Thomas P
Thin B4.1
20 posts in this topic
Just wanted to show off my "new" Thin4.1..first run today and it was a rocket...easy to drive, a lot of steering and well balanced..
le chassis est super beau par contre la carrosserie...
Hi Thomas,
Your car is nice but the body is.... :oo: surprising :D
Regarding the frame, is it home made ? What are the advantages compared with the original B4 ?
Rgds
Olivier
Yepp, i know..a lot of people do not...like the lid :D....the chassi is "home made", used a B4 fro mstart and then dremel, carbonfibre,CA,epoxy and some time :D...Hmm, it have tons of steering, good rear end grip, quick when ya change direction...Hmm, maybe centered weight in to the car?...real easy to handle in the air..
Hey Thomas.P
Cool project !Are you from Sweden ?
Could you point us towards links explaining how to mold CF ? I'm lost among the gazillion techniques and products that can be used. RC boats and planes hobbyists seem to use different resins and fibers, and various molding techniques. What worked for you ? A tutorial would be great.
The body isn't so bad... did you use PET ? Does it prevent the need for a front wing/spoiler ?
Also, what's with the narrow rear tires ?
Edit : I see you used a stock b4 chassis and just two woven CF sidewalls... give us more details !
Thanks !
Hey Thomas.P
Thanks !
Yepp, im from Sweden :)
It is PET, from a Coke 2L...no need for a F-wing :)
They are Thundertigre 4wd fronts...im back on Schumachers Pin/Spikes
Yes, a regular Stock B4...hard to eplane, but a lot of cutting,sanding...il see if i can get some more pics up for ya..
Brb
T
I see i'm not the only one to have stolen ideas from Lars Jonsson's blog ;-)
I was asking WHY did you use narrow rear tires?
thanks in advance for the pictures
Edited by heretic
Ok i've been on your blog and I stand corrected, the shell is the ugliest I've seen in years. :carre:
True :D...
Why i used the narrow one´s, i did not have any stock rear ones :(...but now i do :)
/T
So, kind of pleased..waiting for new Electrics, update this evening i hope..
the batteries weight is maximum pushed to the front end.
Did you tried the car on a slippery track ?
No grip issue ?
@peuge73, Nope, not yet..not sure if i dare to :D..
think i moved the batt app 40mm towards the front. Added GHEA brass in the rear,Speedpassion ESC and a Rx..im not telling i am back to stock weight"place", but little..
the whole car will lift, when i grab it app 3cm towards the front tower from rrear towerbrace.. it would be fun if it works on loose tracks, but no must :)
@acaciapiks thanks for those words m8 :)
Nice rig with a really neat build.
But what if your next esc is 3 square millimeter bigger :-D
Hmmm,, it wont be a Thin4.1 it will be a Fat4.2 :D...na, dont think il be changing ESC for a long time
Thanks for all worm words guys.
/T
/T
Thank you to share us your work, and specially in a stranger forum fo you.
pegue73 it is just fun to see what other think of my ideas...i hope it can work descent on loos tracks, but i do not hope to much...it will roll for 2 races this winter..WBC here in Sweden(winter buggy cup)
