Xray 12
22 posts in this topic
XRAY is excited to release the next evolution of the XII, the all-new XRAY 1/12 pan car platform: the X12. Direct feedback from factory team drivers, as well as customers from around the world, allowed the XRAY factory to turn a concept into reality… this is what we do best at XRAY. New battery placement means better car balance and weight transfer, and stiffer chassis material and more robust suspension material creates a car that is significantly easier to drive. By rethinking and then creating a completely new geometry where we elongate the wheelbase and widen the front track-width, we created a car that works exceptionally well for beginners, highly-skilled drivers, and everyone in between. And to make a car even easier to work on, we replaced the side shock with newly-designed side tube lateral dampers. Lowered rear bulkheads and an improved rear axle system allow the use of super-small tires while providing a super-low center of gravity. And much more.
Say goodbye to XII... say hello to the all-new X12.
Martin Hudy
XRAY designer
All-new X12 specs:
Chassis:
• new battery position placement (horizontal) for better car balance and weight transfer
• new harder chassis material to make the car easier and more stable for high bite tracks
• longer chassis for greater wheelbase for better stability
• holes for suspension mounting are wider which create wider width to make car easier to drive
• platform designed and optimized for LiPO batteries and brushless motors
Rear bulkheads:
• lowered rear bulkheads to allow the rear axle to move lower which allows to use smaller tire diameter and allows to move lower the weight
Rear axle:
• new system of steel part mounting into the graphite tube makes the rear axle more durable
Front suspension:
• lower, upper arms and steering blocks made from harder material to make the car easier to drive and more forgiving mainly on high bite tracks
• plastic balls for king pin are used for smoother steering
Side tubes
• side tubes replace side shock for smoother and more consistent operation
Side springs:
• are placed directly to chassis for smoother and better movements
Center Shock:
• the shock shaft is extended which makes the center shock longer for better dampening
Servo saver:
• new 4 spring servo saver makes the car more consistent and easier to drive. Makes the car steer more precise
Servo positions:
• two servo positions for allowing to perfectly balance the weight transfer
Team Tamale - SpeedMerchant Adjustable Pods
SpeedMerchant XRAY Conversions & the *NEW XRAY 12*
(Amazingly, the Chassis & Bottom Plate we did for our XRAY conversions several months ago,matches up exactly with the brand new and yet to be released XRAY 12 chassis....what a coincidence)
Spacers for the front axle Xray X10 & XII & X12
Set of spacer for front axle Xray X10 & XII & X12 NITROSISTERS024
4 pcs 1mm thick
6 pcs 0,5mm thick
material: alloy
Montage et premier roulage effectues.
Au niveau du montage rien à dire, très bonne qualité et explications au top. de préférence mettre le servo dans la position droite pour un meilleur équilibre du chassis. je n ai pas cyanolise les bords, juste fait un chanfrein au papier de verre ( gros grain puis petit grain pour finition). j ai aussi rajouté le pare-choc en mousse de la r5.
niveau roulage: c est une voiture très délicate de boîte et très vive ( dû à ses amortissements assez souple) . j ai donc passé les ressorts rouge crc latéraux et ça à desuite beaucoup mieu marché . c est la seule Modif que j ai faite sur les amortissements. j ai beaucoup cherché un bon set-up pneu et je suis tombé sur du purple à l avant et dû 30 shore a l arrière. la voiture est plaisante à rouler et efficace, reste plus qu a affiner le set-up et ça peut aller très vite. là carro est une black art ba004.
voilà, a+
surement m@t
Strong rear axle assembly for XRAY XII, X12 or XRAY X10 features tough shaft that is specially machined for perfect balance and smoothness with zero run-out for vibration-free operation. Made from HUDY Spring Steel™.
pour une fois chez xray
XRAY confirms and announces that the current 1/12 and 1/10 pan cars, the X12 and X10, will remain unchanged for the winter season 2012-2013.
Martin Hudy, X12 designer: "We have been constantly working on further improvements of all the cars in our line up and testing all the time some new ideas or prototypes. The pan car racing category has been for some time at the maturity of the stage of development and all the changes to new cars are usually very minor. With the current high performance of our both X12 and X10 we have decided to keep these two cars without any changes for this coming winter season but of course will continue to further collect the feedback and comments from the team and customers and will continue on the next improvements of these cars."
bonjour,je voudrais savoir kel rapport avc 1 moteur12/1,et pacs nimh.merçi d avance
C'est un peut du chinois tout ça! Et j'pense que t'est pas dans le bon sujet. Mais précise un peut si tu veut une reponse.
OK si je resume Xray x12 + 12T simple brushed + NiMH en 4,8V je suppose.
J dirais de commencer dans les 40mm puis d' augmenter comme dab en controlant bien la T°.
Mais comme a chaque fois le rapport est très variable suivant la piste et les brushed c'est un peut loin pour moi.
En esperant t avoir aider.
Diggity Designs DX12 - Transverse Chassis Conversion Kit For The Xray X12
This conversion will alow the racer to run the X12 in transverse battery configuration. Pushes the shock forward by .250" and has a 3mm narrower front end. This layout is best used in spec racing classes (i.e. 17.5 and 13.5) but will work well in mod classes as well. Includes 2.5mm Chassis, 2.5mm Upper Pod Plate, 3mm Tweak Plate, O-Ring and Long Ball Cup for Shock.
X12’14 Side Springs
• straight side springs
• improved side traction
• improved handling
• consistency
• smoother compression
• reduced traction rolling
Side springs for X12’14. The new side springs and spring caps feature a new straight design comparing to the previously used conical shape, to improve side traction and improve the handling of the car. The straight side springs have more consistent and smoother compression which results in a smoother out-of-corner exit as well as helping to prevent traction rolling. Set of 2.
#373584 Side Spring C=0.6 - Silver (2)
#373585 Side Spring C=0.9 - Gold (2)
#373586 Side Spring C=1.2 - Black (2)
2015 All-new Specs
All-new orange aluminum parts
All-new chassis
All-new narrower design
All-new narrow rear pod
All-new weight balance
All-new center shock position adjustment
All-new 1-hole piston
All-new steering block
All-new bumpsteer shims
All-new upper arm position adjustment shims
All-new composite lower and upper pivot brace
All-new pod pivot ball
All-new rear link pod upper plate
All-new shock adaptor
All-new rear link brace
All-new composite battery backstops
General
XRAY 1/12 pan-car with authentic 100% self-developed XRAY parts, designed and manufactured parts by XRAY in Europe
Legendary XRAY premium design, workmanship & material quality and unmatched attention to the finest details
Simple yet effective and proven design, well thought-out details, unmatched precision of all small details
High-competition design with focus on ultra-low weight, resulting in super-lightweight construction
Optimized for indoor carpet racing as well as outdoor asphalt racing
Chassis
Grooves under the front suspension are smaller to stiffen the flex and optimize the steering characteristics to make the car easier to drive
Chassis is 3mm narrower to even further centralize the weight along the centerline
Chassis allows mounting of center shock in either forward or rearward position
Chassis includes holes for composite battery backstops
CNC-machined chassis from stiff custom-manufactured 2.5mm high-grade graphite material with specially-designed compound for carpet and asphalt racing
Chassis layout designed to give sufficient stiffness for excellent handling, but flexible enough to generate sufficient grip and traction
Chassis and rear pod features pre-drilled centerline holes for optimum weight balance adjustment using HUDY Balancing Tool #107880
Composite front chassis protectors protect the front of the chassis in crashes
Robust body posts with fully-adjustable body holders; optional super fine +1 or +2mm body backstops available optionally for even more super-fine body height adjustment
Tiny lightweight antenna mount secures lightweight yet strong molded fiberglass rollover antenna
Chassis design allows to use both horizontal and vertical battery placement
Front suspension:
New shims for changing the upper arm position
Steering block play was removed for more precise steering characteristics
Bumpsteer shims were added for improved steering characteristics
Redesigned & improved front suspension
Front lower & upper arms and steering blocks made from hard material to make the car easier to drive and give smoother steering
High-competition, fully-adjustable front suspension with super-clean design of all composite suspension parts
Lower suspension arms feature smart eccentric aluminum inserts for quick & easy changing and setting up of track-width
Optional aluminum 0.5mm and 1.0mm eccentrics are used to set the track-width either narrower or wider
Ride height adjustment shims for very quick, precise and hassle-free ride height adjustment for various track conditions; set of 0.2, 0.4 and 0.6mm ride height adjustment Shims are included
All composite parts manufactured by XRAY using premium self-developed composite mixtures which guarantee sufficient flex of the suspension parts yet hard enough to withstand heavy crashes
Fast & easy front caster adjustment via included clips
Reactive caster adjustment of preset 2.5°, 5.0° or 7.5° via easy-to-change eccentric bushings
Ultra-precise wheel axles CNC-machined from premium HUDY Spring Steel™ additionally hardened and hand ground for precision fitment
High-precision, HUDY Spring Steel™ upper pivot balls ensure super-fine movement of the front suspension under compression
Composite lower pivot balls allow the front suspension to work more smoothly
Front upper 3mm adjustable HUDY Spring Steel™ camber turnbuckles are lightweight yet can withstand heavy crashes
Steering
Chassis features predrilled holes for the servo mounts on both left and right side which allows the placement of the servo to balance the car as necessary
Super-tiny yet robust steering blocks with specially-designed axles which prevent axle spinning while tightening the wheel locking nuts
Pivoting front suspension with super-smooth hardened steel kingpins supported by soft springs; optional medium, hard, and extra-hard suspension springs available as options
Aluminum servo mounts position servo flat on the chassis to ensure lower possible center of gravity
Tiny yet robust servo saver with easy Ackermann adjustment via shims mounted below pivot balls
4-spring servo saver makes the car steer more precisely and smoothly
Specially-designed narrow composite ball joints
Adjustable, super lightweight Swiss 7075 T6 aluminum turnbuckles
Rear pod:
Compact and ultra-lightweight narrow rear pod constructed from high-strength aluminum bulkheads, rear aluminum brace, and strong high-grade 2.5mm graphite plates
New lighter & smaller pod pivot ball decreases the weight of moving parts and increases the movement angle of the rear pod plate
Composite upper & lower pivot brace was redesigned to lower the pivot ball by 0.5mm to improve roll center height
Composite rear pod links located centrally and moved 3mm more towards the center, resulting in increased steering response and improved side-to-side weight transition
Rear pod upper includes mounting hole for optional side shock, for different damping characteristics
Redesigned rear link brace allows battery relocation by 4mm rearward when using cross chassis alignment, for improved steering characteristics
Rear pod bulkheads CNC-machined from premium extra-hard Swiss 7075 T6 aluminum, additionally black coated for long life and stylish look
Rear bulkheads are strategically machined to reduce weight to minimum while retaining strength
Premium-grade graphite upper deck provides solid attachment for shock absorber to rear pod
Tweak-resistant graphite rear brace
Super-easy motor top access
Rear pod accommodates all motors
Eccentric composite bushings included for ultra-fine rear ride height adjustment
Rear differential features high-grade precision carbide balls for spur gear, hardened and precision-ground D-steel shims, and premium carbide 3x8mm axial thrustbearing
Ultra-strong hollow rear axle
Precision-molded spur gear made from XRAY's exclusive composite material, ensuring true running, super-quiet operation, super lightness and robustness for handling powerful motors
Aluminum rear hubs machined from lightweight aircraft aluminum, specially lightened and black coated for stylish look
Lightweight rear wheel mounting screws for reduced rotating weight
Rear left aluminum wheel hub with center-balanced clamping mounting system, ensures secure mounting while eliminating vibration and run-out
Easy rear track-width adjustment via included shims
Rear body posts are mounted to the chassis via a wide independently-mounted graphite holder, ensuring body downforce is properly transferred to the chassis
Rear pod weight balance can be easily adjusted via shims between motor and bulkhead
Straight side springs have more consistent and smoother compression for smoother out-of corner exiting, and reduction of traction rolling
Shocks
XRAY micro shock with similar design as it’s “big brother” counterpart in XRAY’s successful T4 touring car platform
Centralized position of the shock absorber
Fully-adjustable shock with aluminum shock body hard-anodized for ultra durability and additionally black coated for stylish look
Fine-threaded shock body for quick and easy shock spring preload adjustment
Tiny thin shock membrane gives super-smooth dampening characteristics
Super-soft silicone shock O-ring for smooth operation while preventing oil leakage
Ultra-finely finished shock shaft with precise-molded composite shock piston ensures optimum shock oil flow and smooth shock absorber action
Simple yet smart shock construction allows for quick and easy shock-length adjustment for downstop adjustment
Shock position adjustment via shimming of HUDY Spring Steel™ shock ball studs
Rear pod side balance is controlled by side tubes which give equalized lateral damping in both directions and eliminates unwanted rebound
Rigid centrally-mounted shock mount prevents tweak and significantly improves side-to-side stability
New 1-hole piston for improved damping characteristics
New shock length adaptor for adjustable damping characteristics
Assembly & support:
Highest quality of all composite parts ensures super-precise fitment, easy assembly, and smooth operation of all parts
Premium 3D full-color Instruction Manual
Exclusive Virtual Online Setup Sheet database with thousands of setup sheets for race tracks around the world
Premium, unmatched XRAY online support
Adjustment Possibilities:
Front camber, caster, and toe
Front & rear track-width
Front, center & rear ride height
Front springs & shock absorber
Downstop & pod damping
Ackermann
Front brace stiffness
Differential setting
All specifications are subject to change without prior notice. Pre-production prototype is shown. Final specifications may slightly vary. In some pictures optional parts may be shown. All option parts are not included and must be purchased separately. The color of some aluminum parts may vary from kit to kit and some of the kits may not include all the orange or black parts as shown. Some of the spare parts or option parts may not be available at the moment in the orange or black color as shown. Some of the pictures show colored stickers on wing and radio tray, these are not included in the kit and are used in photos only for promotional purposes. The racing body included in the box is clear and unpainted.
X12'15 Specs:
Dimensions
Class: 1/12 electric pan car
Width: adjustable 167mm +/- 2mm front, 169mm rear
Length: 264 mm (varies depending on rear tires used)
Wheelbase: 201+/- 0.5mm
Weight: 202 g
Ready-to-run weight: 840 g - incl. BL system (varies depending on equipment used)
Chassis
Chassis: 2.5mm carbon fiber,CNC machined
Body: not included, uses 1/12 pan car type
Drivetrain
Type: 2wd direct drive to rear axle
Rear Axle: Steel shaft with ball differential
Primary: spur/pinion
Bearings: High-speed ball-bearings (10)
Suspension
Front: Spring-supported, kingpin-style front suspension with composite upper & lower suspension arms and steering blocks
Rear: Articulating rear motor pod adjustable via pivot-ball links, controlled by rear shock absorber.
Rear Shock: Central adjustable oil-filled shock absorber
Geometry
Ride Height: Adjustable front + rear
Camber: Adjustable front
Front Caster (Static): 1–14.5° static adjustable static caster
Front Caster (Reactive): 2.5–7.5° adjustable reactive caster
Track-width: Adjustable front and rear
Toe: Adjustable front
Downstop: Adjustable rear
Ackermann: Adjustable with shims
Steering: Direct linkage between steering servo saver and steering blocks
Balance: Front/rear weight balance adjustable via battery position
Other
Wheels: not included
Tires: not included
Instructions: Full-color instruction manual
Set-up book: not included, the 2-color set-up book (16 pages) can be downloaded and it shows previous XRAY models in photographs contained within it. However, the methodology and set-up theory are the same for all 1/12 pan cars
Packaging: Carton box with vinyl bags with parts
Additionally included: HUDY Diff Grease, Authentication Certificate, set-up sheet, parts list & exploded view, decals, oils
Not included: Motor, batteries, speed controller, tires, body, steering servo, radio equipment
Hello,
Je viens de me commander une X12 2015 pour l'hiver. Le but est de m'affûter les doigts pour ma prochaine saison de TT 2015.
C'est tout nouveau pour moi, l'expérience débutera au MRCC dans quelques jours dès son ouverture !
A bientôt sur les pistes.
Chassis – Xray X12’15
Motor – Reedy Sonic 3.5T
ESC – LRP Flow
Battery – Reedy 7000mAh
Tires – CRC Green rear Magenta front
Radio/Servos – Sanwa
Body – Protoform AMR 12
Remarks – British National Champion Olly Jefferies is used to running his X12 on high grip surfaces back in the UK and so has had to adapt the setup of his new 2015 Xray for the low grip conditions. The changes include using the centre shock extension and a stiffer centre spring, stiffer side tubes and giving the car more tube droop. With the conditions on track changing every run, Olly says he has to continually fine tune the car prior to going out for each run.
New X12 Composite Front Suspension Arms and Upper Arm Mounts – Hard
#372011 Composite Front Upper Arm Mount - Right - Hard
#372021 Composite Front Upper Arm Mount - Left - Hard
• Special hard composite material
• For high traction, high temperatures
• Higher stability
• Marked for easy identification
Front upper arm mounts and lower suspension arms for X10 and X12 cars made from new hard composite material. The hard composite material makes the car more stable, recommended for high-traction conditions or in hot weather. Marked “R” and “H” for easy identification.
showimage.php?img_id=89873&crt=43bf67f752b620ea7bcaafa1a4e8ec0d#
