3Racing SAKURA ZERO S
126 posts in this topic
SAKURA ZERO S
Sakura Zero is popular among drivers with positive feedback, it also gains reputation by winning champions worldwide. 3Racing is now going to release an entry level 1/10 on road car kit- Sakura Zero S for elementary drivers as an introduction of competition car with highly affordable price. Sakura Zero S keep utilizing the chassis design of Sakura Zero and select the plastic with best quality as its material, which has proven by thousands tests on tracks that the performance and durability are far more than satisfactory.
The parts of Sakura Zero S and Sakura Zero are interchangeable. As the new car kit is not included assembly, drivers need to construct the chassis themselves, apart from the joy and satisfaction gained from the process, drivers can feasibly upgrade the parts to Sakura Zero.
Sakura Zero S features 2.5mm FRP chassis and 2.00mm FRP long-cutting upper deck, 3.0mm front and rear FRP Shock Tower, pink anodized aluminum motor mount, 2 belt drive system, front and rear gear differentials, full ball bearings, front universal shaft and rear dog bone, steel turn buckles, plastic quick change differential cover, Li-po and Sub-C battery holder with battery strap, plastic fixed suspension mount, oil damper, tires and rims.
2.5mm FRP chassis is specially made for Sub-C battery, drivers can change to use Li-po by their own preference.
The chassis is cut uniquely based on FRP 's characteristics, hardness and durability are highly boosted.
Both the front and rear shock tower are made of 3.0mm FRP, there are 4 settings and 6 settings for adjusting damper angles at the front and rear respectively.
Motor mount is made from CNC machined aluminum for hardness and durability, resulting in good heat loss performance. Anodized pink body makes it look remarkable.
Two belt system provides quiet and smooth run.
Differential is of lightweight design for competition use.
Universal shaft and dog bone are made of steel, which greatly boost its hardness and durability.
The chassis is equipped with 16 pieces ball bearing with different sizes, which makes the car runs smooth with best performance.
Turn buckle is made from steel with extreme stiffness, its counterclockwise design is easy for adjustment.
Battery tray contains two adapters for Sub-C battery and Li-po battery, a battery strap is included for fixing the battery position.
4 suspension mounts with one additional 3 degree suspension mount are consisted, they are made from rigid nylon material for competition use.
Plastic Damper continuously usesthe design of SAKURA ZERO.
Ball stud set up is applied to entre chassis.
3Racing now offers SAKURA ZERO S for drivers who desire for exploring the world of competition car with incredible price. The parts are exchangeable with SAKURA ZERO, do upgrade your car and step forward if you get ready. The new chassis uses shine pink color of SAKURA ZERO, which makes driver becomes the focus of attention on the track.
Specifications & Fearutres
Overall Length: 343mm (without body and foam bumper)
Overall Width: 188mm ( F/R 5mm wheel adaptor)
Wheelbase: 257mm
Tread (F/R): 163 F/R
Gear Ratio: 1:9:1 (38T/20T)
2.5mm FRP main chassis
2.0mm FRP long-cutting upper desk
3.0mm F&R FRP shock towers
Aluminum motor mount with pink anodize
2 belt driver system
F&R Gear Differentials
Full ball bearings
Front universal shaft & Rear dog bone
Steel Turnbuckles
Plastic quick change rear differential cover
Li-po & Sub-C battery holder with quick change battery strap
Plastic fixed suspension mount
Oil Damper
Tires & Rims
Elle a l'air super cette voiture. Quelqu'un connait le prix de ce bolide? Date de sortie?
enfin la ont parlent de la version "S" pas de la pro
La voiture n'est pas encore Dispo en france,
elle le serat normalement début Décembre, pour le prix je ne sait pas encore.
Chassis Sakura S dispo d'ici une dizaine de jours en france.
Prix de vente moins de 140 euros.
Edited by joschua
Hello,
Moi et un collègue avons commandé un chassis chacun pour participer au challenge amical de notre club.
Je donnerais mes impressions si certains sont intéréssés !
Voila, Voiture reçu, monté !! Nickel !!
Belles pièces !
Première Course également,2 chassis présent, avec Victoire en Finale A et en Finale B :XD:
Je voudrais acheter ce chassis , mais les informations ne courent pas les rues sur se chassis, alors est ce que quelqu' un qui le posséde pourrait me dire si ce chassis est bien fait pour les moteurs 540 ? Et sur quel site peut t' on se le procurer ?
Merci d' avance
Bonsoir
pour trouver l'auto il faut te rendre dans une boutique qui l'a commandera a l'importateur
Et oui elle est faite pour les moteurs 540
Ok Merci
Derniere question, se n' est pas un chassis M ?
Pas du tout c'est un chassis format Touring.
Ok merci ,
Mes Carros de TT01 pouront donc allez dessus ?!
EDIT : Les batteries NimH tiennet dedans , car on ne parle que des li-po das la description ?
Les encoches dans le chassis sont la pour les nimh, pas de souci!
Les carros devraient jouer niveau passage de roues mais il se pourrait que tu doives refaire des trous...
La couronne fournis c'est du 48 ou 64 dp ?
Les photos peuvent être trompeuses mais pour moi ça ressemble plutôt à du 48dp...
Châssis intéressant et original...
Avez vous des retours sur le chassis ?
performance par rapport a du haut de gamme genre Mi4, Xray T3, Tam 417 etc etc?
fiabilté du chassis ?
Et ou trouver les pièces en France ?
Merci, Marc
bonjours
déja la voiture a la meme architecture que sa grande soeur la zero .
cependant cette version est plutot pour le loisir avec la grande majoriter des pièces en plastique
pour trouver des pièces aucun souci . juste trouver une boutique qui vend du 3racing
en ce qui concerne la comparaison la sakura zero est une bonne voiture pas mal réussi compétitive pour une premiere voiture de la marque
bonne journée
arnaud
J'aurais voulu savoir, les noix de cardans coté diff sont en plastique, acier ?
La qualité générale des materiaux est bonne ou il y a du jeu partout et sa s use vite ?
D'apres vous elle peut supporter un ensemble brushless Robi en 5.5T ? je penses que oui mais je prefere avoir votre avis
Merci, bon week end
les sorties de diff sont en acier.
Pour un 5,5t ça me parais un peu "généreux" pour la version S.
Sinon les plastique sont de bonne qualité et ça s'use pas trop vite.
