Team Associated B5, nouvelle plateforme 4x2
518 posts in this topic
vous mettez quoi comme huile ou graisse dans un diff a pignon de b5m
et comme huile d'amortisseur
pour rouler sur moquette
hello
3000 dans le diff
et 550 devant 450 derriere me concernant , mais ca depends un peu des tracés
B5M low rider wing mount
About this Product
Mount your wing low in your team associated B5M low rider for highest speed in large corners and better feeling while jumpin'.
Notice this one allow the wing to be screwed rather than clipsed , with an avid wing button for example.
3° forward tilt.
http://www.shapeways.com/shops/redworkshop
FUNCTION & DESIGN
The RDRP B5M Wing Mount Set replaces the kit's plastic wing mount with more durable and better performing parts. The mount is of a -7mm design that places the wing 7mm lower than the stock wing mount does which leads to a lower centre of gravity and improved jumping both on small, medium and large jumps. On top of that the high-quality 7075-T6 aluminium part grants a better support for the wing which leads to better aerodynamics and also improved durability in the event of a crash. And, above all, the new wing position looks WAY cooler!
APPLICATION
The RDRP B5M Wing Mount Set replaces the standard composite parts.
SPECIFICATIONS
- Material: Blue anodised 7075-T6 aluminium
- Suitable for: Team Associated B5M
- Available in black and blue color
RDRP0263-BL B5M Wing Mount Set (blue)
RDRP0263-BK B5M Wing Mount Set (black)
FUNCTION & DESIGN
The RDRP Battery Plate Thumb Nuts for Team Associated 5th generation off-road vehicles are machined from high-quality 7075-T6 aluminium and they are of a super lightweight design while offering a slightly lower profile than the original ones. Excessive machining brings then down to 0.8g per piece while their overall design makes them looking gorgeous in your ride. Included with the thumb nuts come clear O-rings to prevent them from becoming loose in severe off-road action.
APPLICATION
The B5/B5M/T5M/SC5M BATTERY PLATE THUMB NUT SET replaces the standard parts.
SPECIFICATIONS
- Suitable for: Team Associated 5th generation off-road vehicles
RDRP0264-BL B5/B5M/T5M/SC5M Battery Plate Thumb Nut Set (blue)
RDRP0264-BK B5/B5M/T5M/SC5M Battery Plate Thumb Nut Set (black)
FUNCTION & DESIGN
The RDRP B5RM/MM Bellcrank Aluminium Set replaces the kit's plastic steering bellcranks with stronger parts for added rigidity and better looks. The CNC-machined 7075-T6 aluminium construction considerably strengthens the steering assembly for less slop, a more precise steering reaction and less flex, resulting in a rock solid steering feeling and more durability in the event of a crash. The RDRP B5RM/MM bellcrank aluminium set is made for the use with B5 and T5 series kits and it comes blue anodised and laser-etched to match the remainder of our Team Associated option parts.
APPLICATION
The RDRP B5RM/MM Bellcrank Aluminium Set replaces the kit's plastic steering bellcranks.
SPECIFICATIONS
- Material: Anodised 7075-T6 aluminium
- Suitable for: Team Associated B5, B5M, T5M and SC5M
RDRP0250-BL B5RM/MM Bellcrank Aluminium Set (blue)
RDRP0250-BK B5RM/MM Bellcrank Aluminium Set (black)
Where to buy
France (DISTRIBUTOR)
selectmodelsshop.com
Je regarde le B5 depuis sa sortie et je me suis enfin décidé, il va remplacer mon losi 22. Je l'ai pris avec les hexagones alu et une barrette d'accus.
Y a-t-il des choses particulières à faire au montage ? (rondelle, vis différente...)
Bonne journée
Des bouchons d'amortisseur à volume constant sont-ils sorti pour le B5 ?
Salut Pesca,
Asso a toujours travaillé et proposé des amortos à émulsion donc hormis une bidouille avec une autre marque, tu ne trouveras pas de solution pour obtenir un volume constant...
Il me semble que le volume constant est plus indiqué en DTM mais je ne suis pas spécialiste ...
Cdlt Tonton.
C'est ce que j'avais sur mon losi 22 et j'aimais plutôt bien. Après ça se trouve je vais préférer les amortisseurs asso, je n'ai pas encore pu l'essayer.
Merci de ta réponse.
vous mettez quoi comme triangle sur un b5m a l'avant
les hard ou normaux
salut, j'ai vu que j'ai pas mal de jeu au niveau des bouchons d’amortisseur (plastique), pour ceux qui ont déjà eu le problème, vous avez changé juste les bagues plastiques qui sont sur l'axe de la vis on l'on fixe l’amortisseur ou aussi le bouchon d’amortisseur?
Généralement on ne change que les baques plastiques, après ca dépent du jeux que tu as.
mais après 2 ou 3 changements de bagues il faudra bien changer les bouchons.
pour acheter quelques pièces de rechange pour mon B5M, je voudrais savoir quelles sont pièces fragiles sur cette voiture?
Par avance merci.
Jacques
C 'est super solide, mais il faut un nez de châssis inférieur et supérieur. Triangles avant, une couronne, un pignon inter.
