philippe27
TURNIGY 1:4 Scale Brushless GoKart ARR
4 posts in this topic
RC TURNIGY 1:4 Scale Brushless GoKart (KIT) ID:17898
The TURNIGY 1:4 scale gokart is a real blast to drive, with its low center of gravity and ultra sticky TruRubber* tyres which keep the kart turning sharply. A powerful full size servo is included with kart to keep the steering precise and quick, while the non differential rear tyres lay rubber on each corner!
The entire floor pan is made of 4mm Carbon fiber sheet with very little suspension travel at the rear giving the gokart very realistic handling.
You will need a 35A ESC, an inrunner motor around 3900Kv, a tansmitter and receiver and 2S LiPo battery.
Stickers are included, but the driver is unpainted so you can create your own race livery on the driver.
Spec.
Length: 450mm
Width: (F)262mm / ®305mm
Height: 201mm
Ground Clearance: 5~12mm
Top Speed: 45~60km/h
Tyres: 56×30mm / 58×45mm
Pinion: 13T (Required)
Gear Ratio: 13:2.37
Drive/Main Ratio: 13:47
T-Tube/Main Ratio: 20:30
Driving Weight: 2,100g (approx.)
Required.
35A Car ESC (TR35A-V2, 60A-SL or HK-45A)
Receiver/Transmitter (HK-GT2 or other 2~3 channel Tx)
LiPo: 2S 4000~5200mAh Hardcase Lipo (140x48x50mm max size)
13T Pinion gear.
TruRubber: TURNIGYs very own super-soft rubber compound that sticks to road surfaces better than standard street tyres.
autre karting 1/18
Turnigy F1 1/18 Go-Kart & Thunder Tiger KT-8 1/8 Kart
http://www.youtube.com/watch?v=xdWjk7nWT9Q&feature=related
ça m'a l'air de pas accrocher un dard cette chose
