Team Orion Advantage One Duo AC/DC charger
7 posts in this topic
Team Orion release the Advantage Touch Advance, a compact AC/DC color touch screen charger with an integrated 100W power supply and intuitive software. Equipped with a modern micro processor this charger is powerful, ultra versatile and extremely easy to use - and it speaks 6 languages.
Features:
Microprocessor controlled advanced digital circuit
Integrated 100W power supply
Input Voltage: 11-18VDC and 100-240VAC
Screen: Spectra TFT 400x240 color touch screen
Functions: charge, discharge, storage, cycle, balance
Charging Capability: LiPo/LiFe/LiIon 1-6 cells, NiMH/NiCd 1-15 cells, Pb 2-20V
Charge Current: adjustable 0.1-10A (variable with number of cells)
Discharge Current: adjustable 0.1-5A (variable with number of cells, 10W max)
Charge and discharge curve graphic engine
Charge Assistant
ATTS Advanced Touch Technology Software
HPC High Precision Charging System
Cycle modes: C->D, D->C, D->C->D
Unique 4-in-1 Balancing Board included (XH, TP/FP, EH, HP/PQ)
Balancing: adjustable on/off
Advanced Stand Alone Balancing
Discharge Cut-off voltage: adjustable
Multi-Protection System: Input and output reverse polarity protection
Multi Language Menu (English, Japanese, French, Italian, German, Swedish)
Charge and discharge data storage for later review
Adjustable automatic delta-peak charge cutoff
Temperature monitoring and cut-off (optional)
TRX-, Deans-, EC3-, Tamiya-, Crocodile Clips, BEC- and Futaba- charging cables
Dimensions: L170xW158xH45mm
Weight: 744g
ORI30207 EU-Version, ORI30208 UK-Version, ORI30209 USA-Version,
ORI30210 CH-Version, ORI30211 JP-Version, ORI30212 AU-Version
Source: Team Orion
Voila tout est dans le titre.
Je peux l'avoir d'occasion a un très bon prix reste a savoir si ce chargeur est correcte pour la pratique du 1/10 elec
le race sec (1 sortie) est-il identique au twin spec niveau qualité?
oui j'avais les 2. par contre le duo gère le storage en charge et décharge.le race seulement en charge, obligé s'utiliser mode décharge autrement si tension sup à 7.70v.
