Xray XB4, un tt 1/10e electrique pour xray?
641 posts in this topic
Je n'ai pas un niveau de pilotage suffisant pour pouvoir comparer...
show.php?img_id=93166&crt=17642f168c28dfb8656664961cc39197
#362573 Alu Steering Plate 4-Hole
• For high-traction conditions
• Increases steering precision
• More predictable steering
• Extra Ackermann positions
• 4 holes
• More forward Ackermann positions
show.php?img_id=92997&crt=f95430d20637fcc12f1f4ddedfb80827
#364021 XB4 Alu Central Bulkhead
• Increases strength
• Increases reliability
• Longer life
• Premium Swiss 7075 T6
• Black coated
• Laser engraved
show.php?img_id=92629&crt=86354050d61a621a89727c572a0bddf0
#363351 Alu Rear Upright - Right
#363352 Alu Rear Upright - Left
• Increases stability
• Fine & precise roll center adjustment
• More roll center positions
• Wider wheelbase range adjustment
• Black coated
• Laser engraved
show.php?img_id=92515&crt=f80c74cd876f84ee5b3cd003f26aabf6
#362234 Alu C-Hub 12° Right
#362244 Alu C-Hub 12° Left
• Pre-set 12° caster
• Increases out-of-corner steering
• Black coated
• Laser engraved
show.php?img_id=92453&crt=18bae6b4472adfe298aa9de944939eb7
#364978 Composite Center Diff Spur Gear 78T / 48
#364981 Composite Center Diff Spur Gear 81T / 48
#364984 Composite Center Diff Spur Gear 84T / 48
• Precision molded
• Specially-formulated composite material
• Strong
• Stamped for easy identification
show.php?img_id=92184&crt=2b07bb81390ccae4d6f77b8d475c6a28
#365353 Alu Wheel Hub 12mm (2)
#365354 Alu Wheel Hub 12mm (2)- Offset "-0.75mm"
#365355 Alu Wheel Hub 12mm (2)- Offset "+0.75mm"
#365356 Alu Wheel Hub 12mm (2)- Offset "+1.50mm"
#365357 Alu Wheel Hub 12mm (2)- Offset "+2.25mm"
#365358 Alu Wheel Hub 12mm (2)- Offset "+3.00mm"
• Optional 12mm wheel hubs
• Precision track width change
• Swiss 7075 T6 aluminum
• Lightweight design
• Additionally drilled
• Black coated
• Marked for easy identification
show.php?img_id=93591&crt=9098fd59c4f1d5a1631f4d4c80727dff
#361173 Graphite Front Upper Deck 2.0mm
• Premium graphite material
• 2mm thick
• Adjusts chassis flex
• Maximum strength
• Long life
• Combine with alu chassis
show.php?img_id=93342&crt=0d8925447158db05678b4d1cc0d04f13
#361103 Alu Chassis - Swiss 7075 T6 (3mm)
• 3mm thick
• Super-strong
• Extra-stiff
• Increases cornering speed
Je cherche à modifier mon XB4 2013 en version shorty. Je n'ai pas trouvé de tutoriels pour le faire proprement. Quelqu'un peut-il m'aider ?
Il me semble que c'est tout sauf trivial... sur le forum azur, Oliv l'a fait je crois...
C'est quoi le forum azur ?
un pseudo site de rc, copie de petitrc il y a 5-6 ans.
Ah ok !
Sinon, savez vous si une carro d'un 2013 va sur un 2015 ?
Ah ok !
La carro 2015 est plus large que la précédente.
Je voulais juste avoir un retour d'info sur les amortsseurs, montage? utilisation? merci
Puisque l on parle amortos   Le traitement  de la version 2016 a t il vraiment changé   ( car suivant les photos ce n est pas les même ) et pas de communication de la par d xray a ce sujet
Oui, le traitement est différent, et améliore la tenue dans le temps
Sur 1/7/2015 22:33:56 , noarz a déclaré:
C'est propre. Possible d'avoir les détails de la conversion ?
