Yokomo BD7
393 posts in this topic
Si j'en crois les descriptions qui trainent ci et là :
- Nouveau support moteur et couronne centrale avec fixation unilatérale (à la Schum Mi5)
- Épure de direction modifiée
- Traitement corps d'amortisseur
Et si j'en crois certains commentaires, le châssis ne disposera plus des trous pour le blocage des accus avec ergo type LRP.
Cordialement.
On November 22nd, just days before making its debut at the Final Round of the Asian Onroad Championship at Yatabe Arena, we announced the BD7-2014.
I'm very grateful for all the excitement and positive comments regarding the BD7-2014.
Thank you!!!
Today, I am making an urgent and important announcement to our customers.
Last September, we released the BD7 and received several time more orders than expected. We dramatically increased production to respond to the incredible demand, and the BD7 stays popular to this day.
With the new BD7-2014, we are experiencing a similar situation – ever since the announcement on our website, we have received many orders worldwide, surpassing the production count of our first lot, and we are currently implementing measures to increase production and speed up production for the second lot and beyond.
The reaction to the BD7-2014 is greater than the hugely successful BD7, and to that I am very very grateful!
With the BD7-2014, the following optional parts of the BD7 come standard: graphite front and rear suspension arm, front steering block, and rear hub carrier.
Furthermore, the BD7-2014 comes standard with a "hard type" steering hub carrier which employs a new material to improve steering response to better handle turns.
The BD7-2014 is so popular, that it may become difficult to get a hold of one if you don't order one now!
If you are considering purchasing a BD7-2014, I would recommend you act now by heading over to your local retailer and place an order for this extremely popular model.
The BD7-2014 will meet and exceed your expectations!
Hang on tight until the BD7-2014 becomes available!
Yukijiro Umino
Sur la bd7 black édition le support de servo flottant est il livré d origine avec le kit?
"New aluminium Parts"
donc je dirais que oui.
on le trouve ou et quand
Bonsoir
Le kit de conversion est disponible chez asia racing team
Bonne soirée
merci le fantome
par contre y a t il une reel difference de comportement ou de performance entre la bd7 et la bd7 2014?
T'y
merci le fantome
Bonsoir
Désolé c'est en cour de montage prochain roulage a argenteuil le 18 janvier
A bientôt
merci le fantome
Au moins 1s plus vite au tour ;)
Mdr Paul, t'en rate pas une ;)
Quel réglage de droop(av et ar) est-il préconisé sur piste bitume?les setup sont avares d'infos sur ce point là...
bah pourtant si tu prend la derniere fiche ajoutée qui est celle de Cyril N'Diaye, il y figure!!
http://www.petitrc.com/reglages/yokomo/setups/BD7/BD7_CyrilNDiaye_Emerainville2013092122/
6 devant et 4 derriere.
idem celle de loic jasmin: http://www.petitrc.com/reglages/yokomo/setups/BD7/BD7_LoicJasmin_Besancon2013082425/
6 et 4.5.
Ou encore toutes celles de volker.
http://www.petitrc.com/reglages/yokomo/SetupSheetsYokomoBD7.html
Bref je pense que ta de quoi faire là. Mais apparemment ca reste classique.
En regardant la liste des pièces, il semble que ce support soit une option.
De plus, il y a une erreur dans la table de pincement du train arrière de la BD7 2014. Vous trouverez le communiqué de Yokomo traduit avec la table corrigée sur la page regroupant les informations sur ce châssis.
Front Spool w. Spring Steel Out Drive ver.2 For Yokomo BD7
SPR020-DBD2L
spec-r
Some new parts from Mr Roche for Yokomo BD7:
De nouvelles options pour la Yokomo BD7 :
Available on Feb/2014
Part No. : ROC-BD-21
Aluminum Floating Servo Mount, 7075-T6
Part No. : ROC-BD-22
Aluminum Separate Suspension Mount (1 pair), 41.3mm
Part No. : ROC-BD-23
Aluminum Separate Suspension Mount (1 pair), 42.0mm
Part No. : ROC-BD-24
Aluminum Separate Suspension Mount (1 pair), 43.5mm
Part No. : ROC-BD-25
Aluminum Separate Suspension Mount (1 pair), 43.9mm
Part No. : ROC-BD-26
Aluminum Separate Suspension Mount (1 pair), 44.2mm
Part No. : ROC-BD-15
Aluminum Suspension Mount, 43.5mm
Part No. : ROC-BD-16
Aluminum Suspension Mount, 44.2mm
Part No. : ROC-BD-17
Aluminum Suspension Mount, 45.7mm
Part No. : ROC-BD-18
Aluminum Suspension Mount, 46.4mm
Part No. : ROC-BD-19
Aluminum Suspension Mount, 43.9mm
Part No. : ROC-BD-20
Aluminum Suspension Mount, 44.9mm
Source: Mr Roche
Quel rapport tirer avec un 7.5 ?
J'ai essayé 110 x 32 et 34 bof en vitesse max (6.4 et 6.8)
102 x 28 pareil
C'est un SP 7.5 avec vario SP LPF
Remplacer le joint noir en plastique qui sert de guide tige et qui est dans le bouchon inférieur de l'amorto par celui en blanc (moins épais) et compenser en mettant un deuxième joint en silicone bleu. Ça permet d'avoir une suspension plus ferme et constante avec un même grade d'huile et diminue les rares fuites. A faire absolument ;-)
Ce guide blanc en question est il livré avec la voiture ? j'ai une BD7 d'occas et rien qui ressemble a ça dedans. Si vous aviez une ref ! Merci
J'ai vu des amorto big bore (marque roche) quelqu'un a tester ?
Est ce que quelqu'un a un rapport pour un 7.5 SP
bsr, si qqun peut m'aiguiller sur un petit soucis sur ma bd7 : sur courbes à hte vitesse , petit décrochage de l'arrière, idem la remise des gaz en sortie de virage .
mon set up
pneus lrp 32
traitement cs
ammortos av : ress purple, huile 500, bar de 1.2
ammortos arr : ress bleu, huile 450, bar de 1.2
diff arr rempli de 2000
droop de 5 av et arrière.
voilà si qq chose d'éfficace à changer
merci d'avance por votre aide
