philippe27
Turnigy F1 Kart 1/18
2 posts in this topic
http://www.youtube.com/watch?v=8p4WYx3lqM4
The TURNIGY 1/18 Mini Go-Kart is a real blast to drive, with its low center of gravity and ultra sticky TruRubber* tyres which keep the kart turning sharply. A powerful metal gear servo is included with kart to keep the steering precise and quick, while the non differential rear tyres lay rubber on each corner!
The entire floor pan is made of 2mm carbon fiber sheet which offers a very rigid chassis and true race kart handling characteristics. The wheels are alloy, as well as the steering arms and motor mount offering light weight durablility.
You will need a 18A ESC, an 20 size inrunner motor around 4500-4800Kv, a 2CH transmitter/receiver and 2S 800mah LiPo battery.
Stickers are included, but the driver is unpainted so you can create your own race livery on the driver.
Spec.
Length: 190mm
Width: (F)129mm / ®139mm (measured at edge of tires)
Wheelbase: 120mm (axle to axle)
Height: 139mm
Ground Clearance: 5~6mm
Tire Size: (F)26×15mm / ®27×21mm
Required.
18A Car ESC
Receiver/Transmitter
LiPo: 2S 800mah (31.5mmx30mmx60.5mm max size)
Included:
Mini Go-Kart
Pinion
Zip Ties
Double Sided Tape
Spare Screws
TruRubber: TURNIGYs very own super-soft rubber compound that sticks to road surfaces better than standard street tires.
http://www.youtube.com/watch?v=3sXlNgr2goo&feature=related
http://www.flickr.com/photos/fusselflitzer/sets/72157628044807486/
https://plus.google.com/photos/104656736936976952947/albums/5667486495712981025?banner=pwa#photos/104656736936976952947/albums/5667486495712981025
http://www.youtube.com/watch?feature=player_embedded&v=xdWjk7nWT9Q#!
