Posted August 4, 2011 Speedsport "Shorty" LiPo battery Team CRC's Speedsport line of LiPo batteries keeps growing! The Speedsport line offers great battery packs at an even better price. These batteries pack a huge punch for your vehicle, NOT your wallet. And now there's a CRC Speedsport pack ideal for your Losi 22 buggy or any other vehicle that requires a smaller case size than the "standard" 2s size. (battery pack dimensions provided below. make sure to confirm that the pack will fit your vehicle before ordering.) Ask your local retailer about Team CRC Speedsport batteries today, and start enjoying top level performance at an entry level price! Share this post Link to post Share on other sites
Posted October 19, 2011 Reedy 4000mAH 60C 7.4V Shorty LiPo Reedy's Shorty LiPo offers a high 4000mAh capacity and powerful 60C rating in a light and compact package. With more than enough power and run time for both on and off road racers, this battery's real advantage is its compact size which allows racers to optimize their setups by altering their vehicle's weight distribution. A durable hard case helps prevent damage while 4mm socket connectors reduce resistance while allowing for short and clean wiring. A pair of 4mm male connectors are included. LiPo battery technology continues to progress and Reedy is proud to bring improved performance to the masses. Specifications: Capacity: 4000mAh Voltage: 7.4V (2S) Dimensions (mm): 94 x 47 x 25.1 Max. Charge Current: 8.0 (2C) Discharge: 60C cont., 80C burst Weight (g): 202 #306 Reedy LiPo 4000mAh 7.4V 60C Share this post Link to post Share on other sites
Posted October 20, 2011 Reedy 4000mAH 60C 7.4V Shorty LiPo ... Attention, ce pack est un 2S et non un 1S Share this post Link to post Share on other sites
Posted June 30, 2012 Reedy 4100mAh 65C Competition 7.4V Shorty LiPo Battery! Reedy's 4100mAh 65C Shorty LiPo is intended solely for racers! Its compact size allows racers to optimize their setups by altering their vehicle's weight distribution. And its reduced weight means more acceleration and improved jumping ability. Winning race setups are a combination of handling and power. A 65C rating and a 4100mAh capacity means that whether racing stock or modified, you will have more than enough power to clear the big jump where others come up short! A R.O.A.R.-approved durable hard case helps prevent damage, and 4mm socket connectors reduce resistance while allowing for clean wiring. LiPo battery technology continues to progress and Reedy is proud to bring improved performance to the masses. Specifications: Capacity: 4100mAh Voltage: 7.4V (2S) Dimensions (mm): 96x47x24.8 Max. Charge Current: 8.2A (2C) Discharge: 65C cont., 120C burst Weight (g): 211 #602 Reedy LiPo 4100mAh 7.4V 65C Shorty Share this post Link to post Share on other sites
Posted June 30, 2012 salut ce sont tous des 2c soit 7.4v, moi j'ai des intellects ils sont tres bien car tu peut jouer sur la repartion des masses, apres j'ai du changer de moteur car j'avais moins de peche pour les saut . il faut dire que j'avais des 5600 60c . en tout cas je suis content je fait 2 manches tranquilles aplus Share this post Link to post Share on other sites
Posted October 12, 2012 Bonjour Tout le monde, J'aurais besoin de quelques retours concernant les lipos shorty... je roule sur Losi 22T et possède des lipos sticks longs mais si je passe le pépère en mid, il me faudra des lipos shorty donc quelles sont les marques "correctes" sachant que je ne cherche pas non plus à me ruiner et c'est plus pour du loisir que de la compétition acharnée? Merci aux ames charitables qui auront pris le temps de me répondre! TOnton. Share this post Link to post Share on other sites
Posted October 12, 2012 Je vends bcp de vampire, bien et raisonnables en prix, et aussi du reedy mais ils sont assez (trop) chers Share this post Link to post Share on other sites
Posted April 25, 2015 bonsoir , j'aimerais savoir si 2 lipos shorty 4500/100c peuvent etre utilisé en TT 1/8 brushless car je me demande si 4500 ce n'est pas un peut juste malgré que je ne compte pas mettre un moteur de plus de 1900 kv Share this post Link to post Share on other sites
