Serpent S411 TC scoop
233 posts in this topic
J'ai toujours roulé avec ces courroies pas de soucis
Niveau tension elle n'est pas tendue à fond mais ne bouge pas...
OK merci...
Edited by kistof
Des retours de pilotes utilisant la eryx en France.comportement ,usure ou autre je suis preneur de tous renseignement.
Serpent 411 Eryx, new optionals
Shiping before end july or even before.
Bonjour , étant nouveau s411 , où commandez vous vos pieces en france autre que les ".de" avec leur 30e de port , car trouver un site avec des rtr et courroie ok mais chapes boules axe etrier fusée etc.....
Benjamin
Serpent is about to introduce the strongly developed 411-ERYX 3.0 soon.
Key NEW features:
2mm coated and laser engraved 7075 T6 aluminium chassis; dark grey anodised with ERYX 3.0 logo, lowered sides for optimal flex, fully symmetrical for even flex
lighter lower bearingblocks front and rear indentical
new type lower CG 7075 T6 motormount, centrally mounted
seperate bushings to support the top-plate front and rear, to influence flex as needed
lightweight aluminium spool with blades
v2 type hard composite all around: wishbones, uprights, castorblocks, steeringblocks
v2 hard composite wishbones with one central hole for shock mounting
rear anti-roll bar mounted in front of rear arm
double joint cardan shaft v2 with clips
brackets standard : 3.5/ 0.5 split blocks in the rear, 2.0/ 0.5 in the front
New material shock-O-rings
Lightweight anodised aluminium camberlinks
Lightweight anodised aluminium trackrods
Lighter composite anti-roll bar centering front and rear
ERYX 3.0 set-up sheet
Detailed news and images to follow end april 2014.
ERYX 3.0 starts shipping 1 may 2014 !
Team Serpent
