Posted May 15, 2014 Hello, Durant le salon Shizuoka Hobby Show au Japan, Hirosaka Masami, ambassadeur KO Propo, a présenté la nouvelle radio à manche de la marque, l’Esprit IV. Pas de données techniques connues, mais gageons que celle qui va succéder à l’Esprit sera une digne héritière. Les amateurs de radio à manche vont être soulagés, sachant que Sanwa détenait le monopole des radios haut de gamme stick jusqu’à présent. Share this post Link to post Share on other sites
Posted May 15, 2014 Y en a pas beaucoup des "pipoles" dans la RC comme Masami... quand tu le vois, tu penses instantanement "Yokomo/KO". c'est LE monstre sacre de la RC. En esperant que leur modele a manche ait plus de succes que la KIY (sur ce coup-la, ils se sont quand meme pris une bonne pile, hein...) Share this post Link to post Share on other sites
Posted May 15, 2014 En tout cas pour une bonne nouvelle, c'est une bonne nouvelle! :XD: Share this post Link to post Share on other sites
Posted May 16, 2014 (edited) Edited May 16, 2014 by Reporter Share this post Link to post Share on other sites
Posted May 17, 2014 http://www.petitrc.com/_forumphp/showthread.php?78086-New-KO-PROPO-ESPRIT-IV Share this post Link to post Share on other sites
Posted June 9, 2014 Hirosaka Mr. Comments:.. Goodness of response is attractive even if I say "what RC will move at about the same time with the reaction of finger feel that signal is sent in clear or very simples Speaking of feeling there is no play on the radio waves? you are. time is proportional to that feeling, you can time up lightly. not be able to return to the original one use, it is an article of the long-awaited recommendation for the racer. " ● product of the long-awaited appearance this summer! ESPRIT is, to the renewal of the long-awaited debut. While following the one that is supported by a number of drivers stick, operation feeling is equipped to brush up further software EX-1 the latest contents. That, the whole picture soon! Esprit IV transceiver set tentative price \ 70,000 (tax not included) Share this post Link to post Share on other sites
Posted July 24, 2014 traduit automatiquemtn du japonais Features >> << of ESPRIT4 ■ performance of the best ever It was equipped to ESPRIT4 to evolve further as the know-how of racing prop was built in the EX-1. Readjustment in accordance with the stick the response characteristics of the fastest. Please Enjoy the experience the culmination of seven years. ■ I loved the feel function. Point of evolution is a field function. We have to adjust the reaction rate [] by the adjustment of the "response" so far, but in the field function, it will be possible to adjust the [operation] feeling. [Feeling of operation] is something the driver each has its own, but it can be finished to prop you feel that it is most optimal by adjusting the feel function. ■ I was supported battery. I was able to use only batteries ESPRIT3, but it can now be equipped with a battery in 4. You can You can use the Tx Lihue battery on sale now, it is running up to 12 hours continuous. ※ I can be installed only rechargeable type battery BOX supplied with the main unit. ■ LCD screen is large, it became easy to use. I adopt the LCD of the same size with the EX-1. I became easy to set on the screen graphical. <Setting item> ● Response mode ST / TH individually switchable (Normal / High Speed / Advanced) [New features] feel ST / TH-F feel / TH-B feel [Model] menu ▶ ▶ Model Select Model Name Model ▶ ▶ copy model reset [steering] ▶ ▶ trim travel ▶ ▶ balance sub trim trim rate ▶ ▶ ▶ turn speed return speed punch ▶ ▶ ▶ reverse curve ▶ Travel override [Throttle] ▶ ▶ trim High Point ▶ ▶ brake sub trim trim rate ▶ ▶ ▶ turn speed return speed punch ▶ ▶ ▶ reverse curve ▶ ▶ drag brake brake override ▶ ABS ▶ acceleration ▶ ▶ auto start idle-up [3/4CH] ▶ 2WAY ▶ 3WAY ▶ 5WAY ▶ ANALOG ▶ 4WS mixing mixing amplifier ▶ ▶ ▶ GYRO throttle mixing mixing <Quick Setup (QuickSetup)> [Timer] ▶ ▶ down stopwatch timer ▶ wrap History [Function] ▶ ▶ LCD monitor backlight ▶ LCD contrast ▶ ▶ buzzer sound volume ▶ key repeat [system] ▶ response (ST) ▶ response (TH) ▶ ST feel ▶ TH-F feel ▶ TH-B feel ▶ Setup (key setting item editing) ▶ ▶ direct switch adjust VR (ST) ▶ Adjust VR (TH) ▶ ▶ operation time 2.4G band power management ▶ ▶ ▶ ICS All Reset <Set Contents> Transmitter: ESPRIT IV Receiver: KR-413FH <Compatible receiver> ● KR-413FH ● KR-411FH ● KR-212FHG ● KR-211FH <Option> 73018 Tx Lihue battery 2N-1550 ¥ 3,800 51201 BX-10L ¥ 4,500 Black ¥ 1,000 2 pieces 10702 Short stick head Silver ¥ 1,000 2 pieces 10703 Short stick head 16303 neck strap 3 (Planet Blue) ¥ 1,600 16305 neck strap 3 (gray) ¥ 1,600 16209 Tx bag EX-1 (KIY) for ¥ 3,200 ※ I We have shown in all for the price excluding tax. Hirosaka Mr. Comments:.. Goodness of response is attractive even if I say "what RC will move at about the same time with the reaction of finger feel that signal is sent in clear or very simples Speaking of feeling there is no play on the radio waves? you are. time is proportional to that feeling, you can time up lightly. not be able to return to the original one use, it is an article of the long-awaited recommendation for the racer. " ● product of the long-awaited appearance this summer! ESPRIT is, to the renewal of the long-awaited debut. While following the one that is supported by a number of drivers stick, operation feeling is equipped to brush up further software EX-1 the latest contents. That, the whole picture soon! Esprit IV transceiver set \ 70,000 (tax not included) Share this post Link to post Share on other sites
Posted August 6, 2014 est ce quelqu'un peu savoir a quel prix elle sera vendu et quand sur le marché ??? merci Share this post Link to post Share on other sites
Posted August 6, 2014 Dispo le 23 septembre à 599€ chez l'importateur France. Share this post Link to post Share on other sites
Posted August 16, 2014 KO80700 - Esprit IV - 2Ch Stick Radio Set The long awaited follow-up model of the Esprit 3 offers a redesigned case with a larger screen and relocated buttons to make for improved handling and easier adjustment. The stick elements are adjustable in their angle to allow the driver to fine-tune the radio to personal preferences. An optional LiPo transmitter battery makes for an operation time of up to 12 hours without recharging. The integrated screen is of the same size as the one used on KO Propo’s EX-1 KIY pistol grip radio while six buttons and a jog dial make adjusting the several software features easy. Due late August. As for the settings, beside class-standard features such as several mixes, a stop watch, trim and exponential functions the radio also offers a new “feel” setting for the throttle and brake that allows to adjust the “feeling” of the steering and throttle response. Included with the transmitter, that will become available hopefully late August, is a KR-413FH 2.4GHz receiver. Features: - Fully integrated 2.4GHz – Respond mode (normal, high-speed, advanced) – Steering trim, sub trim, speed, curve and travel override functions – Throttle high point, sub trim, speed, curve, drag brake override, ABS, acceleration & idle-up functions – 4WS mixing – Gyro throttle mixing – Quick setup – Timer and stopwatch – LCD backlight and contrast settings – Buzzer sound volume setting – Compatible with KR-413FH, KR-411FH, KR-212FHG & KR-211FH receivers - Removable aerial with storage compartment. - Adjustable stick position - Lipo, Life or NiMH option. Options KO21007 - KR-413FH Micro Receiver IP752880-2S - Intellect-Rx/Tx Lipo 2300mAh 1C - 2S-SQ Flat KO16116 - Battery Box for Esprit 3/4 (To allow use of NiMH batteries) KO16209 - Transmitter Bag - EX-1 KO10702 - Short Stick - Black KO10703 - Short Stick - Silver KO16303 - Neck Strap 3 Planet Blue KO16305 - Neck Strap 3 Grey Share this post Link to post Share on other sites
Posted August 17, 2014 Donc comme sur la KIY, pas de module externe d émission ? Share this post Link to post Share on other sites
