rcpassion
Losi Mini 8ight - 1/14 Scale 4WD Brushless Buggy
67 posts in this topic
<img src="
http://www.petitrc.com/gallery/files/losb0224_01.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" />
1/14 Scale Mini 4WD Brushless Buggy
Based up on the ROAR-Championship-winning 8IGHT™ buggy, this brushless-powered prodigy is the ultimate mini buggy.
Its 1/14-scale size allows it to handle tougher terrain while mastering the outrageous power and speed from the brushless system. Better still, the Mini 8IGHT comes with everything you need to get started, including transmitter, rechargeable NiMH battery pack and charger. Experience the thrill of driving a Mini 8IGHT today.
<img src="http://www.petitrc.com/gallery/files/3039-losb0224_04.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" />
SPECIFICATIONS
Length: 292mm (11.49 in)
Width: 204mm (8.03 in)
Wheelbase: 186mm (7.32 in)
Height: 110mm (4.33 in) at ride height
Weight: 0.98 kg (2.15 lb) with battery
Motor: 4500Kv brushless motor
Speed Control: Brushless
Radio: Spektrum™ 2.4GHz DSM Technology
Batteries: 7.2V NiMH with EC2™ connector
Kit/RTR: Ready-To-Run (RTR)
Shock Type: Aluminium, threaded, oil-filled
Body: Custom decorated available in 2 colors
Tire Type: Mini Kingpin™ Buggy
Ball Bearings: Complete
<img src="http://www.petitrc.com/gallery/files/3039-losb0224_08.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" />
FEATURES
• Water-resistant brushless ESC
• 4500Kv brushless motor
• Spektrum SR300 receiver with 2.4GHz DSM technology
• 7.2V 1100mAh NiMH battery pack with EC2™ connectors
• 4WD shaft-driven drivetrain
• Front and rear metal gear differentials
• Mini servo with saver
• Aluminium, threaded oil-filled, coil-over shocks
• Heavy duty, 2.5mm anodised aluminium chassis
• Mini Kingpin™ treaded tires
• 2.5mm aluminium shock towers
• 12mm wheel hexes
• Aluminium motor mount
• Heavy-duty adjustable turnbuckles
• Chassis dirt guards
<img src="http://www.petitrc.com/gallery/files/3039-losb0224_10.jpg" alt="Mini 8ight 1/14 Scale Mini 4wd Brushless Buggy" />
Source: Horizon Hobby
Edited by rcpassion
il a l air super sympa ce mini eight vous en pensez quoi?
qui peut mettre des photos
merci titi
chassis reçu et demonté/remonté pour faire un petit check
Tres belle qualité, reste a voir demain sur la piste
seul le servo est un peux cheap avec un retour au neutre pas tjrs top mais avec 2 ou 3 coups de dremel je pense que l'on peux mettre un servo low profile de 1/10
quelques photos demain
Salut châssis reçu et essayer hier c est de la balle ça se pilote comme un tt1/10 ça braque bien ça saute super amortisseur top coter puissance avec le pack 1100nimh ça pousse bien prochain test en lipo
titi
salut titi tu la essaye a vic?
Je pense m en prendre un pour me faire un circuit privee a la maison
il a l air d enfer je l ai vu en vrai sa a l air genial
Le premier arrivage de mini 8ight est prévu fin du mois de novembre chez l'importateur français
salut oui essayer a vic sur la piste rally est c est vraiment super ça marche fort on dirait un 10eme en plus petit
c est qui l importateur en france?
Je ne sais qui l'importe en france mais si il avait été en france en meme tps que l'angleterre ont aurai pu le commander ici, dommage
voici les photos du mien :)
MOI je l ai acheté en france. dit moi sur ton losi tu as mit quoi comme options tu peux me dire? merci
Nous Non on avais besoin de 5 kits et on a pas trouvé ça en stock.
la il y a juste supports amortos et platine carbone.
j'atten les supports de triangle alu et ça suffira
j'ai egalement mis un micro recepteur spektrum que j'avais dans un coin
Les support de triangle alu tu les a trouver ou svp? si tu veux dit le moi en mp merci titi
Les pces carbone sont les Losi ??
MP pour le "fournisseur".
Merci.
Stéphane.
Bonne qualite
Bon comportement, direction tres (trop ?) vive (en tout cas sur moquette avec pneus d'origine)
Attention cependant : 2 chappes d'amortos petées en 2 packs sur 2 receptions de saut pourtant pas si moche que ça !
Qualité des plastiques ?
Quoi qu'il en soit, je les ai remplacé par des chappes 1/10 (les boules d'origine rentrent pile poil dans celles de B4)
La section de plastique entourant la boule etant plus consequente, il ne devrait plus y avoir de probleme de ce coté là
Une bonne petite machine qui n'a rien à voir avec du 1/18 plus petit et surtout beaucoup trop leger (à mon gout)
un vrai comportement de 4x4 1/10, tres directif et moteur d'origine deja tres puissant en lipo.
bonne autonomie et tres bon comportement en l'air.
sur moquette avec pneu d'origine trop d'accroche sur le toit a chaque virages, par contre passage sur roues DTM mousse 35 shore et la que du bonheur
essai hier devant chez moi sur goudron avec un lipo 1800 25C a l acceleration il leve les roues avant ca marche grave
ptite astuce, les ressorts arrieres étant un peux dur on peux les remplacer pas des ressorts avant de B4
Salut les chapes RPM pas nickel dessus car celle d origine sont un peut faible
Bon et bien ce mini losi marche définitivement fort
Astuces utiles:
-rotules du bas des amortos plutôt fragiles, mettre celles du B4/T4 (boule interchangeable et plastique bien meilleur
-ressorts avant du B4 pour les amortos arr du mini-8
-chappes RPM
-roues mousse de dtm 1/10 en 35 shores sur piste indoor moquette
encore quelques pack et nettoyage des diffs et test avec un huile de 5000
chappes RPM installées ainsi que les rotules amortos du B4
j'ai installé a l'arrieres les ressort avant Marron du B4, on vas voir
mousse DTM 37 shores
bientot les retours pour les interessés
