philippe27
Servos KawaTomo programmable
1 post in this topic
Programmable Circuit System
KAWATOMO
KAWATOMO HV Brushless Servo series could be considered as your first choice on the market. Programmable Digital Circuit , HV, Brushless Motor, Durable Steel Alloy Metal Gears.
These programmable servos only with the Kawatomo Programmer.
BG-0927WV
1/6, 1/8, 1/10 Buggy / Truggy, Crawler, Monster, Airplane.
Heli (EP / Gas Engine)
Particular Specification
Electrical Specification (Function Of The Performance)
Torque At 4.8V 18.6 kg-cm / 258.3 oz-in
Torque At 6.0V 21.3 kg-cm / 295.8 oz-in
Torque At 7.4V 27.1 kg-cm / 376.4 oz-in
Speed At 4.8V 0.13 sec / 60°
Speed At 6.0V 0.11 sec / 60°
Speed At 7.4V 0.09 sec / 60°
Apply Environmental Condition
Operating Voltage Range 6.0V ~ 8.5V ( 5 ~ 6 Cell Ni-MH or 2S Li-Poly & 2S Li-Fe)
Operating Temperature Range -20°C ~ +60°C ( -4°F ~ +140°F )
Control Specification
Control System Digital Controller / AD 12-Bits Resolution ( 4096 Steps )
Dead Bend Width 0.001ms (1us)
Mechanical Specification
Ball Bearing Dual, Stainless steel
Type Gears Durable Steel Alloy Metal Gears
Motor Type Premium Brushless Motor (Made In Taiwan)
Horn / Gear Spline 25 Teeth (Same as F-Type)
Outline Drawing
Dimension (mm) 40.5 x 20 x 38 mm / 1.59 x 0.79 x 1.49 in
Weight (gram) 66 ± 1 grams / 2.32 oz
http://www.blue-bird-model.com/KAWATOMO/Servos/BG-0927WV.html
http://www.blue-bird-model.com/KAWATOMO/Servos/BG-0622WV.html
http://www.blue-bird-model.com/KAWATOMO/Servos/BG-0310HV.html
