bartt
1/10 22SCT 2WD Race Truck Kit
94 posts in this topic
Nothing beats experience, especially when it comes to engineering a performance-driven race machine like the 22™ SCT. To create it, TLR engineers used all the knowledge and experience they gained from making the revolutionary 1/10-scale 22 buggy. They built on the championship-winning 22 platform and took it to the next level. And now the 22 SCT is the most innovative, durable and competitive short course truck ever designed.
Features
Mid and Rear Motor Mounting Options
Depending on your driving preference or track conditions, the 22SCT will deliver the configuration you need. For the first time ever, Team Losi Racing is providing both rear- and mid-mount motor configurations in a single kit.
High-Performance Body
Designed for optimal performance, the 22™ SCT has a body that maximizes airflow around and through it.
Rear Bumper Option
Use the rear bumper system to configure the bumper to race mode or a traditional SCT bumper style with mud flaps.
4mm Heavy-Duty Turnbuckles
To meet the demands of short course racing, the 22 SCT is agile and built to last with 4mm heavy-duty turnbuckles.
Complete Kit
Build the 22SCT from the ground up so you know and control the entire assembly process to your exact specifications.
2.5mm Hard-Anodized Aluminum Chassis
The precision-machined 7075-T6 2.5mm aluminum chassis is hard-anodized for increased durability and a great look.
Gull Wing Suspension Design
This design allows the overall height of the front tower to be much lower and lowers the 22SCT's center of gravity, which improves handling.
12mm Big Bore Shocks
Smooth the ride, tame large jumps and tune suspension performance with these oversized shocks with bladder compensators and bleeder valve shock caps.
Racing Wheels
These new wheels were designed specifically for the 22SCT Truck. We are including 2 complete sets without tires so you can pick the tread and compound you need to dominate your track.
All Metric Hardware
Every piece of hardware on the 22SCT is metric so there is no guessing and no need for multiple sets of tools.
Key Features
  • All metric hardware
  • Extensive instruction manual and build guide
  • Full ball bearings
  • All the components included to complete the vehicle to either rear-motor or mid-motor
  • 7075-T6 Aluminum lightened hard anodized chassis
  • Changeable dirt guards with Short Course body bumpers
  • Slide rack steering system with optimized steering Ackerman
  • Two battery mounting configurations to accommodate both motor placements
  • Hook and loop straps to secure batteries in all configurations
  • Optimized suspension package for superior handling
  • Gull wing designed front arms for lower front shock positioning to lower the center of gravity
  • Increased hinge pin offset from the rear arm to hub for increased rear traction
  • Front nose clearance has been maximized
  • Heavy Duty 4.0mm Steel Turnbuckles with HD ball cups
  • Aluminum rear pivot that can be adjusted for pro-squat and anti-squat
  • Front plastic pivot with 30 degrees of front kick
  • Titanium Nitride coated hinge pins
  • 4mm trailing axle spindles
  • Dual Disk Slipper
  • Steel RCD drive shafts
  • Ball Differential with optimized ball pattern
  • Motor centered in transmission for balanced handling
  • Molded Gear Cover with attached rubber plug
  • Improved hub and spindle bearings
  • High Performance SCT body
The 1/10-scale 22SCT Short Course Truck Kit is the first short course offering from Team Losi Racing and is based on the ROAR National Champion 22 buggy. The 22SCT will be the most innovative, durable and competitive short course truck ever engineered since it is based on the 22 platform and designed from the ground up to be a dominating competitor.
Nothing beats experience. Especially when it comes to engineering a performance-driven race machine like the 22™ SCT. To create it, TLR engineers used all the knowledge and experience they gained from making the revolutionary 1/10-scale 22 buggy. They built on the championship-winning 22 platform and took it to the nextlevel. And now the 22 SCT is the most innovative, durable and competitive short course truck ever designed.
Designed to be a champion the 22SCT barrows the majority of the innovative features that make the 22 platform a contender. Right from the start the ability to choose either mid or rear motor configuration will allow SCT drivers to tune the ride they want depending on the track style and surface they are racing on. This will give the 22SCT a more global appeal for those individual currently running a mid-motor set-up as the driving characteristics are similar. Other key features include a 7075-T6 aluminum chassis, full ball bearing equipped, Heavy Duty 4mm turnbuckles, optimized motor and transmission placement, two full sets of wheels (8 wheels total), dish inserts for the wheels and all metric hardware for ease of maintenance.
Product Specifications
Type: 2WD SCT Truck
Scale: 1/10
Length: 21.65 in (500mm)
Width: 12.99 in (330mm)
Height: 5.63 in (143mm)
Wheelbase: 11.3-11.41 in (286-290mm)
Weight: 66 oz (1870g)
Chassis: Aluminum
Drivetrain: Rear Wheel Drive
TLR0024_a1.jpgTLR0024_a2.jpgTLR0024_a3.jpgTLR0024_a4.jpgTLR0024_a5.jpgTLR0024_a6.jpgTLR0024_a7.jpgTLR0024_a8.jpgTLR0024_a9.jpgTLR0024_a10.jpgTLR0024_a11.jpgTLR0024_a12.jpgTLR0024_a13.jpgTLR0024_a14.jpgTLR0024_a15.jpgTLR0024_a16.jpgTLR0024_a17.jpgTLR0024_a18.jpgTLR0024_a19.jpg
Oué vu le teaser, elle a l'air bien née la bébette!
De plus, le 22T est loin d'etre une mauvaise base dc on peut facilement entrevoir le potentiel de départ!
Cela dit une caisse bien réglée, un bon pilote et une belle piste US tout de suite ca fait vendeur comme teaser!!
Mon petit doigt me dit que meme des SC 10 4x4 pas tres vieux vont se retrouver aux rayons PA...
D'autant plus que le calage des satellites dans les diffs a l'air "délicat" d'après ce que j'ai pu lire sur le forum...
Tonton.
perso je garde mon 4x4 surtout que je n'ai aucun souci de diff,mais je vais certainement chnager mon sc10 asso pour un 22sc ça c'est sur
ou ^peux t on le trouver en france et a quel prix?
j ai deja un 22t et plus de sc, donc je vais investir dans la panoplie losi.
chez Sms,moi le miens est en pre-commande depuis ,mais normalement sous peu,au allentour de 300€
TLR334002 Sway Bar Kit, Rear: 22SCT
Key Features
  • Allows for adjusting the amount of chassis roll
  • Rear sway bar provides more responsiveness and an increase in off-power steering
  • Rear & Mid Motor-Rear sway bar kit includes all hardware for rear motor and mid motor configurations
  • 3 Sway bar sizes. 1mm(white), 1.2mm(yellow), & 1.5mm(pink)
  • Bars have colored paint markings for easy visibility of size
  • Only fits the TLR 22SCT
  • All hardware included
TLR334001 Sway Bar Kit, Front: 22SCT
Key Features
  • Front Sway bar provides less off-power steering and more on-power steering
woohoooooooooooooo,il est là!!!!!!!!!!!!!!!!!!!!
COOL
IL en a encore en stock? si oui a combien avec les frais de ports?
comme c'est joli!!!!!!!!!!et cette fois ci je le monte en mid car je veux tester une autre configuration,j'ai eu le 4x4,le 4x2 rear et ben celui là sera en mid puisqu'il y a les deux proposés
hihihihihih JUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
et en comparaison d'un TLR
aller en attendant voila pour le devant ,ça fait assez mario bros
aller entre deux ......
voilà l'évolution
une vraie partie de plaisir :-(
j'ai jamais vu un truc pareil,un croisement entre un mikado et super mario des tubes en veux tu en voilà et comme d'habitude,la notice comporte plein d'anomalie au niveau de la nomenclature des vis
