Kyosho RT6/SC6
15 posts in this topic
Introducing the Truck version of the RB6. The proven race winning performance of the RB6 is all carried on to this truck chassis! Debut to win. 2013 ROAR National Champion!
Key Features
1.) 7075 Hard Anodized chassis
2.) Allows both mid and rear motor configuration
3.) Compatible with various types of battery packs(Straight, Separate and shorty)
4.) Rear gull wing type lower suspension arm for most efficient grip
5.) Proven RB6 steering crank system allowing linear controls UMW701 and UMW702 included.
6.) Velvet coated big bore shocks
7.) X-Gear Ball diff grease, hi-graphite grease and shock springs included
8.) Various Option parts available
9.) X-Gear Springs (Front Red / Rear Gold)
TECHINCAL DATA *Length; TBAmm *Width; 328mm *Height; TBAmm *Wheelbase; 290mm *Tread (F/R); 272mm *Tire (F/R); ΦNot Included *Tire width : Not Included *Gear Ratio; 2.6:1 *Weight; approx. 1900g
KIT CONTENTS *Chassis *1.5mm/2.0mm/2.5mm Hex Wrench *Cross wrench *X-Gear Ball diff grease, hi-graphite grease and shock springs *Wheels
REQUIRED FOR OPERATION(KIT) *Tx-Rx * Servo *ESC and Motor * Pinion Gear *Tire and inner sponge *Batteriy and charger for Tx and ESC *Body shell (BODYLESS KIT)* Tools *Paint for Body
ben voila une belle direction,mais est ce que ça voudrait dire que le truck n'est pas definitivement mort?????????
La catégorie Truck (ou Stadium Truck) n'est pas morte, elle est en fait belle et bien en renouveau.
Les SC ont eu leur période de succès de part le réalisme aussi bien du point de vue du visuel que du comportement mais les pilotes se lassent et reviennent vers les ST.
Franchement joli le truck de chez kyosho .
A voir si il marche aussi bien que le buggy .
Le seul truc qui me gène c'est la fixation des roues ...
Illuzion - T4.1 / Kyosho RT6 Body
Part # - 0235
(fits Kyosho RT6 RM and Team Associated T4.1 stadium trucks)
JConcepts kicked off the 2012 ROAR Off-Road Nationals with a Finnisher 1/10th truck body for the T4.1 racing truck. The slight cab forward, raked windshield and aggressive stance highlight a performance oriented core. Front chin spoiler, headlight and grill protect the front-end from unwanted up-drafts during flight while the supplied decals stand-out like an 18 wheeler.
Like the ROAR National Champion Hi-Flow SCT body, the T4.1 body has built-in air escape passages which allow the customer to fine-tune the body for maximum outdoor performance. The new body includes the high performance gurney spoiler which increases rear grip and balances the handling characteristics of the aggressively styled body. The Finnisher for the T4.1 is class leading straight out of the package. 1/10th racing is back, JConcepts style.
Features:
• Original - JConcepts Finnisher design
• Blended wing / body design
• Includes additional separate gurney spoiler with mounting hardware
• Clear polycarbonate with protective film
• Window masks and Finnisher decal sheet
Additional wing available:
Illuzion - RT6 / T4.1 / 22-T Finnisher gurney spoiler (0226 and 0235)
Direct replacement spoiler
Part # - 0129
(fits Finnisher RT6 /T4.1 and 22-T bodies)
j'adoreeeeeeeeeeeeeeee
The waiting game is over.
The Ultima SC6 is here!
The ULTIMA SC line has consistently competed at the highest level. To maintain its advantage, the ULTIMA SC has undergone a complete evolution into the new ULTIMA SC6 model. A convertible Midship or Rear motor duralumin chassis with tungsten diff balls, aluminum steering rack set, and all the adjustability of the IFMAR world champion RB6 combine to deliver a sharp increase in speed. These features also improve durability and strength so the risk of damage during practice or club racing is reduced, allowing you to run your machine for the pure fun of it with peace of mind. The suspension design incorporates gullwing rear suspension arms and provides precision setting of the damping ratio to achieve optimal running characteristics. In addition, the midship motor layout matches the model to high-grip surfaces such as carpet or astro to produce nimble control and movement. The motor can be converted to a rear mount to produce optimal performance on rough or loose surfaces as well. Compatible with various battery types, a mount for separate or short-type Li-Po batteries is included that allows the mounting position to be moved between front-rear. The new ULTIMA SC6 racing machine is designed to respond decisively to the driver’s commands and will take your driving performance and results to the next level.
Optional aluminum steering parts UMW701 & UMW702 are included in the kit!
New gullwing style shock mounting postion in center. The standard holes are still available on the same arms!
Aluminum gunmetal anodized clamp style wheel hexes are included all the way around.
Extended shortcourse length 7075 hard anodized aluminum chassis. Virtually unlimited battery positioning up and down the chassis with standard, shorty, or saddle pack batteries.
Velvet coated "Big Bore" shocks with bleeder style caps and genuine X-gear springs. Orange front and Red rear.
ESC pedestal from the RT6 for added traction in rear motor setting.
Allows for both Mid Motor and Rear Motor configurations. All items are included in the kit.
__________________________________________________________________________________________
Key Features
1.) 7075 Hard Anodized chassis.
2.) Allows both mid and rear motor configuration.
3.) Compatible with various types of battery packs. (Straight, Separate and shorty)
4.) Rear gull wing type lower suspension arm for most efficient grip.
5.) Proven RB6 steering crank system allowing linear controls. UMW701 and UMW702 are included.
6.) Velvet coated big bore shocks with new "bleeder" style caps.
7.) X-Gear Ball diff grease, hi-graphite grease and shock springs included.
8.) Various Option parts available.
9.) X-Gear Springs. (Front Orange / Rear Red)
________________________________________________________________________________________________________
TECHINCAL DATA
*Length; TBAmm
*Width; TBAmm
*Height; TBAmm
*Wheelbase; TBAmm
*Tread (F/R); TBAmm
*Gear Ratio; 2.6:1
*Weight; approx. TBA
KIT CONTENTS
*Chassis Kit
*Cross wrench
JConcepts kicked off the 2014 Cactus Classic with a Finnisher body which drop fits on to the Kyosho RT6 MM racing truck.
The #0269 body incorporates pre-dimpled locations for one of the hottest trucks on the circuit. The slight cab forward, raked windshield and aggressive stance highlight a performance oriented core. A revised front hood scoop allows plenty of clearance for the unique RT6 geometry while smoothing out the front down force area. Front chin spoiler, headlight and grill protect the front-end from unwanted up-drafts during flight while the supplied decals stand-out like an 18 wheeler.
Like the ROAR National Champion Hi-Flow SCT body, the Finnisher body has built-in air escape passages which allow the customer to fine-tune the body for maximum outdoor performance. The new body includes the high performance gurney spoiler which increases rear grip and balances the handling characteristics of the aggressively styled body. The Finnisher for the Kyosho RT6 MM is class leading straight out of the package. 1/10th racing is back, JConcepts style.
The Finnisher body also has the necessary geometry to fit the Centro CT4.2 conversion vehicle. The body does not include pre-dimpled locations for the vehicle so it will be necessary for the customer to locate and ream their own body mount locations.
Features:
· Original – JConcepts Finnisher design
· Blended wing / body design
· Includes additional separate gurney spoiler with mounting hardware
· Window masks and Finnisher decal sheet
Finnisher – Kyosho RT6 MM | Centro CT4.2 MM body
Part # – 0269
UPC Code – 845937011107
Replacement gurney spoiler:
JConcepts – Finnisher gurney spoiler (0269) direct replacement spoiler
Part # – 0139
FUNCTION & DESIGN
The RDRP RB6 Suspension Mount MM-RM2 Set allows you to change the rear toe-in setting of your RB6 buggy and RT6 stadium truck within seconds. Included in the set are CNC-machined and black anodised aluminium suspension mounts, designed to replace the stock plastic mounts with more durable and highly adjustable parts. The front RF2 mount mimics the stock geometry while the rear RR2 mount (included for both mid and rear motor vehicles!) makes use of delrin inserts that, depending on the orientation, make for 2 degree, 3 degree or 4 degree toe-in settings. As the toe settings have a direct influence on the available traction and side bite you now have an additional tool to get the most our of your Kyosho buggy.
APPLICATION
RDRP RB6 RB6 Suspension Mount MM-RM2 Set is a handy tool to alter the rear suspension geometry in seconds. The four included delrin inserts for the RR2 suspension mount let you build between 2 and 4 degree of toe-in in order to alter the forward traction and side bite of your mid and rear motor converted vehicles.
SPECIFICATIONS
- Material: Anodised 7075-T6 aluminium
- Suitable for: All RB6 and RT6 vehicles in mid and rear motor configuration
Schon seit sehr langer Zeit bin ich von den Fahrzeugen aus Kyoshos Ultima-Reihe begeistert. Obwohl mir in grauer Vorzeit jemand im heimischen Modellbaugeschäft den Ultima II vor der Nase weggeschnappt hatte, weswegen ich in der Internet-freien Ära mit teilweise seeehr langen Lieferzeiten frustriert zum Tamiya Astute griff, ließ der erste Kontakt nicht lange auf sich warten: Der “weiße” Ultima Pro und der Outlaw Ultima Truck zweier Freunde konnten damals restlos überzeugen, wobei besonders der Stadium Truck durch sein ausgewogenes Fahrverhalten und die vielfältige Einsetzbarkeit für enorme Freude sorgte.
Since very long time I am excited about the cars from Kyosho Ultima series. Although me in the distant past, someone had snapped in the domestic model shop Ultima II in his face, so I get frustrated reached into the Internet free era with some very very long delivery times for Tamiya Astute, was the first contact not long in coming: The "white "Ultima Pro and Outlaw Ultima Truck two friends could then completely convincing, especially with the stadium truck made ​​by its balanced performance and the versatility for enormous joy.
http://www.rc-news.de/05/2014/testbericht-kyosho-ultima-rt6-stadium-truck/
base pour sc6 sur astro
Mid motor
No anti squat spacer
30 deg front block
Short links at front
Med links rear
550cst oil front 400 rear
Saddle pack
1 deg camber all around
4mm droop limit spacers on front 2mm rear.
Reversed rack
Rest as per manual.
As a starting point should work ok.
SC6 4MM CARBON FIBER FRONT TOWER (SC6, RT6)
Serial Number: 1452
Heavy duty 4mm carbon fiber shock tower for the SC6 and RT6. Much stiffer and stronger than the stock tower for consistent damper action. Adds an extra outer mounting location for added tuning options and designed with countersunk lower mounting holes to insure exact mounting and alignment which is extra critical for taller shock towers.
High grade quasi weave USA made carbon fiber. Includes 2 csk screws.
Stock holes matches the stock geometry.
DSC_0534__91208.1410930457.1280.1280.JPG?c=2
DSC_0531__13558.1410930458.1280.1280.JPG?c=2
BullDog Mid Motor Clear Body for Mid Motor Kyosho RT6 and Associated/CML CT4.2
This is a BullDog Mid Motor Clear Body for the RT6 and CT4.2. Pro-Line now has a BullDog truck body for you Mid Motor Stadium Truck! This BullDog fits both the Kyosho RT6 in Mid Motor configuration and the CT4.2. The new Mid Motor BullDog features a new Mohawk down the center of the roof that improves high-speed stability and adds an aggressive look. The front end geometry has also been reshaped and improved to achieve higher front down force and reduce wheelies that cost precious time. Get the most advanced body for your stadium truck: Release the BullDog!
