philippe27
News Servo BBM Full alu Low Profile servo
1 post in this topic
BLS-A910
Recommend: 1/8 、1/10th On-road Car & Heli 550 Class CCPM cyclic use, Aircraft
Particular Specification
Electrical Specification (Function Of The Performance)
Torque At 4.8V 10.9 kg-cm / 151.4 oz-in
Torque At 6.0V 13.6 kg-cm / 188.9 oz-in
Torque At 7.4V 16.4 kg-cm / 227.8 oz-in
Speed At 4.8V 0.080 sec / 60°
Speed At 6.0V 0.064 sec / 60°
Speed At 7.4V 0.052 sec / 60°
Idle Current 4 mAh @ 4.8~7.4V Stopped
Apply Environmental Condition
Operating Voltage Range 4.5V ~ 8.5V ( 4 ~ 6 Cell Ni-MH or 2S Li-Poly )
Operating Temperature Range -20°C ~ +60°C ( -4°F ~ +140°F )
Control Specification
Control System Digital Controller / AD 12-Bits ( 4096 Steps )
Dead Bend Width 0.001ms (1us)
Mechanical Specification
Ball Bearing Dual
Type Gears All Metal Gears
Motor Type Racing Brushless Motor
Horn / Gear Spline 25 Teeth (Same as Futaba)
Outline Drawing
Dimension (mm) 40.8 x 21 x 25.4 mm / 1.60 x 0.83 x 1 in
Weight (gram) 60.4 ± 1 grams / 2.13 oz
http://www.blue-bird-model.com/en/widevoltageservo/bls-a910.html
BMS-A900
Torque At 4.8V 10.4 kg-cm / 144.5 oz-in
Torque At 6.0V 13.8 kg-cm / 191.7 oz-in
Torque At 7.4V 16.5 kg-cm / 229.2 oz-in
Speed At 4.8V 0.091 sec / 60°
Speed At 6.0V 0.077 sec / 60°
Speed At 7.4V 0.065 sec / 60°
Ball Bearing Dual
Motor Type Racing Coreless Motor
Horn / Gear Spline 25 Teeth (Same as F-Type)
Outline Drawing
Weight (gram) 53.5 ± 1 grams / 1.88 oz
http://www.blue-bird-model.com/en/widevoltageservo/bms-a900.html
http://www.blue-bird-model.com/widevoltageservo.html
http://www.blue-bird-model.com/highvoltageservo.html
http://www.blue-bird-model.com/servo.html#1
