Sanwa MX-V Radio Set
3 posts in this topic
No R/C racer needs more! Sanwa put the most important functions of a modern transmitter in a new design: fast response thanks to FHSS-2 2.4GHz technology, user-friendly menu with easy-to-setup functions and a sensational price/performance ratio. With this transmitter every R/C pilot gets all the decisive features in the same design as the high-end Sanwa MT-4.
The Sanwa MX-V works with the Sanwa FHSS-2 2.4GHz technology. This guarantees interference-free R/C car fun and a fast transmission of the signal. The decisive point when it comes to overtaking or braking in competition.
A nameable 10 model memory allows an easy and quick change between your models. In addition, the Sanwa MX-V is compatible with different receivers. It can be operated with the Sanwa RX-442FS and also with the LRP C3-RX.
The complete setup works via the multi-functional display. No matter, if anti-lock braking system setup, model selection or Expo adjustment – no problem with the large and clear display.
The technological equipment is rounded up by the modern design. All important functions are arranged intuitively and can be reached without any problems also with small hands. Due to the low weight compared to other transmitters in this category, also long races can be finished without getting tired.
RX-37E 3-channel FHSS-2 2.4GHz micro receiver included
Features
  • Super fast Sanwa FHSS-2 2.4 GHz technology
  • Multi-state Anti-Lock Braking System
  • Programmable model names and 10 model memory
  • Antenna integrated into the handle
  • High-quality case and workmanship
  • Direct model select
  • Dual Rate, Expo, Trim / Sub Trim, Servo Reverse and Endpoint Adjustment
  • Large multi-functional display
  • Compatible to other receivers
  • 3-channel 2.4GHz micro receiver included
  • Charge socket for optional rechargeable batteries
  • Ergonomic gun grip and steering wheel design
  • Adjustable spring tension for steering and throttle
Je déterre ce post afin d'avoir des avis et des retours sur l'utilisation de la part des utilisateur de cette radiocommande.
Je l'ai depuis des mois mais pas encore utilisé sur piste :secret laugh:
Elle est très compacte et legère.
La prise en main est excellente malgré l'apparence cheap de la poignée, les courses et dureté des gâchette sont bien étudiées (non réglables).
Les bips sont un peu trop puissants, les menus et fonctions sont parfaits, très simple et intuitif.
