TRF418 Chassis Kit
33 posts in this topic
TRF418 Chassis Kit
- will be displayed at the Tokyo Hobby Show September 16/17
- to be released November/December as usual
- list price in Japan to be 83790 yen (same as TRF417V5)
Apparently the car was run at the Japanese nationals a week ago. Looks like it will be all new with most info coming from Japan indicating new chassis, bulkheads, motor mount, suspension arms, servo mount, roll bars etc. Let's see what info becomes available within the next few days...
Translated info below:
● All Brand New "TRF418 chassis" appeared towards the IFMAR World Championships to be held in 2014. Machine a whole new main parts all test tires and power source of latest. Of course the main chassis part, to link the servo mount and suspension arms, stabilizer also has become a new design. Aluminum motor mount and also bulk conscious twist, such as weight and balance before and after. It is a machine that has been developed for the victory of the race.
http://kentech.blogs.se/2013/08/10/42270-tamiya-trf418-chassis-kit-16302722/
On en attendait pas moins !
All Bran New "TRF418" [tentative name] appearance! (08.22)
The victory in the race of many since its debut in 2010, his third consecutive in the 2012 World Championship, TRF417 series achieved world domination for the fifth time. "TRF418" (tentative name) will debut as All Bran new chassis to the world championships to be held in 2014.
The machine even while test and tire power and the latest sources, was designed to take full advantage Jirusu players active world champion Mark player, and Victor player, and feedback from the TRF works driver, almost all new design. The evolving challenges and always, yet the winner, please stay tuned to TRF418 means to challenge the six world championship win of unprecedented!
Suspension arm opening, redesigned hole position only to be used in the race, upright
To optimize the chassis roll separated from the upper deck and center bulkhead.
Change to 1.85 secondary reduction ratio in accordance with the motor characteristics, center pulley that is 20T mosquitoes.
The redesigned all the main parts!
Carbon parts
Lower deck / upper deck / front and rear shock stays / bumper support
Resin parts
Light up / before and after suspension arms / spur gear before and after
Aluminum parts
Before and after lower-upper bulkhead / motor mount / steering wiper /
Direct shaft Cup / integrated servo mount before
Suspension Mount / Separate Suspension Mount / 20T center pulley / Stabilizer / stabilizer end / damper spring
TRF Series No.170
TRF418 [tentative]
Tentative price \ 83,790 (tax included)
100% juste, l'évolution va dans le bon sens!
Le ratio interne qui descend, ca c'est intéressant...
je me rejouis de voir la poulie centrale et ses 20 moustiques..
MDR !!!!!! j'avais même pas vu au début !!!!
Encore une vidéo !!
Une petite question : ça amène quoi comme amélioration les poulies de 20 dents ?
Ca fait descendre le ratio interne... Après...
Dispo en Janvier chez l'importateur français, prix dans les 650€
Heureusement que c'est la Crise :slow:
Ca aide à encaisser la puissance.
Pourquoi? Les prix baissent pendant les crises? lol
Si vous voulez en voir de près ce week-end, il semblerait que celles d'un triple champion du monde soient de sortie ce week-end du côté de Longwy ;)
Et si vous voulez rouler à côté de lui il est même encore temps de s'inscrire!!
C'est pas la tienne alors !!!! :arr:
Our friend Kentech propose you his review about his new Tamiya TRF418.
Notre ami Kentech a le plaisir de vous proposer son article sur le montage de la nouvelle Tamiya TRF418.
Here you can see the new separate suspension blocks with material removed to clear steering links at all settings. You can also see the new 54479 Separate Suspension Mount Setting Spacer (0.5mm/4pcs.) which is included with the kit. The standard setting is as you can see 0.5mm under the blocks. 1C blocks are included.
Good picture of the slim and heavily lightened motor mount. Notice how all parts have the edges chamfered for a very nice look. The anodizing is also perfect as usual on TRF kits.
More details:
http://kentech.blogs.se/2013/12/06/trf418-build-finished-17256484/
http://www.petitrc.com/_forumphp/showthread.php?72917-TRF418-Chassis-Kit
Source: Kentech
Qu'est ce qui ce passe chez Tamiya on peut trouver la 418 à 440$ sur certains sites !!!!!!
Le retour de Tamiya dans l'hexagone ;)
Tamiya TRF418 de Walter Pollet-Villard
La denière production Touring de Tamiya commence à faire des émules dans les stands, comme en témoigne Walter Pollet-Villard, poleman et vainqueur de la finale A sur cette manche, qui a délaissé sa Team Magic pour une TRF418.
http://www.overrc.com/courses/courses2014/sitcc25012014/sitcc25012014.html
Edited by Reporter
