Sanwa Super Vortex Zero (Sensored Brushless-Speedo)
10 posts in this topic
The Sanwa Super Vortex is a sensor controlled speed control that is suited for Electric Onroad, Electric Offroad and 1/12 Onroad racing. It features a 4.5T motorlimit when operated with 7.4V (2S LiPo) and 3.5T motorlimit when operated with 3.7V (1S LiPo). The Sanwa Super Vortex can be directly programmed from the Sanwa M12 transmitter, when a RX-472 receiver is used.*
The Super Vortex offers another special feature for racers using the Sanwa M12 or MT-4 & RX-472 receiver: due to the SSL system (Sanwa Synchronised Link), motor RPM and temperature as well as the speedo temperature can be read out and saved without any additional optional sensor.
* The Sanwa RX-472 receiver will be available soon
Features:
  • Latest sensor brushless technology
  • 8 profiles incl. Boost Zero Mode
  • Incl. sensor wires, cooling fan & power wires
  • Comfortable programmability directly from the Sanwa M12 radio possible (only with RX-472 receiver)
Specifications:
Weight 37g
Multi-Protection-System Yes
Sensored Brushless System Yes
Voltage input 3.7 - 7.4 V
Rated current 740A/phase
Type Forward/Brake
B.E.C. 6.0 V/3.0 A
Dimensions 32.0 x 35.5 x 19.7 mm
Motorlimit 1S over 3.5T
Motorlimit 2S over 4.5T
Boost Zero Mode Yes
Cooling fan included Yes
SSR compatible Yes
Vortex... j'espere qu'il freine, celui-la :)
(et leur prochaine radio elle s'appellera Machine, aussi??? ;) )
Pq? Le orion est mou en terme de puissance de frein?
Sinon, je note que ce vario est SSR compatible, comme les servos, les ordres radio seront transmis encore plus rapidement ;-)
absolument rien a voir,uniquement a cause de celui la, de vortex:
laurent
Ouf, oui d'accord, je comprends mieux maintenant ;-)
Grave ! 26 ans après il reste encore des preuves de mes écrits ! Bon ben oui, il n'avait aucun frein l'engin, bizarre comme choix commercial ! Sinon dans cet exellent n° 29 il y avait aussi l'essai du cat xls, un cat rallongé d'un pouce, comme quoi les chassis + x mm ça ne date pas d'hier...
Salut les gars,
En me baladant sur le site de Wartelle j'ai vu ceci:
Donc j'ai regardé un peu mais rien ne vaut les commentaires d'utilisateurs.:grin:
Donc voila si vous avez ou connaissez ce vario n'hésitez pas.
This is an Airtronics Super Vortex-Plus ZERO Sensored Brushless Competition ESC w/Integrated RX-472 2.4GHz FH4T Super Response SSL Receiver. The new Super Vortex-Plus ZERO takes all the features of the Super Vortex Competition ESC and the RX-472 2.4GHz FH4T SSL receiver and integrates them into one lightweight, compact unit, specifically designed for electric on-road and off-road racing. Integrating both the ESC and receiver results in a much lighter and more efficient setup than using a separate ESC and receiver. It’s the perfect combination for the competition racer.
Features:
  • Brushless Sensored Design w/Custom Sanwa Programming
  • Compatible with Normal, SHR and SSR Channel Modes*
  • Adjustable Voltage Cut-Off for Li-Po and Ni-Cd/Ni-MH Batteries
  • Twelve Programming Modes (Red, Blue & Green ESC Setup LEDs)
  • Thermal Overload Protection Circuit
  • Supports SSL (Remote Programming via Transmitter)*
Specifications:
  • Frequency: 2.4GHz FH3/FH4T Selectable Via Transmitter
  • Nominal Input Voltage: 6.0 to 7.4 Volts
  • Input Power (Cells): 1S or 2S Li-Po (4C to 6C Ni-Cd/Ni-MH)
  • Motor Limit: 3.5T w/1S Li-Po or 4.5T w/2S Li-Po
  • On Resistance: 0.00038ohms
  • Rated Current : 740 Amps/Phase @ 25ºC (77ºF)
  • BEC: 6.0V/3.0A
  • Dimensions: 1.44 x 1.48 x 1.05” (36.6 x 37.8 x 26.9mm)
  • Weight w/Power Capacitor & Switch: 48.0g (Excluding Wiring)
What's Included:
  • Super Vortex-Plus ZERO Competition ESC w/Integrated RX-472 Receiver
  • Motor Sensor Cable
  • Cooling Fan w/Four M2.6 x 13mm Mounting Screws
  • 12AWG Flexible Silicone Wire and Color-Coded Heat-Shrink Tubing
  • Auxiliary Channel Y-Harness Adapter
*When Used With Compatible Airtronics or Sanwa Transmitter.
**This product is not compatible with Airtronics or Sanwa FH2 surface transmitters or aircraft transmitters. SSL function only available when used with an Airtronics M12S, M12, MT-4S or Sanwa EXZES-Z transmitter. Super Response feature only available when used with an Airtronics or Sanwa FH4T transmitter in SSR Mode with Airtronics or Sanwa Super Response SRG digital servos. Telemetry requires telemetry capable transmitter (M12S, M12, MT-4S, MT-4 or EXZES-Z).
