Novak gtb2
15 posts in this topic
The GTB 2 Sportsman Racing Brushless ESC (#1709) is a speed control for the modern, entry-level racer. This GTB now includes many new features including built-in protection in an effortless, clean, and technological design. The GTB 2 includes every feature a Sportsman class driver would want without timing adjustments or a PC interface. This ESC provides the industry with a spec speed controller, ensuring even competition among Sportsman Class racers.
CLASSIC GTB NAME
The GTB has been a trusted speed control since 2005. This is why Novak has kept many of its signature features. The GTB 2 meets ROAR Sportsman Class guidelines and has a user-friendly One-Touch Programming Interface. Just like its predecessor, the GTB 2 has multiple adjustable parameters, including Minimum Brake and Drag Brake. It has the updated Novak Thermal Overload Protection, which detects when the speed control's temperature rises too high; it then drops the ESC's power so drivers can safely maneuver their vehicle off the track.
Novak's new speed control includes Built-In Voltage Cut-Off Circuitry, which monitors the vehicle's battery pack's voltage and prevents the batteries from going below the critical safety voltage level. It is sensor-based for excellent torque and low-speed drivability. The GTB 2 has an extremely low on-resistance for its price point. Customers can enjoy this ESC for the same low price as the original GTB (#1710), with a street price aimed under $100! The GTB 2 is clearly the highest performing ESC for Sportsman class racing at such a low cost!
A MODERN SPEED CONTROL
The GTB 2 Sportsman Racing Brushless ESC would not be a Novak product if it wasn't upgraded with the latest features available. The GTB 2 features the patent-pending NovaBrakes™. This revolutionary braking system provides instantaneous braking under any condition. The brake response is smooth and immediate at any speed or throttle position, ridding the ESC of brake delay. This new braking system has completely transformed the feel, response and use of traditional brakes.
The Racing Power Trans-Cap Module – 2S LiPo and 4-6 cell NiMH (#5678) is also included. This updated Trans-Cap Module is smaller and more compact than the previous Novak (#5679).
Not only does the GTB 2 come with excellent Default Programming, but it includes features such as Throttle Curve Selection (Linear/Expo), Brake Curve Selection (Linear/Expo), Adjustable Brake Frequency, Adjustable Brake End Point, and an Adjustable Drive Frequency. The GTB 2 also includes a selectable Motor Rotation and has an all new Cross-Cut ESC heat sink for reduced weight and efficient cooling.
FUNCTIONAL AND COOL RACING
Included in the GTB 2's long list of features, Novak's temperature indicator that allows racers to check their ESC's temperature during or after each run also comes standard in this ESC. This indicator is so accurate that many racers use it in place of a temperature gun. A quick tap on the One Touch™ button will display the speed control's temperature via the on-board LEDs.
Additionally, Novak's Hall Sensor Test™ quickly verifies if the sensor harness and sensors in the motor are functioning properly without any risk to the ESC or motor. This Hall Sensor Test is an invaluable tool when troubleshooting at the race track. This feature works with all Novak motors.
FAIR AND EVEN SPORTSMAN RACING
One of the best qualities about the new GTB 2 Sportsman Racing Brushless ESC is its signature purpose as a Sportsman Class and Entry-Level ESC. It is perfect for the racer who wants a small, reliable and modern speed control without Timing Levels, Timing Set Point Adjustments or a PC Interface to alter its settings. Novak is pleased to release a speed control perfect for the rising popularity of Sportsman Class Racing.
The GTB 2 is an all-purpose speed control for On-Road, Off-Road or Oval Racing, and is compatible with all Novak 540-size and 550-size sensored brushless motors. It's compact, small and light-weight design combined with a cross-cut heat sink for reduced weight make it perfect for many different vehicles of many shapes and sizes. The GTB 2 features a highly water resistant case with a silicone seal gasket and includes a cooling fan. It meets RoHs compliance and includes Novak's 120-Day Warranty.
GTB 2 SPORTSMAN RACING BL ESC FEATURES
Multiple adjustable parameters via on-board programming: Minimum Brake (0-30%), Drag Brake (0-30%), Minimum Drive (0-15%), Dead Band (2-8%), Throttle Curve (Linear/Expo), Brake Curve (Linear/Expo), Brake Frequency (1.67-13.7 KHz), Brake End Point (10-100%), Drive Frequency (16-7 KHz), Reverse, Motor Rotation, Voltage Cut-Off
Meets ROAR Sportsman Class Racing guidelines
Built-in diagnostic temperature monitoring that lets you quickly check the ESC's operating temperature at any time
On-board Hall Sensor Test to easily and quickly verify that the motor's sensors are working properly
NovaBrakes™ provide instantaneous braking under any timing condition
Sensor-based for excellent torque and low-speed driveability
User friendly One-Touch programming interface with five colored status LEDs to help personalize the speed control's settings
Compatible with the entire 540 and 550-sized Novak brushless motor lines
Robust 3-amp BEC for strong and fast steering response under any condition
Highly Water-resistant case
Cross-cut ESC heat sink for reduced weight and efficient cooling
Meets RoHS compliance and includes 120-Day Warranty
Designed, assembled and tested by Novak in Irvine, Calif., using globally sourced components
GTB 2 SPORTSMAN RACING BL ESC SPECIFICATIONS
Motor Type: Sensored Brushless
Fwd/Brk/Rev: F / B / R
Input Cells: 1-2S LiPo/LiFe or 4-6 NiMH
Size (w/o fan)(in/mm): 1.16" x 1.47" x 0.97" (29.5 x 37.3 x 24.6 mm)
Weight (w/o wires)(oz/g): 1.29 oz. (36.6 g)
On-Resistance: 0.00040 ohms @ 25°C trans. temp.
Motor Limit: 540-Size: 3.5T; 550-Size: 4.5T
BEC: 6.0 volts DC / 3.0 amps
Power Wire Size: 14G Super-Flex Copper-Strand Silicone Wire
Status LEDs: 5
Il est dispo en france ce vario ?
Si oui, à quel prix ?
Merci d'avance.
Novak's brand new Sportsman Class ESC is NOW SHIPPING! The all-new GTB 2 Sportsman Racing Brushless ESC (#1709) is a speed control for the modern, entry-level racer. This GTB now includes many new features including NovaBrakes™, an all new Cross-Cut heat sink, and Novak's Hall Sensor test and temperature indicator. The GTB 2 includes every feature a Sportsman class driver would want, without timing adjustments or a PC interface.
Il a l'air bien sympathique ce vario, le retour de novak sur nos voitures ?
Trop tard, j'ai acheté mon GM 80R dont je suis bien content !
J'ai vu sur plusieurs boutiques étrangères le Novak GTB 2. On en voit pas en france. Quelqu'un a t'il acheté et testé ce vario ? Est ce un lifting du GTB ?
merci d'avance de vos avis
Salut Losi XXXT,
On est deux dans mon club a avoir ce vario! Acheté aux US car pas encore vu en France! Malheureusement, je ne peux pas donner bcp d'indications car je l'ai testé durant 1pack 1/2 avant que la pluie ne tombe sur notre terrain TT et le transforme en piscine...erfff
On a simplement fait un plug and play, pas encore eu le temps de comparer les programmes! Lipo cut off intégré, c'est cool!
Je reviendrai après des tests plus concluant mais première sensation positive!!
Tonton.
peux tu nous proposer une photo de ton installation pour se rendre compte de l'encombrement ?
tu l'as installé avec quel type de moteur et sur quelle voiture ?
Alors pour l'encombrement c'est légerement plus gros qu'un GTB mais c'est vraiment minime! On a mis ça sur nos T4.1 FT avec des 6.5 !Voila mais bon je peux vous faire une petite photo pour le plaisir...
Par contre, le ventilo d'origine a l'air de meilleur facture que les anciens transparents des GTB.
Tonton.
Bon voila comme promis quelques photos de la bête installée sur mon T4.1 FT!
p><p> <img src=
p><p> <img src=
GTB 2 Instruction Manual
GTB 2 Track Guide
Taking the Racing World by Storm!
GTB 2 GETS X-DRIVE!
Novak X-Drive™ has arrived in a major way, and is taking the racing world by storm! This new technology has now been added to the tried-and-true GTB 2 platform, and is here to stay. Novak is pleased to introduce two new racing speed controls—the GTB 2 Racing w/X-Drive (#1749) and the GTB 2 Racing w/X-Drive- Low Profile (#1748).
1748 Novak GTB2 Racing ESC w/X-Drive Low Profile
The GTB 2 Racing ESC w/X-Drive is also available with a low-profile heat sink (#1748)
WHAT IS X-DRIVE™?
Novak-developed X-Drive™ is the newest motor-firing technology. This revolutionary firmware and hardware delivers unmatched performance and provides:
  • Unparalleled throttle response
  • Smooth and controlled braking
  • Cooler operating temperatures
  • Faster lap times
  • More power for nearly all applications
Customers and team drivers who have used X-Drive in side-by-side comparisons report a noticeable performance advantage. This update not only makes your speed control more efficient, it may very well make you faster and put you on the podium!
THE IDEAL SPEC ESC
Novak’s original GTB, and its successor the GTB 2, have been staples at race tracks all over the world. The GTB 2 platform offers the perfect ESC for almost any class of racing from local Sportsman club racing, to Pro Modified 4X4 Short Course, to any form of on-road racing. The GTB 2 excels in the non-ramping /non-timing Spec Classes and can easily handle the demands of modified 540 and 550-sized motors. It has no built-in timing or motor-ramping features so there is no need to worry about firmware versions, lights or blinks. The GTB 2 is Spec Legal!
LOADED WITH FEATURES
The GTB 2 w/X-Drive has everything you need. If you want to fine-tune the feel and response of the ESC, there are 9 on-board adjustments using the One-Touch button. There is no complicated PC programming or use of external programming devices. The GTB 2X w/X-Drive also features NovaBrakes™. This revolutionary braking system provides instantaneous and unbelievably smooth brake response for every application. In addition to thermal protection, the GTB 2 w/X-Drive has on-board temperature monitoring circuitry. Racers can check their ESC’s temperature during or after each run.
GTB 2 RACING ESC WITH X-DRIVE FEATURES
  • Designed specifically for all forms of 1/10th scale racing
  • Sensor-based ESC for excellent torque and low-speed driveability
  • Nine adjustable parameters to maximum performance on the track:
Minimum Brake (10 settings), Drag Brake (10 settings),
Minimum Drive (10 settings), Dead Band (5 settings), Throttle Curve (Linear/Expo), Brake Curve (Linear/Expo), Brake Frequency (10 settings), Brake End-Point (10 settings), and Drive Frequency (10 settings). Interface also features Reverse Disable and Motor Rotation
  • Novak X-Drive™ provides enhanced throttle response, ultra smooth power delivery, higher top speeds, and cooler operating temperatures
  • NovaBrakes™ provide instantaneous braking under any condition
  • Novak's One-Touch Set-Up™ for quick and easy transmitter set-up
  • Robust, 3-amp, true-spec BEC for strong and fast steering response under any condition
  • Designed to meet ROAR Sportsman Class Racing specifications
  • Highly water-resistant case with protective silicone gasket seal to help keep out the elements
  • Built-in Voltage Cut-Off circuitry prevents damage to LiPo/LiFe batteries
  • On-board diagnostic temperature monitoring that lets you quickly check the ESC's temperature at any time
  • Thermal overload protection circuitry to protect from overheating
  • On-board Hall Sensor Test to easily and quickly verify that the motor's sensors are working properly
  • Cross-cut ESC heat sink (#1749 model) for reduced weight and efficient cooling
  • Gold-plated direct-solder wiring tabs for flexible soldering options
  • User-replaceable input and switch harnesses
  • Carries Team Novak’s commitment to excellent quality, support and warranty (120 days)
  • Designed and manufactured by Team Novak in Irvine, California using
the best components from around the globe. All ESCs are 100% tested to ensure your product works right out of the box and on the track!
GTB 2 RACING ESC WITH X-DRIVE SPECIFICATIONS
  • Motor Type: Sensored Brushless
  • Fwd/Brk/Rev: F / B / R
  • Input Cells: 1*-2S LiPo/LiFe or 4-6 NiMH
  • Footprint 1.16” x 1.47” (29.5 x 37.3 mm)
  • Height #1748: 0.70” (17.8mm); #1749: 0.97” (24.6mm)
  • Weight (w/o wires) #1748: 1.15 oz. (32.6 g); #1749: 1.29 oz (36.6 g)
  • On-Resistance: 0.00040 ohms @ 25°C trans. temp.
  • Motor Compatibility (#1748 model): 540-Size: 8.5-turn or higher sensored; 550-Size: 6.5-turn or higher sensored
  • Motor Compatibility (#1749 model) 540-Size: 3.5-turn or higher sensored; 550-Size: 4.5-turn or higher sensored
  • BEC: 6.0 volts DC / 3.0 amps
  • Wire Size: 14G Super-Flex Copper-Strand Silicone Wire
  • Status LEDs: 5 multi-colored
*For 1S applications, a receiver battery pack or a receiver booster such as Novak's #5477 1S Booster Module must be used.
OPTIONAL/REPLACEMENT PARTS
#5304 or #5309 Plug-In Input Signal Harness (Mini-JST) (optional/replacement)
#5331 ESC 14GA Battery Harness with Traxxas Plug (optional)
#5332 Brushless Motor Connector Wire Set -- 14GA (optional)
#5351-#5353 Brushless Shielded Sensor Harnesses (optional)
#S5431 Low Profile Heat Sink (optional) (not recommended for motors below 8.5T)
#5508 14G Brushless Motor & Battery Wire Set (replacement)
#5512 12G Silicone Power Wire Set: 3 feet Black, Red, and Blue (optional)
#5602 Remote Power Programming Switch (replacement)
#5649 or #5653 Black Cooling Fans 25x25x10mm—2mm Mini Plug (replacement)
#5679 Racing Power Trans-Cap Module - 2S LiPo (replacement)
#5731 or #5741 Low-Loss Power Connector - 5 pairs (optional)
#5831-#5833 Lead-Free Silver Solder (optional)
#5850/#5851 Heat Shrink Tubing (optional)
#5090 Traxxas® Slash 4X4™ ESC Mounting Plate (optional)
By Mike Garrison
LiveRC.com
We are all racers and we all have those hidden little secrets of ours that make us faster. The secrets that you won't even share with your dog on the slim chance he learns to talk and blabs to everyone. We have one of those secrets, and for the simple fact that the boss says we HAVE to share it I suppose I will.
There is arguably no closer racing in R/C than spec classes, especially the 17.5 spec classes. Novak recently released their GTB2 with X-Drive ESC and Ballistic 17.5 brushless motor system, and we were lucky enough to get our hands on it.
First Impression
Right out of the box we immediately noticed the low-profile design of the GTB2. Expecting a far more "chunky" ESC, this was a pleasant surprise and relief to us as it is getting harder and harder to fit ESC's in 2wd buggies these days. The Ballistic 17.5 brushless motor caught our eye with its stealthy black styling and multiple cooling fins. We also prefer the "L tabs" to solder onto which are built into the Ballistic series, as opposed to the "U tabs" which make choosing different wire sizes difficult.
The Build & Setup
Like most brushless racing systems the GTB2 and Ballistic motors require soldering. Novak provided all of the necessary wires and easy to read instructions, so all we needed was a hot soldering iron and solder to finish the job. The GTB2 ESC doesn't require any fancy boards, computer programs, or plug-ins to get setup. It is as simple as pushing a few buttons and reading the light sequences. The lights, unlike some ESC's, are very bright and provide a very easy read. The included instruction manual provides a very easy to follow setup guide. Unfortunately for some of us, lights flashing over and over begin to get a little confusing, and it took a few extra minutes of checking and double checking to get things set to our liking.
Design and Build - Rating 4/5
Bob Novak and the entire Novak crew pride themselves on craftsmanship, and it shows. The GTB2 is precision designed with a unique low profile feature to fit under the most fitting car bodies. While still low profile, it features a unique heat sink that is designed to keep everything cool. The overall footprint and size of the GTB2 low profile is by far one of the smallest released from Novak, however, remains slightly larger than other ESC's on the market. In most spec class racing, with the combination of shorty LiPo pack, ESC size and weight isn't usually an issue however. The Ballistic brushless motor is a fin designed can which is designed to also keep things cool with signature black and orange Novak appearance.
Setup - Rating 4/5
Setting up the Novak GTB2 ESC uses a light system. While this system is pretty straight forward and has been used in the industry for some time, it can be a little confusing. To program the ESC to your radio gear is extremely simple with a one touch button, making it great for entry level drivers. While the ESC does offer fine tuning adjustments for advanced drivers, the light system is slightly more confusing and frustrating to follow than using programmer cards/computer plug ins.
Key Features
This system is sensored which provides consistant and instant response.
Easily setup and tuned using the light system with 9 adjustable parameters.
Novak X-Drive provides enhanced throttle response, smooth power, and cooler temps.
NovaBrakes to provide instaneous braking under any condition.
ROAR Approved for spec class racing
On the Track
Immediately after taking a lap around the track we were at a loss for words. The GTB2 with X-Drive and 17.5 Ballistic motor made us feel as though we were cheating in some way. Had we read the motor wrong?! Why were we going so fast?!
Acceleration - Rating 5/5
The Novak system provides an unreal amount of acceleration and torque for a 17.5 motor. Some "cheater" cars in the stock class using ESC timing were able to make a tricky rythm section with precise moves, however, our Ballistic 17.5 with NO ESC TIMING came out of the corner smooth, laid down the power, and cleared it no problem. On the high traction straightaway the car would actually pull a small wheelie (a rare sight in the 17.5 stock class).
Top Speed - Rating 5/5
Our test track has one straightaway that can prove to be the winning or losing factor in the stock classes. The GTB2 and Ballistic 17.5 ran just as fast and often faster than various other brands on the track. The powerband is very powerful, yet still smooth, getting up to top speed.
Braking - Rating 5/5
This particular category is a very touchy subject, as many ESC's we have ran in the past offer very inconsistant braking and are difficult to setup with our driving style. We like brakes. We like brakes whenever, wherever. Novak has equipped the new GTB2 with their NovaBrakes system. They claim it has "instaneous braking under any condition." Their claim is 110% correct and we couldn't be more happy to say that. We were able to charge hard into the corners brake hard at the last minute and gain time like never before. We will confess that the first lap out we actually stopped 20ft before the corner as we expected to have the usual delay in braking we were used to.
Conclusion
The new Novak GTB2 with X-Drive and 17.5 Ballistic brushless motor is something that we wish could have been kept our little secret, as it is definitely amongst the best spec class systems we have ran so far. The entire system is light-weight, compact, very fast, and did we mention very very fast. For entry level racers setup and programming is simple and easy, and for advanced racers setup and programming is simple and easy but also provides the necessary fine tuning adjustments desired. The secret is out, and we expect that we won't be the only one jumping the tricky rythm sections anymore!
On the LiveRC Beacon Rating we give the Novak GTB2 and 17.5 Brushless system a 4 out of 5. While the light system is very simple and basic, our brain gets confused with changing colors and counting lights, therefore with such an advanced system we would like to see an optional programmer of some sort to make things a bit easier. The GTB2 low profile includes a heatsink built in and is one of the most compact Novak ESC's to date, it's overall footprint and weight is slightly more than others on the market today. Aside from lights and size, this is nothing short of a spec class killer!
Quelqu'un aurait il une notice du GTB2 en version francaise?? Merci
Tonton
