ]
DT4.18 RTR Desert Truck (DIDC0046)
Length: 11.8 in (302 mm)
Width: 6.9 in (176 mm)
Height: 5.0 in (129 mm)
Weight w/battery: 1.49 lb (680 g)
Requires: nothing!
http://www.dromida.com/downloads/index.html
Entrambi i modelli vengono forniti
Assemblati e pronto a correre
Carrozzeria colorata e adesivata
Radiocomando 2,4 GHz D100 a 2 canali
Regolatore di velocità e ESC Impermeabili
Motore brushed classe 370
Servosterzo impermeabile
1 batteria NiMH 6 celle 1300mAh
Caricabatterie
4 batterie “AA”
Desert Buggy 4WD DB4.18 RTR in scala 1/18
Lunghezza: 294 mm
Larghezza: 180 mm
Altezza: 98 mm
Peso: 658 grammi
Desert Truck 4WD DT4.18 RTR in scala 1/18
Lunghezza: 302 mm
Larghezza: 176 mm
Altezza: 129 mm
Peso: 680 grammi
