grimmjow
3Racing Sakura Ultimate
11 posts in this topic
La nouvelle DTM haut de gamme de chez 3Racing
quelque nouvelles photos issues de la page Facebook 3 RACING ; sortie du SAKURA ULTIMATE prevu en juillet
Edited by ciol77
Page du site officiel online !
Pas de date encore clairement annoncée.
3RACING Sakura Ultimate 1/10 Touring Car
Sakura Ultimate
Replacing the successful Sakura XI and XI DH, comes the all new Sakura Ultimate featuring all that we've learned in the past 2 years resulting in a completely redesigned race platform which to the untrained eye may seem similar to the previous Sakura while it is anything but.
Our focus has been on improvements in the production process, material engineering, reduction in maintenance time and frequencies, suspension geometry, flex symmetry and weight distribution.
Sakura Ultimate will redefine the meaning of performance in an affordable package.
Floating Servo Mount
All new machined 7075 Alum Floating servo mount ensures symmetric side to side chassis flex and minimizes any risk of chassis tweak.
Factory Racing Products Gear Differential
All new ultra smooth Factory Racing Products Gear Differential featuring redesigned production molds for all components, all new materials, hard coated alum outer joints.
All new Front End Components
All new steering crank featuring a smoother initial steering response.
Front Anti Roll bar joints are now tweak adjustable.
Front upper camber link features our unique fine tune adjustment just like the Sakura XI.
Anti Roll Bar Joints
Rear Anti Roll Bar joints features tweak adjustable ball ends.
Composite Front Spool
Composite Front Spool with replacable Joint Cups.
Titanium Turnbuckles all round.
Front Suspension
Redesigned suspension components and new materials.
SSK Front Driveshafts now standard for maximum on power front wheel traction when used with a spool.
Factory Racing Products Dampers
New Factory Racing Products Dampers featuring 7075 Alum Threaded Shock Body, Hard and PTFE Coated for maximum durability and smoothness.
Hex Shaped Spring Preload Adjustment Nut for easier handling.
Out Board Toe Rear Hubs
New rear uprights/hubs with outboard Toe-In something we found to be superior in adaptability under most conditions.
Center Front Body Support
Standard on the Sakura Ultimate, the Center Front Body Support ensures those lightweight bodies will hold shape at high speeds maximizing its aerodynamic properties.
Anti Roll Bar Mounts
New front and rear Anti Roll Bar Mounts features a positioning system preventing unwanted roll bar shifings and maintains consistency throughout each run.
Motor Mount and Fan Mount
New Low CG 7075 Alum Motor Mount featuring a center mounted front leg to ensure symmetric side to side chassis flex.
New Chassis Integrated fan mount for 30 and 40mm cooling fans.
Imported Bando Belts front and rear.
Front Belt Stabilizer
Adjustable upper chassis mounted front belt stabilizer ensures smoothest belt operation and eliminates belt skipping under heavy braking.
Composite Adjustable Battery Mounts with Velcro Battery Straps
New Composite Adjustable Battery Mounts with Precision Positioning System from the Sakura Ultimate, simply adjust battery position by adding or removing spacers on 4 positioning points to ensure perfect chassis side to side balance each time.
Velcro Battery Strap eliminates the use of Fiber Tape.
Ultra Fit Composite Servo Horn
New servo horn built with a more rigid material ensures accurate steering input and eliminates any unwanted slop.
Oooooh, un cinquieme plot de carro en standard... tiens tiens... certaines personnes avaient-elles donc raison?
Y a de bonnes idees sur cette caisse... grosses inquietudes quand meme concernant la dentelle du chassis, mais bon...
Oui quand j'ai vu ce type de châssis sur la Sakura XI DH j'ai eu peur pour la solidité, mais bon après tout ça marchait bien sur la DH alors ... wait'n see comme on dit ;)
Partie chez les distributeurs , elle arrive dans les jours qui viennent !!!!
<a  href=%7Boption%7Dhttp://img.imagesia.com/fichiers/ac/1012436-579726782073523-872201380-n_imagesia-com_ac03_large.jpg' alt='1012436-579726782073523-872201380-n_imagesia-com_ac03_large.jpg'>
bonjour a tous
je viens de faire ma training avec ma SAKURA ULTIMATE, un régale voiture facile et très agréable sans forcé la voiture est très fluide et senne.
10621281_956280377730707_449004381_o.jpg?oh=1d07fd266d337d582b88a7fa280201cb&oe=53F1A35A&__gda__=1408341959_e23541cebf48a367ff3de72b602b079f
- - - Mise à jour - - -
Edited by gimard
La 3Racing Sakura Ultimate de Julien Jost.
La 3Racing Sakura Ultimate de Julien Jost n'est semble-t-il pas la version "2014", reconnaissable à son support moteur monobloc similaire en conception à celui de Yokomo. Ce pilote devrait disposer lors de la prochaine manche du SITCC de la version 2015, pas encore disponible commercialement, qui verrai apparaître de gros changements. La ligne directrice de sa conception serait la fixation des éléments de l'auto au centre du châssis de façon à ne pas brider le flex. On parlerait par exemple d'étonnants supports de triangles!
IMG_8451%20copie.jpgIMG_8456%20copie.jpgIMG_8460%20copie.jpgIMG_8462%20copie.jpgIMG_8465%20copie.jpgIMG_8463%20copie.jpgIMG_8459%20copie.jpgIMG_8453%20copie.jpgIMG_8454%20copie.jpgIMG_8458%20copie.jpgIMG_8471%20copie.jpgIMG_8461%20copie.jpgIMG_8466%20copie.jpgIMG_8470%20copie.jpgIMG_8467%20copie.jpg
