Tlr twenty two 4wd
6 posts in this topic
Our Car is based on the TLR 22 Mid-Motor-Configuration. We built a front Gearbox-Case and Belt-Drivetrain from Slipper shaft to the front Gearbox. And also all the other parts that we need.
- Most parts, next to 100% must be original TLR or Self-made.
- Self-made parts must be produced in-house.
- The parts must be durable, like the other TLR parts
- Parts must be light weight.
- The service and part replacement must be enabled in minimum amount of time.
Parts from other manufacturers:
- the belt
- some Ball-Bearings
- for the time being the front drive shafts (depending to the World’s 2013)
- the Body (Bulldog from Proline for TLR 22)
All other Parts are TLR 22 or self-made.
Special-Features:
- Front differential came out sideways, with only 4 screws.
- Motor plate came out, without splitting the rear Gearbox case.
- Drive belt cover can be removed with only 1 screw.
- Replacing the belt in 10 minutes.
- Front wheels from TLR 22 2WD-Car
- Most tuning parts from TLR 22 fits our car.
- Outtake the rear Diff without removing any taped or soldered electronics
https://sites.google.com/site/hofmannracing/4wd-the-car
https://sites.google.com/site/hofmannracing/home
un boulot de pro:grin:
Avec le moteur dans cette position il me fait plutôt penser à un CAT2000
