[SCOOP] Serpent Viper 977 turns electric
57 posts in this topic
Serpent will soon be introducing the next development stage in 1/8 scale electric powered onroad design. Being the 1st a few years back to introduce the purpose designed Serpent 966-e, we are now taking another big step to introduce the Viper 977-e.
Michael Salven as designer could focus fully on the central part of the car, as the Viper 977 suspension is well proven with the TQ and Wc win.
The new design takes into account the todays battery, speedo and motor technology and makes best use of it. The 1/8 speedo, 2 x 3S batteries and a 2000 KV brushless motor as complete package make the Viper 977-e accelerate like crazy and achieve very similar or even faster laptimes than gaspowered. Run-time is already close to 5.5 minutes as well.
We choose for the 2 x 3S batteries as those are easy to get everywhere, and enable playing with balance / weight well too.
Why run a 1/8 scale EP onroad racecar ? Well there are some reasons:
- The sheer speed and power
- No noise in tracks where this is an issue ( sometime only eveningtime )
- No mechanic / helper needed to race
- Cleaner 
- Just different , try something new
- Greener 
- Lower running cost is possible but depends on proper use of speedo and batteries
Key features
- Carbon fibre chassis 5mm and topdeck
- Carbon fibre battery holders / protectors
- Carbon fibre speedo plate
- 2 belt system with 5mm belts
- large pullies and ballraced belt tensioners
- Aluminium 7075 T6 motorholder and mid-shaft bracket
- 16T motorpully / 48T spur ratio
- Viper 977 front and rear suspension
For existing Viper 977 gaspowered drivers, we may also offer a conversion kit, so at end of season they can convert their GP 977 into EP to give it a try.
Final testing is in full progress and soon production can start.
Team Serpent
s'ils arrivent a trouver la solution a ce satane probleme de pneus a tourner, ca sera THE categorie.
magnifique là je dois dire que ça me laisse réveur cette chtite cocotte:=):
Oula elle a l'air pas mal.
On ne voit pas le dessus, mais si on cherche bien on arrive a découvrir l'implantation de la transmission a courroie vers l'avant et c'est ce qu'il fallait faire sur les 1/8 4x4.
En gros comme la EDAM 1/10 4x4 qu'on peut monter en 220mm.
J’achète vite elle sort QUAND ;) et qui la vendra sur le territoire ?
Sinon, date annoncée par l'importateur interrogé semaine dernière : fin juillet au minimum, plutôt septembre; Pas de prix pour le moment; J'en réserve?
Ca fait plaisir qu'un grand constructeur sorte enfin une "vraie" brushless en piste 1/8.
Par contre 16/48 le rapport ? Humm à voir, bon y a pas de boite mais elle à l'air bien light la petite.
Impatient de savoir sa dispo effective et le prix final.
Si jamais une photo du dessus filtre je serais curieux de la voir.
mouai:oh noes:, ils ont fait un peu "simple" quand meme!!! 2 lipos sur les exterieurs,un pack central aurait été bien vu genre c801el.
le chassis carbone bon j'avoue,bien bien...
mais ça sent le gros pavé de 3 kgs pour ceux qui tenteront 2*3s 5000mah,apres c'est sur que chacun trouvera sa config et ses accus sans se faire bouillir la marmite....
plutot jolie quand meme , a premiere vue.
....enfin on a pas encore la photo "vue de dessus" mais toute la transmission est décalée ce qui n est pas rien quand meme
Serpent Viper 977-e
1/8 scale electric onroad car
Key features
- Carbon fibre chassis 5mm and topplate 2.5mm
- Carbon fibre battery bolder / protectors, fully adjustable fits most 3S LIPO batteries
- Lipo packs mount on each side off center, very low and super balanced
- Aluminium 7075 T6 motorholder in center, easy to change motor
- Aluminium fan-holder to mount 2 small or one larger fan
- 14T motorpully / 48T spur ratio
- Viper 977 front and rear suspension and shocks
- Race-ready weight around 2600 to 2650 grams
Features:
Although the Viper 977-e is based on the Viper 977, it has a lot of features that make it a dedicated Electric racing car:
2 belt system with 5mm wide belts for optimized effectivity. Both belts have ballraced bel-ttensioners.
5mm stiff carbon fibre chassis in perfect symmetrical shape for even flex and weight distribution.
Countersunk holes, chamfered edges for more cornering, ground clearance. All screws from the bottom are with 2.5mm allen size.
2.5mm carbon fibre top-deck to create a strong and stiff connection between the front and rear-end of the car . The servo is mounted in the center of the car and can hold large and low profile servo’s. The center offers also space fo the receiver which can be glued to the small plate/ clips.
Strong carbon fibre battery holders, which can be easily adjusted to fit most popular 2S or 3S battery packs. The batteries can be moved more to the front or the back with the flexible mounting system. This can be used to change the balance of the car, to create more steering or grip. The low and central position of the batteries create the lowest and best possible CG.
Strong carbon fibre speedo plate, which fits most popular speedo’s well. The plate with speedo attached can be easily removed.
Smart machined aluminium motorholder in 8mm very durable unit, which can stand the enormous power of the brushless motors. It is also connected to the rear bearingblocks to create a stiff, yet flexible construction. The gearmesh is easily adjusted from the bottom of the car. The kit includes a 14T pinion, other pinions are available as options.
Middle shaft holder in 7075 T6 alumium to hold and support the mid-shaft and spur (14T/48T). This makes changing a spur gear a fast and easy affair.
Of course the 977E has most other features in common with the 977:
The strong aerodynamic shaped composite bumper comes from the 977 . The upward edges make it more stabile, so these wont touch the surface under impact or with high temperatures.
The durable alu front bodyposts are excentric , to allow moving the body to front or back a few mm to optimize steering / downforce.
The steeringblock , which can be mounted left or right, offers a system to change the axle position more to front or back giving a “trailing” or “leading” steering, and the ability to change the kingpin-inclination and offset.
The spring-steel steering-rods are fastened to the alu steeringplates, which mount to the new steeringblocks. Optional carbon fibre disks can be mounted on the side of the steeringblocks to stiffen the assembly and for aerodynamic reasons.
The steeringblock is right and left the same, and features an aluminum plate to connect the steering-rods, 2 options for Ackermann.
The long durable front lower wishbones, are mounted superlow in the car, and feature a semi covered “leg” for the inner suspension pin and the pivot link for the front anti-roll bar system, its also has an extension for the down-stop screw . The lower arms hold the lower alu shockmount plate, which allows a further out and higher mounting point for the front shocks. The strong upper arms can be used left and right. The front lower arms connect to the alu front bracket on very low nylon holders. The kit includes 2 versions, low and superlow. This system also enables you to replace a front driveshafts very quick and easy.
The longer upper arms are mounted between the anodized aluminum top brackets, which also hold the suspensionpin inserts to allow camber-change adjustments with 3 possible inserts . Below the alu top-brackets spacers can be used to change angle or height. Caster spacers are used as simple clips on the upper pivot pins. Same clips are also used on the lower pins to change wheelbase.
The topmounted composite bracket gives extra stiffness to the front section, it holds the 3mm thick carbon fibre front shocktower and allow for the down-stop screws.
The ballraced front anti-roll bar is a wire type, with very easy and fast open access on the front, captured in the alu front braces. The standard wire is 2.5mm and 2 other as options. The pivotballs link system directs the power to the bar in a smooth way and easy to adjust the tweak with the captured pivotball.
In the front the alu front axle with Japan-made one-way bearings features a free of play and super-true pully assembly . Springsteel drivecups, strong, long and thin spring-steel driveshafts with CVD system, and ballraced springsteel wheelaxles with alu quick-change levers. The open front end design allows for very fast and easy removal of the front axle or parts.
The springloaded servo-saver allows easy and fast Ackermann settings. The servo-saver features a top mounted insert which can be used in 3 positions. Another 2 Ackermann positions on the steeringblocks.
The steeringblocks and rear uprights connect to the arms with springsteel 8.5mm pivotballs , which run very smooth and well protected in nylon cups, and are easy to adjust with an allen tool.
All the supertrue pullies have holes in the side flanges to allow dirt and dust to move out easier.
The rear end construction with the alu brackets holds the rear axle. Its open design allows for eas of maintenance and cleaning, and needs very few screws to dis-assemble. Replacing a belt in case needed, is simple and very fast too. The excenter on the rear shaft allows for belt tensioning.
The ballraced rear anti-roll bar mount in steel adaptors, which run in nylon spacers in the alu holders as integral part of the rear brackets, with 2.5mm as standard wire and 2 other as options. The anti-roll bar links to the rear lower arms with adjustable trackrod guidance.
The solid rear axle with new lightweight 48T pulley in Serpent springsteel, 9mm wide with 4 slots for the pin.
The suspension bracket and rear plate hold the pins firmly and have composite roll-center inserts to allow for fast and precise changes.
In the rear strong springsteel driveshafts , springsteel wheel-axles with alu quick-change levers and a springsteel rear axle. Very durable and lasting drivetrain .
The long durable rear lower wishbones can be used left and right. The lower rear arm holds the low mounted link for the rear anti-roll bar and holds the alu mounting plate of the rear shocks, which allows a position which is very far to the rear and to the outside for best performance/ geometry. The lower arms also hold the easily accessible down-stop screws. Nylon clips are used on the lower rear pins to change wheelbase.
The durable composite uprights hold the ballraced spring steel wheelaxles, with aluminium quick-change levers. The 8.5mm piotballs are used to adjust camber fast and easy with the smooth hex-shaped plugs . The arms of the floating bodymount mount to the top of the uprights. On top of the up-right spacers can be added under the pivotball to change rollcenter and camberchange.
Optional carbon fibre disks can be mounted on the side of the uprights for aerodynamic reasons.
The adjustable rear upper camber links mount to the rear carbon camberplate with 2 positions .
The rear floating bodymount is mounted on the up-rights with 2 arms and held in place by a carbon-fibre-steel guider. The 2 arms have 2 positions to choose from, depending on body In use. The end of the mount allow for mounting body-supports , with full threading to allow exact positioning. The system leads the available downforce direct onto to the uprights to the tyres.
The kit features high speed ballbearings, mostly sealed ones with aeroshell lubrication or grease. All bearings in the car ( except for the servosaver and brakecam) are seated in nylon bushings to reduce vibrations and play.
The shockabsorbers are the latest Serpent RCM units with membrames. The threaded houses with setting-nuts ( or-ring inside) makes ride height changes easy and precise. The front and rear shock are identical. The RCM shocks are very smooth, and easy to assemble and fill. The shocksprings are selected, matched, flatgrinded, colorcoded units.
The kit does not include motor, batteries, speedo, radio-gear, body, tyres-wheels or electronics.
The silicone shockoil is included.
The 977-e comes with a full color assembly manual as PDF download, reference guide and exploded views booklet all in one. Set-up sheets ( blank and default) are included seperately, and 2 decalsheets are included as well.
Set-up possibilities
- Wheelbase
- Caster
- Trailing/leading steering
- Offset
- Kingpin-inclination
- Camber
- Camberchange
- Roll-centers
- Ride height
- Droop
- Width
- Toe-in
- Weight balance
- Shocks for dampening and springs, shockangle
- Anti-roll bar thickness
Optionals
A large selection of optionals to further improve performance, speed, weight and looks.
Merchandising
A nice selection of shirts, sweaters, jackets, caps, bags, tools and decals .
Designed by Michael Salven, Europe
Superbe, par contre, je suis surpris de la.taille des courroies, en particulier arriere, moins large qu en thermique alors que la contrainte electrique est au moins egale voir sup
:grin:
Exacte pour les contraintes sur la courroie arrière, bizarre il y aura peut etre une courroie option plus large car il reste un peu de place sur le support principal.
Ils doivent penser 1/10 elec, courroie fine, mais pour des configs hard ça va couiner sévère.
Par contre je pige pas le montage du servo, il est tête en haut ok mais comment fonctionne le renvoi vers l'avant, en plus y a un poil de longueur de biellette si la tête et vers l'arrière ce que j'imagine vu la découpe de la platine carbone.
Et le récepteur on le colle ou du coup ???
Dernier point, pour ceux qui on des contros type kontronik, atoss et autre avec les fils de chaque coté c'est mort pour l'utiliser à l'emplacement prévu.
Oui oui je sort les défauts qui me sautent aux yeux pour ne pas craquer mon slibar à la fin du mois car je la trouve trop belle la bête.
CB y'a pas une erreur de frappe???????????????
ouai 'fin c'est quand meme que du carbone, de l'alu et du plastique, ça gratte quand même !
oui la je suis d'accord ,vu le tarif de ses concurrentes et des marque aussi prestigieuse que motonica etc quand même 200 balles moins cher
on ne vit pas dans le même monde . . . moi j'arrête tout !
Bientôt la braderie !
