Tamiya FF-03
221 posts in this topic
rhaaaaaaaaaaaaaaaaaaaa lovely! une date de sortie?
seb, fan des traction tam old school (m03)
Ca c'est plutot cool mais je trouve pas ca très "trf", on dirait plutot une version R ou carrément la version plastoc...
:applo:
Ca va être bon ça ^^
Avec une carro de clio williams? :D
tiens y a un nouveau dans l'equipe... faut qu'ils te forment a reconnaitre un TRF d'un tamtam... :oo:
Oh pinaise, celui là dès qu'il sort je l'achète! Je suis un super fanatique des tractions avant !xx!
on dirait que ça va encore être la race au RCA , hein Seb ? :D
Mé, mé, mé,... Je suis au RCA cet après'm et on me dis rien !!!
DO WANT ! Me le faut c'lui là ! Avec une honda civic siouplait M'sieur tam !
Tamiya is proud to announce the release of the FF-03 PRO, the newest touring car chassis kit in their line-up. The FF-03 chassis features a horizontally-placed front-motor, front wheel drive and comes enhanced with a range of high performance parts to offer you a new driving experience. Due to its unique chassis layout and FWD setup, you can enjoy a style of driving different from 4WD chassis machines. The chassis features a newly designed lower deck and comes with a compact front gearbox. Suspension is equipped with short reversible suspension arms and TRF416 uprights on the Inboard Front Suspension (IFS) setup. True to its name “PRO”, high-spec parts such as TRF dampers, aluminium turnbuckle shafts, and aluminium ball connectors are also included in the kit.
About the Model
* This is a 1:10 R/C assembly model kit.
* Chassis length: 384mm, Overall width: 185mm, Tread: 157mm, Wheelbase: 257, 245, 233mm.
* FWD chassis features front-mounted motor and is designed for optimum weight distribution and a low centre of gravity.
* Body, tyres, ESC, motor, R/C unit, battery and charger not included.
* Front suspension features the IFS setup.
* The damper mount is equipped with stabilizer holders.
* 3 wheelbases (257, 245, 233mm) can be assembled by replacing rear block parts.
* Rear dampers can be installed to either side of the suspension arms.
* Slim chassis features longitudinal battery position.
* R/C unit is placed on each side for optimised chassis balance.
* Motor is securely attached to blue-anodized aluminium motor plate which enhances dissipation of motor heat.
* The compact gearbox is equipped with a large-sized ball differential.
FF-03 PRO Chassis Kit includes the following Option Parts:
* Item 42102 TRF Special Damper (Hard Black Coating) plus Titanium Coated Piston Rods and White Coil Springs (Medium x2, Hard x2)
* Item 51000 Hi-Torque Servo Saver (Black)
* Item 53159 4mm Anodized Aluminium Flange Lock Nuts (Blue)
* Item 53642 5mm Aluminium Ball Connector (Blue)
* Item 54121 Aluminium Horn For Hi-Torque Servo Saver
* Item 54223 FF-03 Aluminum Motor Plate (Blue)
* Aluminium Turnbuckle Shafts (Blue)
* 5mm Adjuster (Grey)
The following Spare, Option, and Limited Edition parts for FF-03 Chassis machines will also be released in conjunction:
* 51419 FF-03 B Parts (Bumper)
* 51422 FF-03 M Parts (Damper Stay)
* 51423 FF-03 06 Spur Gear (68T)
* 54223 FF03 Aluminium Motor Plate (Blue) (Tentative)
* 54226 3/32 Inch Tu Ball (12pcs.)(Tentative)
* 54227 FF-03 04 Module Spur Gear (102T)
* 54228 Fluorine Coated 06 Module Pinion Gear (26T, 27T)
* 54229 Fluorine Coated 06 Module Pinion Gear (28T, 29T)
* 54230 FF-03 Stabilizer Set (Front & Rear)
* 54233 FF-03 Aluminium Diff Joint Set
* 54234 FF-03 Aluminium Spur Gear Mount
* 84130 FF-03 Ti Screw Set
FF-03 chassis machines are compatible with many 1:10 R/C touring car Spare Body Sets, but they are NOT compatible with the following:
* Item 50809 Peugeot 306 Maxi WRC Body Parts Set
* Item 51223 Audi A4 DTM 2005 Lightweight Body Parts Set (Finished)
* Item 51265 ADVAN Courage LC70 Mugen Body Parts Set (Finished)
* Item 51288 BMW 320si WTCC 2006 Team Germany Body Parts Set
* Item 51292 EBBRO 350R Body Parts Set
* Item 51295 BMW Z4 M Coupe Racing Body Parts Set
* Item 51306 Raybrig NSX 2007 Body Parts Set
* Item 51322 Nissan Fairlady Z Version NISMO Body Parts Set
* Item 51357 ARTA Garaiya Body Parts Set
* Item 51359 Xanavi NISMO GT-R (R35) Body Parts Set
* Item 51395 Corolla Axio apr GT Body Parts Set
* Item 51396 BMW M3 GT2 2009 Body Parts Set
* Item 51401 Lancia Delta Integrale Body Parts Set
58463 1:10 R/C FF-03 PRO Chassis Kit
Availability: May
Source: Tamiya
vivement la sortie de cette traction, tamiya quand tu nous tiens.......
Oui j'ai toujours un FF01 et j'attends de voir cette nouvelle version.
Kéjoni.
WHAAAAAAAAAAAAAAAAAAAAAAA TROP BEAU!!!!!!!!!!!!!!!!!!!!!!!!!!, j'en ai une demi molle... regarder bien les fixation de cellules arriére, trois point de fixation , donc trois empattement????
je confirme trop belle , a quelle date est prevu sa sortie...:youpi::youpi:
vers mai/juin
ce sera une civic
Castrol Honda CIVIC VTi - FF03 Item #58467
Tamiya is proud to announce the release of the FF-03 PRO, the newest touring car chassis kit in our line-up. The FF-03 chassis features a horizontally-placed front-motor, frontwheel drive and comes enhanced with a range of high performance parts to offer you a new driving experience. Due to its unique chassis layout and FWD setup, you can enjoy a style of driving different from 4WD chassis machines. The chassis features a newly designed lower deck and comes with a compact front gearbox. Suspension is equipped with short reversible suspension arms and TRF416 uprights on the Inboard Front Suspension (IFS) setup. True to its name “PRO”, high-spec parts such as TRF dampers, aluminum turnbuckle shafts, and aluminum ball connectors are also included in the kit. For more information on included Option Parts, refer to the next page.
About the Model
* This is a 1/10 R/C assembly model kit.
* FWD chassis features front-mounted motor and is designed for optimum weight distribution and a low center of gravity.
* Body, tires, ESC, motor, R/C unit, battery and charger not included.
* Item 53159 4mm Anodized Aluminum Flange Lock Nuts (Blue)
* Item 53642 5mm Aluminum Ball Connector (Blue)
* Item 54121 Aluminum Horn For Hi-Torque Servo Saver
* Aluminum Turnbuckle Shafts (Blue)
* 5mm Adjuster (Gray)
une idees du prix?
vers les 200 euros au japon pour la voiture seule (pas de carrosserie, pneu...)
ca va etre la race au RCA! un bon 23t, un pack lipo & hop, c'est parti pour 3/4h de race!
vavard, forza, grosquick, cyrille, christophe, partant? Encore mieux que le duel m03 versus TA03!
miam!!chanteur!!chanteur!!chanteur!
seb
Si la carro de "306 maxi" passe dessus, je fonce en acheter un ^^
:D
*fete*
Source: Tamiya
Désolé :(
