philippe27
Team Orion Touch Duo AC/DC Charger
12 posts in this topic
Un 2x10A en 220V, c'est très très très très intéressant !!
ça sort quand cette petite chose ?
Ca dépend pour quoi c'est faire, ça va pas faire du 1c sur gros 4s par ex.
Team Orion introduce the Advantage Touch Duo AC/DC multi-chemistry charger. Building on the experience gained with the single output Advantage Touch chargers the device features a build-in 200 watts power supply for up to 10A charge current per output for simultaneous charging of up to two 6S LiPo battery packs. A colour touch screen display show all of the important charging, discharging and balancing parameters and a new split view allows to display the data of both channels. The charger is also equipped with a USB connector for firmware upgrades and two temperature probe connectors. Included with the charger come two 4-in-1 balancing boards.
Features
– Touch screen dual channel multi-chemistry charger
– Large size 4″ colour touch screen
– Integrated 200W AC power supply
– 2x 6 memory slots for charge settings
– 200W (100W/channel) charge power, 2x10A max
– Charges 1-6S LiPo/LiFe/LiIon, 1-16 cell NiMH/NiCd and 1-20 cell Pb batteries
– Multi language easy to use interface
– New split view data display
– Wide array of adjustable parameters
– Charge, discharge, cycle, storage and balance functions.
– Input/output reverse polarity and short circuit protection
– Two 4-in-1 balancing boards included
Specifications
– AC Input voltage: 100-120VAC/200-240VAC
– DC Input voltage: 11.0V-18.0V
– Charge current: 0.1A-10.0A x2
– Discharge current: 0.1A-5.0A x2
– Charge power: Max 100W x2
– Discharge power: Max 20W x2
– Balance current: 250mA
– Balance tolerance: ±0.01V
– NiCd/NiMH batteries 1-16cells
– Lithium batteries LiPo, LiIon, LiFe: 1-6S
– Pb batteries: 2V-20V
– Dimensions: L202 x W190 x H74mm
– Weight: 1340g
http://www.teamorion.com/index.php?dispatch=pages.view&page_id=46
http://www.teamorion.com/images/product_pages/111219_manual_FR.pdf
Le mono actuel est dans les 175€, donc en 2 sorties on va compter dans les 240€, en fin de mois
c'est pas le meme usage... la on est vraiment sur du specifique 2S :)
Perso, moi maintenant, c'est alim raisonnable, deux i-chargers (>300W chaque), et je refuele 2 6S costauds en meme temps, a des amperages deraisonnables sans un haussement de sourcil. Et le jour ou un des trois modules se banane, je n'ai pas besoin de racheter le tout :)
Par contre on est d'accord, le Orion il est sexxxxyyyyyy, et mono-boitier...
Deux solutions differentes, mais un joli produit ca c'est sur!
Pourquoi cela ne pourrait-il pas convenir pour du 4S ?
On peut quand même charger 2 4S 5600 mAh à 1C avec chaque sortie non ??
Et qui fabrique cela, car Orion ne fabrique pas ... et je ne le trouve pas chez Sky RC ...
5600 oui mais pas trop plus, les gros packs 4s sont des approx 100wh depuis un bout de temps
