philippe27
Buggy 1/14 LC Racing Micro Buggy B/L Blue RTR LCEMB1LHG
2 posts in this topic
Schumacher are pleased to offer the LC Racing EMB-1 Micro Buggy. The EMB-1 is a 1/14-scale 4WD RTR shaft driven buggy packed with exceptional features for entry level micro racing and bashing. Already tested in UK conditions by great drivers, the spec and performance of this Micro buggy with surely be a great hit!
Info Flyer - Manual - Transmitter Manual - Set Up Sheet.
Features:
1. 4WD shaft drivetrain
2. Front and rear metal gear differentials
3. LC design slipper pad with adjustable gear cover
4. Threaded, composite oil-filled, coil-over fully adjustable shocks
6. Powerful Brushless ESC
7. 4500Kv 2838 brushless motor
8. Mini servo with saver
9. Steel hinge-pins with rounded front bumper
10. 2.4GHz technology radio system
11. 7.2V 1100mAh NiMH battery with 3.5mm connectors
13. 12mm wheel hexes
14. LC design treaded tires
Specification:
Scale: 1/14 EP Buggy
Length: 347mm
Width: 205mm
Height: 110mm
Wheelbase: 185mm
Weight: 0.90kg(battery included)
Tire Type: LC Buggy
Chassis: Plastic composite
Motor or Engine: 4500Kv 2838 brushless motor
Gear ratio:8.23
Speed Control: Brushless
Radio: 2.4GHz technology radio system
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminium-threaded, oil-filled, coil-over
Ball Bearings: Complete
Package Contents:
1x 1:14 RTR Micro Buggy
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
http://www.racing-cars.com/images/pdf/LC-Catalog%20EMB%20car%20v1.0.pdf
http://www.racing-cars.com/images/pdf/LC-Manul%20EMB-1HK-kits%20v1.0.pdf
http://www.racing-cars.com/images/pdf/LC-SetupSheet-EMB-1%20v1.1%20.pdf
Contenuto della confezione:
Automodello completamente montato e pronto all'uso al 100%
2CH 2.4HZ trasmettitore
Caricabatteria ( 100-240V )
Batteria 7.2V 1100mAh Ni- MH
Manuale di istruzioni
